Class 230 units training/introduction on the Borderlands line: updates
Sam 76
10 Nov 2021
Southport.
If they did Merseyrail battery trains it would be a smash. 30 minute headway to start with, trains through the loop so people can get to Liverpool instead of changing at Bidston (which is like being on a mini Piccadilly platform 13/14 in terms of bleakness). Definitely a case of 'build it and they will come'. People in the area really like the Merseyrail offer they don't really check the timetable, they just rock up and go.
I’d be careful what you wish for for now. Sadly as amazing as the 777s are and as much as I like them reliability like the 230s is a huge issue
1 Dec 2022
Lancashire
Merseyrail hasn't got the battery-operated trains in service yet so I'm not sure it would "be a smash".. The 777s that are in service are also very unreliable (possibly not to the extent of the 230s but hard to judge due to differences in service frequencies - 1 cancelled train on the merseyrail network has less impact than on borderlands line), there are often cancellations through PIS / door / step board etc faults on the Ormskirk and Kirkby lines & commuters are fed up with it. They definitely do still have to check the timetable, particularly for any cancellations. There's also no guarantee that if Merseyrail did take over the operations of the Borderlands lines that it would be 30-minute services, nor that it would go through the Liverpool loop.
I know the North Wales Transport Commission have recommended that Merseyrail take over operations, but have Merseyrail made any suggestion that they actually want to take over the route?
Xenophon PCDGS
17 Apr 2011
How much autonomy does the North Wales Transport Commision actually have and would the Welsh Government have the final say on what train services run in their area?
Skie
22 Dec 2008
Plenty. And Merseyrail don’t have to do the DFTs bidding either as Merseytravel is in control of the franchise. The two sides have a good relationship, especially with the senior ops management of TFW having prior experience with Merseyrail.
The 777s are also improving in reliability. Software issues are (mostly) sorted and other issues pretty well understood.
CaergwrleKen
2 Oct 2019
Caergwrle
After a cancellation this morning and a steady few hours the service has collapsed again, probably be a double swap now to keep the rest of service going but for how long
L401CJF
16 Oct 2019
Wirral
1430 off Wrexham axed 230007 due to loss of multiple gensets on inbound.
Also noticed a plain white enviro 200 bus parked outside Wrexham General Station all morning with a driver sat onboard at the back - possibly a backup bus?
TDK
19 Apr 2008
Crewe
Sounds like it would have been better to create 5 or 6 × 3 coach 150s for thd service and use the fuelling point at Birkenhead North if a 150 set was running low and required a top up.
3-car 150's will not fit on all the platforms so notes viable solution.
tomuk
15 May 2010
The NWTC is a completely advisory body and has no power to do anything. Th Welsh Government through TfW are responsible for services Wrexham to Hawarden Bridge, Neston through the agreement of DfT. Heswall, Upton and Bidston are Merseytravels problem.
TDK
19 Apr 2008
Crewe
What is the range of a 777 on batteries alone? Your answer needs to take into account the gradients from Shotton to Buckley.
Ribbleman
12 Jun 2019
Early discussions, two or three years ago now, were centred on the notion that TfW would run from Wrexham to Liverpool using battery equipped 777s leased from Merseytravel. That would make sense as the extra units could be drawn from the options that Merseytravel hold with Stadler, rather than TfW having to negotiate with the manufacturer for a small production run. Rapid recharging would be required at Wrexham Central and possibly at an intermediate point, Shotton being the most likely.
Those thoughts may have changed but nothing firm is likely to happen until battery operation to Headbolt Lane is deemed successful. Trial operation on the section from Kirkby is expected to commence shortly with service trains continuing as empty stock to the new terminus, before returning to Kirkby to pick up passengers towards Liverpool.
L401CJF
16 Oct 2019
Wirral
The 150 is back today along with the late evening/night services. 150240 doing the honours.
CaergwrleKen
2 Oct 2019
Caergwrle
150 covering an extended full diagram by the looks of it starting with the 0620 Bidston this usually stands down at 1840 but it’s extending to work the evening so the last from Bidston will run for the first time in a while
185
29 Aug 2010
Out on this yesterday with a short hop from Neston to Heswall. It was on time (??!!) as was the one 40 minutes in front of it.
Doors did take about a week to open / close, so we did close the doors after ourselves to get the train away quicker at both stops. A shame - noticably no passengers, a sign people have given up on the line.
Underneath did not sound healthy, for any train I've been on in my 25+ years on the railway.
CaergwrleKen
2 Oct 2019
Caergwrle
The Sunday timetable can’t really be relied on because it’s very messy and they have drop backs on most trips.
Monday update 009 looks like it’s had enough almost an hour late on 1435 from Bidston
D365
29 Jun 2012
For all my previous Viva commentary - Ford engines certainly aren’t railway conventional…
Was not the idea of the 230s, similarly to the Marston Vale and East West Rail, that they'd last about 10 years which would be enough time to work out whether they wanted to hand it over to Merseyrail or not and if Merseyrail would want it, and to get the extra battery 777s ordered?
Ribbleman
12 Jun 2019
The conversation at the time was with the Chair of the Liverpool City Region Transport Authority. There was no suggestion that TfW would not continue to run services on the line, but that Merseytravel would be willing to lease 777s to TfW to enable them to run from Bidston around the Liverpool Loop. That was his position at the time but what will happen going forward remains to be seen. The success of the battery operation of the 777s and the determination of the WAG to have through Wrexham-Liverpool services will no doubt be major factors.
185
29 Aug 2010
Tis a shame they cant have a short 4km (Shotton elev 6m → Hawarden → Buckley elev 108m) section of third rail on the Wrexham bound side only, to take the weight off the batteries, or, budget 750vdc tram style overheads if a 3rd rail easement is not given - modify a couple of trains for it. If I recall, there's only one foot crossing at Ash View - the duplicate crossing at Buckley can go with the station crossing being the only one - electrification could finish just before there.
samrammstein
13 Apr 2011
Capenhurst
Enjoyed 007 from Bidston to General and back this afternoon.
2F74 was delayed at Wrexham General waiting for a new guard coming off the late running 1V96. Otherwise 230007 seemed to be running fine after her problems this morning. Onboard staff were great, as always with TfW, very apologetic and even a dedicated cleaner onboard for the duration.
Rather noticeable was the rough jointed track heading South out of Bidston. The unit sounded like it was going to fall apart and I've had smoother rides from the wooden coasters at Blackpool.
Wyrleybart
29 Mar 2020
South Staffordshire
Haha and bearing in mind the TfW 230s were theoretically out of a comprehensive overhaul at Long Marston, they have barely lasted three years, and have been sitting around for some of that. There is a Youtube video of 230010 at Stourbridge Jn on tests on the 5th June 2021. That is two years and a couple of weeks ago. 230006 and 007 ware recorded there in July 2020 - not even three years ago.
I have tried to give the Vivarail 230s a lot of lenience as a new technology, but after Vivarail's experience with 230001 and 2360003-005, I just don't think they will ever be able to offer a reliable and robust service. From what I can tell TfW have five units in the fleet - all between two and three years "fresh" out of their most significant overhaul in their lives, yet two in traffic and the failure standby cannot deliver even one week of robust service.
Not only that, batteries degrade over time, so if they cannot deliver the service now, there is no way they will still be running in ten years time. TfW need to do the decent thing for the people of Wales and the borders.
Nicholas Lewis
9 Aug 2019
https://www.senedd.tv/Meeting/Archive/b628e320-938e-4a12-b32e-749f9897c9c0?autostart=True#
Class 230's being briefly discussed in Public Accounts meeting.
Below is copy of the letter sent and reply received from TFW CEO.
https://business.senedd.wales/ieListDocuments.aspx?CId=735&MId=13386
It also includes the costs of the units and associated costs with the program.
Very interesting and the good thing about the various train operators moving away from DfT control is that we are getting to see the detail behind the numbers and the issues that are never exposed to proper scrutiny.
tomuk
15 May 2010
What proper scrutiny? WG\TfW have spent £30m so far on five lemon trains where is the scrutiny of the procurement process or the decision to buy them outright?
Dai Corner
20 Jul 2015
This paragraph in the letter from TfW to the committee seems at odds with what we've read in this thread
In addition, the Class 230 trains have generally been operating reliably and the major
technical issues seem to have been resolved.
Nicholas Lewis
9 Aug 2019
Granted the decision on procurement looks extremely poor value compared to just leasing more 197's but decisions on awarding contracts by public bodies never get any scrutiny before award generally as executives are empowered to just let the contracts as long as they follow due process. My point about scrutiny is that TfW have been forced to expose the detail you will never see the high level number for a DfT run contract let alone the specific detail we have here.
tomuk
15 May 2010
No such figures have ever been revealed in front of the UK Transport Select Committee or Public Accounts Committee? I don't have examples but I find it unlikely and how have TfW been forced? The Welsh PAC sent them a letter and James Price replied and happened to be more open then some DfT mandarins might be. The letter wasn't really honest about the performance of the 230s either.
