That varies. It seems to be a 70 for a few weeks at a time, the a pair of 56s for another few weeks, then back to a 70 again. I think they may rotate like that to keep up drivers' traction knowledge.Also Preston Docks - Lindsey Bitumen which tends to be a pair of 56s.
What is the significance of 813?Edit: I also like it how the picture is of 70813..
Indeed, I wouldn't be surprised if they eventually make their way over to Freightliner or Cappagh / DC Rail - Freightliner seem happy proving their pulling power on the Somerset "Jumbo" trains, though surprisingly not actually using them full time on them.They are crap on t3 work, but excellent for bulk haulage.
I'm guessing @XCTurbostar is referring to the picture used being 70813, but the advert being for 70801-4.What is the significance of 813?
T3?They are crap on t3 work, but excellent for bulk haulage.
I see. Probably just got whatever images were available.I'm guessing @XCTurbostar is referring to the picture used being 70813, but the advert being for 70801-4.
Engineering possessions, worked under module T3 of the rule book.
Auto stop, lack of cooker, plus the parking brake on a non-twin-piped top and tail.Engineering possessions, worked under module T3 of the rule book.
I think 4F89 may be referring to the comfort (or lack thereof) during downtime on such jobs. It isn't easy to find a comfortable position to sleep on them (although I usually manage, tbf), unlike, say, a 66 or 60. It's either that, or (more likely, now I think about it), the fact that the engine autostop suspend button needs to be pressed every 30 minutes to prevent it shutting down - the Colas 70s have an advantage here as they will run for 2 hours.
Another advantage the Colas ones have...parking brake on a non-twin-piped top and tail.
#ifyouknowyouknow
How do theirs differ? From what I've read, the pb isolation is the same on either FL or Colas.Another advantage the Colas ones have...
ThanksEngineering possessions, worked under module T3 of the rule book.
All were modified a few years ago, no longer any need for the pulling of toggles etc. Tie them on and go, either behind the lead loco or top and tailed. Very, very welcome.How do theirs differ? From what I've read, the pb isolation is the same on either FL or Colas.
When u call for 5mph and get either zero, or 40, that's a start!How do you come to the conclusion they're crap on T3s?
I did hundreds if not thousands of hours on 70s on T3s. Only loco I ever got to drop stone at .5mph was a 70 - absolutely awesome bits of kit.When u call for 5mph and get either zero, or 40, that's a start!
