Could an ECML diversionary route be created using East-West Rail?
Midnight Sun
16 Sep 2018
Moderator note: Split from
Badly needs an electrified diversionary route
Wire the planned East West Route between Bedford and St Neots. This would allow Thameslink Bedford services in times of failure on the ECML to be extended to Peterborough.
Ianno87
3 May 2015
Moderator note: Split from Wire the planned East West Route between Bedford and St Neots. This would allow Thameslink Bedford services in times of failure on the ECML to be extended to Peterborough.
Unlikely to be a west-to-north chord where EWR and the ECML cross.
Passengers could however be directed to travel via Bedford and Tempsford (chamging trains) during disruption.
37424
10 Apr 2020
I think HS2 wasn't going ahead it should have been considered as a priority ECML being able to be diverted into Euston and WCML being able to be diverted into KX, with Midland being able to be diverted into either, Obviously St Pancras has limited platform capacity which is why I have kind of left it out, but it would need probably significant extra provision on the East West Rail Link not least of which it isn't planned to be electrified now, but with HS2 it would seem less of a priority even if the whole thing doesn't get built there will at least be a good alternative to the West Coast Route.
Steve Harris
11 Dec 2016
ECML
That is providing that trains can reach that far south on the ECML (during disruption) and be turned to go North again. Otherwise that advice would be pointless, would it not ?
Taking last weeks trouble at Biggleswade as an example, trains were being turned at St Neots and as far as I'm aware the next place trains can be turned is Biggleswade itself (which wasn't possible last week).
Great idea if there was the capacity, but there isn't anymore. If we were still in the 1980's, well, you might of stood a chance.
Ianno87
3 May 2015
If you could at least get a couple of 700s an hour shuttling between the EWR connection and Peterborough.
Steve Harris
11 Dec 2016
ECML
Indeed. However, that would need switches installing at the new station when it's built (Which is the point I was trying to make).
Btw during the Biggleswade disruption they did eventually have 1tph shuttling between St Neots and Peterborough.
A0wen
19 Jan 2008
Hopefully EWR will be a diversionary route
Except to do so means adding junctions and leaving spare paths "just in case". Far better not to and allow disrupted passengers to use EWR services to cross between lines as necessary.
There are precisely no benefits to creating "diversionary" routes.
