ASharpe
Does anyone know if any progress is being made with widening Cow Lane bridge just west of Reading station?
It seems to have been one delay after another.
There were two bridges, one on each curve, hasn't one been done now?
The one on the west curve was replaced during the Reading rebuild. The one remaining is the one that goes under the Reading - Didcot main line.
The original main and relief lines crossed the very narrow brick arch bridge that remains (the most restrictive of all the old Cow Lane structures). The new reliefs appear to have moved north a little and joined the new passenger reversible, with depot tracks and roads, on a new structure which already has a second wider parallel road level opening currently unused. The mains have been been moved south onto the new high level flyover, and another separate flyover, at a slightly lower level, carries the new Festival line. It looks like the old arch bridge carries no working track today so can be removed and the remaining cutting widened with little rail traffic disruption, although the work would be very close to the adjacent down relief, which might have to close through parts of the work. There is also more effort involved in widening and realigning the road on both sides, and making the promised cycle and pedestrian route improvements.
Attached image is looking south from north (Rivermead) side
Cow Lane Bridge (road)works are scheduled for completion next August.
When the work is completed the road underneath will be a two-lane carriageway with headroom meeting the UK Standard Minimum Clearance (i.e. 16' 6" or 5.03m, or higher). I am pretty sure this will require lowering of the carriageway, creating a dip, so flood alleviation measures may also be needed. There will be a separate cycle and pedestrian lane.
