Bet you £5 it isn't.....Cross city first
I would think so. The units have 2+2 seating and as such are built for the sort of passenger traffic on the route. Not too many years ago the route was worked by class 323s.Am I correct in thinking that Wolverhampton to Walsall via Birmingham New Street will be a single three-carriage 730? If so that would be quite a downgrade as it is well used between Wolverhampton and Birmingham New Street.
Don't forget that there will be be the extra Wolves - Walsall route once the new stations open. Granted that's not via New St but there's many options that way already.Am I correct in thinking that Wolverhampton to Walsall via Birmingham New Street will be a single three-carriage 730? If so that would be quite a downgrade as it is well used between Wolverhampton and Birmingham New Street.
Maybe if Liverpool and Shrewsbury to Birmingham returned to two trains per hour the additional services can make additional stops at stations between Birmingham and Wolverhampton to offset the reduction in train length by replacing four-carriage 350s with three-carriage 730s.Don't forget that there will be be the extra Wolves - Walsall route once the new stations open. Granted that's not via New St but there's many options that way already.
There wasn't a pandemic when they started building and training on them so there is a difference.GA 720's were from the same supplier they managed to get their drivers trained and the units commissioned so they should have been able to equal what they achieved.
Well they are down as the 323 replacements, plus 350/2 will go at some point. So X-City was the plan initially, but supporting 319 replacement first now.Maybe if Liverpool and Shrewsbury to Birmingham returned to two trains per hour the additional services can make additional stops at stations between Birmingham and Wolverhampton to offset the reduction in train length by replacing four-carriage 350s with three-carriage 730s.
To summarise, am I right in thinking that the WMR 730/0s will be used on the Cross City line and anything that goes through Walsall?
Someone correct me if I’m wrong, but I’m pretty sure that the general idea with the 730/0s is that they will be the main commuter EMU for the west midlands, running Cross City, Walsall-Wolverhampton, maybe Chase Line and maybe Brum-Crewe, hence the change of the order to 48 730/0s, and 36 730/1 (dunno if 730/2s will exist since they do not seem any different to 730/1s now).What is the overall plan with the 730s then?
WMR /0s on the XC and Walsall-Wolves
What is the plan for the /1 and /2?
Wikipedia quotes Modern railways as saying the /1s are for suburban/commuter services and the /2s for the long-distance services, so I suspect any difference would be in interior layout/spec.Someone correct me if I’m wrong, but I’m pretty sure that the general idea with the 730/0s is that they will be the main commuter EMU for the west midlands, running Cross City, Walsall-Wolverhampton, maybe Chase Line and maybe Brum-Crewe, hence the change of the order to 48 730/0s, and 36 730/1 (dunno if 730/2s will exist since they do not seem any different to 730/1s now).
There's some 15 minutes of slack at Northampton on the Euston to Birmingham services, maybe they can use this time to enable joining/dividing, i.e. 12-carriages from Euston to Northampton and 8 continuing to Birmingham. I'm not convinced that 2tph from Northampton worked by 8-carriage trains is enough, especially as these services originate at Birmingham and call at all stations to Leighton Buzzard.The 57 350s left will still operate Euston-Brums, Abbey Line services, the services above that I mentioned I’m uncertain of and additional peak services. If these are the only services they’ll operate I doubt how highly utilised the 350s will be, and wonder whether some other services will continue to be 350s.
They both will now have 2x2 intercity tables+armrests interiors, so I don’t see any reason as to why they’ll be separated by subclass now.Wikipedia quotes Modern railways as saying the /1s are for suburban/commuter services and the /2s for the long-distance services, so I suspect any difference would be in interior layout/spec.
Well training and testing was stopped during the pandemic due to social distancing so that had a affect.There wasn't a pandemic when they started building and training on them so there is a difference.
AIUI the WMR/LNR franchise was intended to split during it's life into two different business. I beleived that the class 730 order was reflected in the split. However, I understand the class 730/0 order is being increased from 35 or 36 units up to possibly 48, the class 730/1 takes the balance of the build, and class 730/2 remains stillborn. Not seen that anywhere but I find it odd that so many 90mph 730/0s are still being built instead of the 110mph variants.They both will now have 2x2 intercity tables+armrests interiors, so I don’t see any reason as to why they’ll be separated by subclass now.
It was, but it won't now. Out of interest, how many 323 and 350/2 are there? Keeping the 730/0 to X-City, Wolves/Walsall and New St-Crewe via Stoke negates the speed difference and probably replaces all of those unitsAIUI the WMR/LNR franchise was intended to split during it's life into two different business. I beleived that the class 730 order was reflected in the split. However, I understand the class 730/0 order is being increased from 35 or 36 units up to possibly 48, the class 730/1 takes the balance of the build, and class 730/2 remains stillborn. Not seen that anywhere but I find it odd that so many 90mph 730/0s are still being built instead of the 110mph variants.
Whether the franchise split will still go ahead bearing in mind it is technically no longer a franchise as such.
26 323sIt was, but it won't now. Out of interest, how many 323 and 350/2 are there? Keeping the 730/0 to X-City, Wolves/Walsall and New St-Crewe via Stoke negates the speed difference and probably replaces all of those units
Pretty sure yes. But any idea when will the first unit getting into full passenger service?Have they began testing units on the WCML yet? On realtime-trains there’s some Q headcodes that look like they could be it.
One of them was a C2C 720.Have they began testing units on the WCML yet? On realtime-trains there’s some Q headcodes that look like they could be it.
This has been worked up to Crewe regularly over the past week or 2. Can't remember the unit number unfortunately.One of them was a C2C 720.
Yes there have been plenty of test runs between Eus-Cre.Have they began testing units on the WCML yet? On realtime-trains there’s some Q headcodes that look like they could be it.
I thought I recalled seeing photo's of the LNWR 730's at Euston but was told they'd not done any mainline testing - do you recall when this was please?Yes there have been plenty of test runs between Eus-Cre.
Not sure if the LNWR ones have been out, the WMR ones definitely have.I thought I recalled seeing photo's of the LNWR 730's at Euston but was told they'd not done any mainline testing - do you recall when this was please?
Yes 37611 with the 730 came storming through Coseley at 09-15 this morning730018 was dragged to Tyseley from Oxley this morning and a return path is booked later back to Oxley?
Any ideas as to why?
I think 730103 has been out on test, assuming the image in this twitter post is indeed showing the unit on it's own.Not sure if the LNWR ones have been out, the WMR ones definitely have.
Ahh yeah, there are also 2 LNWR units at Crewe depot. Maybe this is one of them, think they are 730103/105I think 730103 has been out on test, assuming the image in this twitter post is indeed showing the unit on it's own.
Assuming they haven’t moved since Saturday it’s 103 and 101.Ahh yeah, there are also 2 LNWR units at Crewe depot. Maybe this is one of them, think they are 730103/105
