- Joined
- 14 Jul 2011
- Messages
- 18,493
Well, the British Library is rather annoying but I think the obvious location for consolidation is probably the Euston Road complex.Where would this gigantic 'London Central' be? Maybe Farringdon, or City Thameslink, or Strand, where KCL is rn? Maybe between Moorgate and Bank. We could do consolidations, too. Euston-Kings's Cross-St Pancras Int'l? Maybe just a gigantic Waterloo that swallows Waterloo East. Marylebone/Baker Street? Ok, probably not that one.
Wouldn't allow total elimination of terminating tracks, but a Euston redevelopment for maximum capacity and a new station on the Library/surrounding site would probably be the "least work" way of doing it.
Might want to be further sotuh though.
If you are willing to have a fully underground station you could probably put it under a royal park, dig a huge pit, build the station and put the park back on top - although you'd need to bore at least one tunnel first for the spoil conveyer!
Well I assume you just tell HS2 they are going to use 915mm platforms. Then build everything to the largest loading gauge you can and 915mm platforms, with a handful of 760mm platforms for HS1 international compatibility. How big would the platform gap to a Class 374 be if a suitably gauged 915mm platform was installed? Too big to step across? HS1 would need separte platforms for international trains whatever you do though.Also interesting to consider what this station would need to have - lots and lots of (presumably underground) feeder lines from the old termini, some 25kV OHLE, some 750V DC. Some at UK loading gauge, and some at European - unless they go all European for tunnels and then have dedicated EU loading gauge platforms for HS1 and HS2. You'd need international platforms and facilities, and a LOT of shops.
The availability of 19m diameter tunnel boring machines probably makes it quite a bit easier by allowing more running lines to be stacked in each tunnel bore.
