Xenophon PCDGS
Day 1 of 4th Test Match saw England recover from being 57-3, then 112-5, to be 302-7 at close of play. Root 106 not out.
And almost a pair of ‘golden ducks’. He was out second ball in the first innings.Day 3 in progress of the Test Match and India were eventually all out for 307.
Not a good start in the England 2nd innings, as in his third over, Ashwin dismissed both Duckett and Pope in successive balls. A pair of ducks is Pope's memory in this match.
Last 7 wickets went for 35 runs. India definite favourites now, with England throwing away a good chance of winning this Test!England were all out for a miserly 145, leaving India to get 192 and go 3-1 up.
Ahswin took 5-51 and Kuldeep 4-22.
And Jimmy's, unless he can make significant amends tomorrow.A pair of ducks is Pope's memory in this match.
I suppose that Jimmy is not there to make runs, but to take wickets. Is the bowling of Pope up to Test Match standard?And Jimmy's, unless he can make significant amends tomorrow.
If we do, you can be sure that the Indian fielders will gratefully accept them, as has regularly happened in this series.Hoping we give a few chances in the last test.
I'd agree, except Robinson, even if you are suggesting he should play as a batsman. His bowling was pathetically bad, by all accounts, and the catch he dropped might have made the difference to the game's result. Combine this with his performances on the last tour to Australia and it seems to me he's far from an ideal tourist even when he manages to keep his potty mouth in check. No, Anderson or Wood should play in his stead.Hoping we give a few chances in the last test. We know there will be 2 Pacers with Ahmed and Leach gone, so I'm hoping for:
Crawley, Duckett, Pope, Root, Lawrence, Stokes, Foakes, Hartley, Robinson, Atkinson, Bashir
I don't necessarily think Bairstow should be dropped but I want Lawrence to get a chance.
Well, about 530 of those England caps came from just four players (Anderson, Root, Stokes, Bairstow)!How can Stokes call the England team inexperienced?
The England team had 668 caps between them @ the start of the game, the Indians 294, it's been like this throughout the series.
So maybe the oldies are the ones that need to be held to account.
Agree about Robinson, he's played a number of tests - including this last one - where it is said that his pace is down. Perhaps telling that Stokes didn't bowl him in India's second innings.I'd agree, except Robinson, even if you are suggesting he should play as a batsman. His bowling was pathetically bad, by all accounts, and the catch he dropped might have made the difference to the game's result. Combine this with his performances on the last tour to Australia and it seems to me he's far from an ideal tourist even when he manages to keep his potty mouth in check. No, Anderson or Wood should play in his stead.
Well, you posed the question and having a spare few minutes I've worked out that the answer is 54 (34 of these in India)Exactly, and of the other 140 or so, how many have been earned on the subcontinent before this series?
.....with a day to spare...India won by 5 wickets, making it 3-1 with 1 to play.,
Did he decide that discretion was the better part of valour, noting his ailments. as no Stokes arm was turned over in the Indian second innings.I'll go with Stokes turning his right arm over competitively for the first time in what seems like years now.
Wellington 1st Test New Zealand V Australia
At the end of the 2nd day Australia have a very healthy lead of 217 runs with 8 wickets remaining.
Oz 383 all out with Cameron Green being 174 not out and 13-2 (Smithy out 3rd ball for a duck) he got 31@ the 1st attempt.
Black Caps 179 all out top scorer was Glenn Philips with 71, Nathan Lyons took 4-43.
Can't see this one going the full distance.
