Some points have electric heaters so that they do not freeze in winter - could you have some sort of refrigeration system which would cool the metal so that they do not over - expand? Maybe coupled with side protectors so that heat from the sun when not directly overhead hits the protectors and not the track.various mitigations have been tried over the years to reduce the failure rate of these points - including, at one stage, a sprinkler system. The only reliable mitigation to avoid the points failing is to take them, and two similar sets of points south of Harrow, out of service when the rail temperature gets too high.
By way of background, this thread ( https://www.railforums.co.uk/thread...nning-on-slow-line.247632/page-2#post-6199009 ) asked why fast Metropolitan trains were running on the slow line, and the answer was that a set of points was running hot due to direct sunlight in recent high temperatures. I was therefore wondering if there were other ways in which tracks could be kept cool, particularly at critical points, to avoid disruption.
