Class 810 for East Midlands Railway Construction/Introduction Updates
QSK19
29 Dec 2020
Leicestershire
I don't know the exact reason. But I'm guessing that it's because between Bedford and London it's 100 max under the wires.
Could it also be because the demand from yet another train would be too much for the electricity supply? I seem to remember this being the reason why TPE have to run (some or all of?) their 802s in diesel along the ECML.
I seem to remember the EMT menu being fairly sensibly priced?
To be fair, yes it was reasonably priced. I think I got a fairly big bowl of tomato soup for something like £2.49 - wasn’t bad either!
That is definitely the reason, it’s come up a few times before. It’s why there’s an upgrade underway on the original wired section between St Pancras and Bedford
Nicholas Lewis
9 Aug 2019
Imagine if we had trains where the amount of carriages could be amended through the day to suit demand?
I grew up on the Southern and splitting and joining went on all over the region but it did come at big cost of extra train crew to do that so has largely died out in favour of leaving stating formations as they are all day. Also gives you a bit of resilience if the service gets perturbed and you need to hoover up extra passengers.
Edvid
7 Feb 2008
Though the 810s won't be in service for a year or so I'm quite curious to see what 125mph is like on the Midland juice; as a Luton resident it'll likely be Sundays only for me.
Probably; the supply at Long Meadow Farm (near Sundon) currently stretches 44 miles to Corby, which isn't good for much beyond Thameslink and the half-hourly EMR Connect service. No APCO zones either (yet).
43066
24 Nov 2019
They are currently building 7 car for Avanti.
Of course - I forgot about those. So many variants it’s easy to lose track :D.
The 810s are unique, aside from adding trailers extending them with more motor cars may be difficult.
There’s also the issue that the EMR versions are having different power systems AIUI to achieve 222-equalling performance on diesel, so adding another coach to a nine car would worsen the power to weight ratio, without completely changing motor coaches etc. As you say with the meridians it’s easier as they’re one engine per vehicle.
No doubt changing unit formations plus power plant arrangements plus vehicle lengths (and all the associated software upgrades) would all have added even more cost.
Much like 125mph off the Midland juice but with less vibration, I imagine (and hope:lol:).
The_Train
2 Jun 2018
Like 5-car 810s? :)
No, like single carriages coupled together so you don't have to remove or add in multiples of 5. Then again, I'm going back to a bygone era when capacity was decided based on usage and not decided by bean counters
Killingworth
30 May 2018
Sheffield
When lines of spare carriages were held in large station central roads ready for fairly quick use and many more manky old coaches were held in odd sidings across the nation to be used for a few summer Saturday services and football specials, like these held in 5 now all but forgotten sidings at Dore. Old, but at least they'd link up with almost every other coach and locomotive and you could walk the length of a 14 car train.
Maintaining such a large fleet for occasional use was one of Beeching's shock/horror observations - plus maintaining all those holding sidings. I doubt he'd see the sense of so many incompatible micro fleets ordered to meet markets maybe 5- 35 years ahead.
The Power supply is more than adequate. Its so they can make full use of the speed profile. (Albeit whenever i see them they see to be on the slows).
43066
24 Nov 2019
If we’re deciding capacity purely on usage we still wouldn’t be using individually coupling coaches these days, surely? Given how busy many EMR trains are if anything it would mean longer fixed formations (perhaps along the lines of the mix of five and ten cars suggested above).
snowball
4 Mar 2013
You seem to be talking about the southern MML, but you were replying to a post about the northern ECML (though in an MML thread).
The post i replied to was suggestimg power supply issues on the southern MML…
QSK19
29 Dec 2020
Leicestershire
No, I was referring to the electricity capacity on the MML and merely using TPE’s 802s as an example of what I meant - ie they run in diesel mode under the wires because there isn’t enough electricity. @Bald Rick then kindly provided an answer.
Spot on.
sharpley
18 Aug 2018
810001 passed by me through Melton Mowbray station a few minutes ago. Seems to be a few movements scheduled out of Old Dalby this morning on RTT.
Verulamius
30 Jul 2014
Seems to be heading to Newark and then shuttling back and forth to Peterborough today.
Laketop
12 Mar 2019
Realtimetrains have it pathed as diesel until Peterborough, but then electric between Peterborough and Newark. I recall seeing it on a run yesterday but the pantograph was down.
Was it running electric today?
800001
24 Oct 2015
Diesel.
It’s not ready for electric testing yet.
K.o.R
6 Dec 2017
From Doncaster it goes down the MML via Beighton and the Erewash line, but only Hull Trains practices this as they're the only ECML operator that were allowed paths
a 9-car 80x fits with 6 meters to spare, and a single 5 also fits. it's a double 5 that wouldn't, hence the slightly shorter 810 vehicles so a double 810 does fit in the platforms
I was talking about how does a train on the ECML actually travel to St Pancras, as there is no immediately obvious link to the non-HS1 platforms from the ECML. Turns out it's actually a sizeable detour!
baz962
8 Jun 2017
The OHLE south of Bedford is currently being upgraded.
Of course. I'm well aware , but the question posed was why don't Hull trains run pan up and currently the max linespeed for pan up running is 100 between Bedford and London.
norbitonflyer
24 Mar 2020
SW London
Indeed. The detour is used when there is a possession on the ECML somewhere south of Doncaster.
InTheEastMids
31 Jan 2016
Would an 80x be able to change to electric power anywhere in the MML without stopping?
43066
24 Nov 2019
That I'm unaware of. Sorry bud
The plan is that the 810s will be able to changeover on the move.
No idea whether the necessary balises are installed as yet, so won’t be relevant to Hull Trains (who I see are clogging up St. Pancras again today :rolleyes:).
cactustwirly
10 Apr 2013
There are twenty four trains from Waterloo to Weymouth each day, I do not think you can compare it with the Highland Chieftain.
I'm not advocating for new stock and on-board service (though a trolley for that and Exeter really would be welcomed back), but when Weymouth has nothing, I think EMR customers moaning that they have a trolley instead of a buffet on their 90 minute express to Nottingham is somewhat entitled.
The Weymouth service is just a commuter service, you can't compare it to EMR's Intercity services.
It's like removing the shop on Avanti or LNER for London to Manchester or Leeds.
