Could Class 43s haul carriages other than mk3s?
m79900
28 May 2023
North Derbyshire
If a heritage railway wanted to run a HST, but didn’t have the space for a rake of mk3s, could mk1/2 carriages be formed between them?
23 Nov 2015
Yes, but there would be no heating and the rear power car wouldn’t be powering. An HST power car can couple to any coach provided it has buckeye couplers and is air braked.
renegademaster
22 Jun 2023
Croydon
They haul freight so I don't see why not. You might need a generator car for the carriages but heritage trains usually do
sprinterguy
4 Mar 2010
Macclesfield
From a mechanical perspective, yes they could, as witnessed by the Colas operated test trains of recent times.
They wouldn't be able to provide auxiliary power to the carriages though.
That's using a pair of buffer fitted power cars as essentially a conventional locomotive, though, rather than forming up a train between separate power cars.
They can't provide braking to vacuum braked stock without some sort of translation.
GC class B1
19 Jun 2021
East midlands
HST power cars can couple to buckeye fitted vehicles. All Mk1 and Mk2 vehicles have buckeye couplers. A single HST power car can operate the brakes on air braked vehicles but to operate in pairs with the coaches between the two power cars requires the coaches to be fitted with 36 way control cables to control the trailing power car.
43096
23 Nov 2015
And the only translator you could use would be a dual-braked 73 as they have buckeye couplers.
randyrippley
21 Feb 2016
I read somewhere years ago that only a 73/0 can act as a air/vacuum brake translator, not a 73/1
73119 and 73136 in GBRf's fleet are dual braked and can act as translators. The other GBRf 73s only have air brakes enabled.
23 Nov 2015
That’s not the case, a 73/1 is just as good. Are you thinking of the ability to heat on diesel?
Thinking about what I said about a 73, would a 33/1 be able to brake translate as they have buckeyes too. And going hypothetical, would a 74 have worked?
randyrippley
21 Feb 2016
No, the article was quite specific: it said that only the 73/0 could work as an air/vacuum translator. Made no comment about air or vacuum / EPB, though that presumably works with the bagpipes
It was discussing the machines "as built", obviously later mods may have changed things
23 Nov 2015
I am surprised at this suggestion. I thought MLV were ep braked with auto air for failsafe operation in an emergency.
MLVs had vacuum brakes to allow them to haul parcels stock (BG, GUV etc).
JKF
29 May 2019
I expect for a certain type of enthusiast, having a dead power car on the rear for extra weight would be quite desirable.
43096
23 Nov 2015
The preserved set at the Midland Railway Butterley has been operated in such a fashion, with use of the power cut out switch on one power car.
It doesn’t have to be a dead power car on the back, either. 41001 was run at the Mid-Norfolk with two idling Class 50s on the back. Now that was very enjoyable!
GC class B1
19 Jun 2021
East midlands
I don’t think the power car would be shut down as it may not be possible to release the brakes without the engine running. The trailing power car would be idling and not taking power. The E70 type brake wouldn’t operate as designed either but the trailing power car brakes would operate as a normal air braked vehicle.
HSTs can operate with a power car entirely dead (other than batteries). It happened on the Great Western quite a lot, with resulting delays over the bank into Plymouth.
43096
23 Nov 2015
How do you think dead power cars are hauled then? How do you think a set with a power car with a failed engine keeps going?
GC class B1
19 Jun 2021
East midlands
I am referring to the situation where the trailing power car doesn’t have a control signal because the intermediate vehicles are not fitted with 36 way control cables. An HST set will have a control signal to the rear power car which will energise the rear power car E70 brake controller and allow the brakes to be released. This will not be the case with non 36 way cable fitted intermediate vehicles.
36270k
7 Jan 2015
Trimley
In the BR era ( 1970/80 ) HST's running on 1 power car were common when the Paxman engines had overheating problems. Was on several where it was a slow climb up from Stroud to Sapperton summit.
D365
29 Jun 2012
If I've interpreted the electrical schematics correctly... this is a function of the 'Isolate' input of the E70 BCU (brake control unit)?
GC class B1
19 Jun 2021
East midlands
That sounds right. Does the trailing power car E70 BCU still vent the brake pipe when an Emergency brake is initiated in this situation?
Please refer to my post number 21 and @D365 post number 23 for the explanation of a failed power car in an HST set. I don’t know how a dead single power car is hauled but there may be an AFT (assisting failed train) air cock to operate to allow the brake pipe to be charged or some method of isolating the applicable brake pipe venting valve. These should only be operated in the instance of a failed train and not in passenger service.
23 Nov 2015
You are presumably unaware that trains have operated in passenger service for many years with one of the E70 (or same functionality DW2 and DW3) BPCUs isolated?
The E70/DW2/DW3 are not just used on HST power cars, but also at least (IIRC) Class 56, Class 90 and Class 91 locomotives and Mark 3 and Mark 4 DVTs. Two BPCUs are only needed for speeds over 110mph, so on West Coast and Anglia Class 90+DVT formations normally had the rear BPCU isolated for reliability reasons. If the TDM de-configured then the rear BPCU would lose its signal and so initiate a brake application.
BPCU - Brakepipe Pressure Control Unit
Irascible
21 Apr 2020
Dyfneint
Does someone have a schematic of the brakes to hand? I did but don't currently. Does the PC not ( effectively ) monitor the control brake pipe pressure as well as EP signal?
Nym
2 Mar 2007
Somewhere, not in London
Except on the Colas ones which have been converted to be compatible with the 27 way through wiring on the Network Rail Infrastructure Monitoring fleet.
The E70 is power to release, so you'd also be pneumatically isolating it with the BCU Isolation Cock. You're then procedurally limited to a lower speed which seems to be whatever the flavour of the month is.
Similar situation on the Mk.4s at full length.
Or just isolate the E70 and run as "AFT" Assisting Failed Train.
DelW
15 Jan 2015
Just a passing mention that the West Somerset is operating an HST in passenger service today (although not using mk1 or mk2 coaches).
Great Western have agreed that the WSR will be able to run one of the trains on the 23rd and 24th September, in normal WSR passenger service.
On both days the train will make two return runs from Minehead to Bishops Lydeard. The “yellow” time table will be in operation, which means that the HST will leave Minehead at 1000 and 1430, and Bishops Lydeard at 1230 and 1635.
43096
23 Nov 2015
As the Colas power cars see use on the NMT, it is unlikely the power cars have been modified. More likely is the jumper cable adapts between the HST 36-way and the 27-way on the stock. There’s plenty of spare wires in the 36-way; it’s a case of mapping the wires across.
