Class 701 'Aventra' trains for South Western Railway: progress updates
Nicholas Lewis
9 Aug 2019
700 ato is in use in the core.
not regularly from my journeys but perhaps should have clarified that whilst it was specified, installed and commissioned there unlikely ever to run a service frequency that will need it. So as i see it ABDO will fall into the same hole but happy to be proved wrong.
Slightly OT, but around a third of my journeys through the core are now on ATO, and it is magnificent. Has the potential to knock a minute or two off the core transit time.
Minstral25
10 Sep 2009
How can you tell if you are not in the cab - I use the Core regularly and would be good to know what is ATO and what is driven.
three ways:
1) driving style. When entering a station, under ATO the train will usually be at linespeed (30mph) and then throw the anchors out about 2/3rds the way along the platform, braking at a consistent (and firm rate) to stop bang on the stopping point. Naturally, drivers will brake earlier, and modify their braking particularly in the last 30 metres or so. Sometimes, if the train under ATO is waiting a previous train to vacate the platform, when it gets movement authority you will find it accelerating hard into and along the platform to the braking point. Drivers don’t do that, they will typically coast at lower speed for a while. When leaving the platform, ATO basically lights up the afterburners and away you go.
2) doors. Under manual driving, the driver has to confirm the train is fully platformed before pressing the door release. This takes a couple of seconds. Under ATO, the train knows it is fully platformed and releases them straight away. If the doors open within a second of the train stopping, rather than 2-3 seconds, it’s ATO.
3) the easiest way. Sit in the first bay of seats behind the cab. If you can hear AWS pings and warnings, its not ATO! (You will hear the double chime of ATO updates coming through instead if the ATO is in).
Nicholas Lewis
9 Aug 2019
I did wonder yesterday whether we were on ATO as the train was quite rapid through the reverse curves at Farringdon before coming to a stop on a sixpence. You can tell on A320 when they've switched on autopilot if your up front as you hear two bleeps when they switch it on an off so other than faster running how can you tell?
Bessie
30 Oct 2017
How many 701 units have people seen stored at Feltham? I passed there the other day and saw the 3 x 10 car units. One of these was 701025; I couldn't make out the other unit numbers.
Goldfish62
14 Feb 2010
I've only ever seen two, so the third one must be recent. At least one seems to go out on test daily.
5 Jan 2014
Saw 2 in Feltham depot this morning and a third stopping on the up platform at Feltham station about 11:46 as I got off a Reading train. Sorry do not have any numbers to offer
Minstral25
10 Sep 2009
three ways:
Thank you - that makes sense
Fincra5
6 Jun 2009
three ways:
Well.... Its about 50% down the Platform a 700 (Both RLU and FLU) will apply 80% Brake. It will ease off on the approach to the appropriate stop mark. It does accelerate about 100%.
You also don't get AWS Pings on ETCS Level 2 when driven manually :) The "Double Chime" is all the same tone for Movement Authority too.
ATO is a good performance tool but it's not perfect!
What's degraded working?
Camera's fail etc.
spark001uk
20 Aug 2010
Any more news on whether RMT are happy with the driving cabs now (with latest mods)?
Fincra5
6 Jun 2009
Thanks. Well, that makes perfect sense given there'll be a guard on every train.
Seems similar to GA Guards, who retain PTS/ Competencies if there's issues with the Stadler Units. (Which use DOO Camera's to Dispatch).
Wokingham
28 Sep 2019
Wokingham
t
Software development is a mine-field. If you took the exact same software from one Aventra and put it on a new build which had 1 or two different components and I guarantee it will not work. Its not as simple as changing a line of code as each piece of code is dependent on another, thats why so many companies dont change computer systems of components. Cash machines still use 20 year old Windows NT and components that are the size of old TV's because they know it works. Trains however, we want new things, new PIS, wifi, aircon, powersaving lighting, CCTV, USB and plug sockets, power management, anti slip, remote monitoring and lower costs. Thats a lot of things to be integrated into one system. Thats a lot more than is going on in your PC and Windows is about 3GB of code and supported by a team of thousands. I could go on for hours, but give the Derby guys a break, software development and testing is hard which is why it pays well!
If I'm right, the 701's are the sole DC only variant of the family, which if so, could easily be the source of the problem.
thats a interesting thought maybe that is the problem, atleast that silly rumour of binning them of has lapsed
Goldfish62
14 Feb 2010
The RMT's problem with the 701s is a rather wider issue - the long-running dispute over Guards operating doors!
Perhaps I'm going mad but that been settled hasn't it? Or has the RMT now unagreed what was voted on and accepted by members?
Are you confusing it with Southern where they're still officially in dispute?
Towers
30 Aug 2021
No, was just referencing it; sorry! :)
