theageofthetra
- Joined
- 27 May 2012
- Messages
- 3,512
That's a blame device, not a safety device.
Correct. Would have done nothing to prevent this tragedy.
A new system to keep tram drivers "vigilant" is already being trialled and should be installed on all trams soon, Transport for London has revealed.
An update issued today by the Rail Accident Investigation Branch (RAIB) on its investigation into the fatal tram derailment at Sandilands Junction last year said tram operators should consider installing such systems.
The Advertiser reported in June that TfL had opened a tender process for companies to design a new driver vigilance system and an automatic speed monitoring device, which could automatically slow speeding trams.
At the moment, the trams rely on a so-called 'dead man's handle', which drivers must keep their hand on and is supposed to apply the brakes should the driver let go of the handle for more than a few seconds.
But it has been reported that drivers used to be able to either disable the handle, or that they were not functioning correctly.
The RAIB said the driver of the tram involved in the fatal crash "lost awareness" before the derailment.
This new system, which TfL says should be installed by the autumn, can detect "any sign" that the driver is distracted or fatigue and provide an alert.
A separate system for automatically managing tram speed on certain parts of the network is also being developed.
The DVD could be incorporated within the AVSM or provided on its own and it must generate a vigilance alert and inform the driver if no driver activity is detected for a time period.
It would then brake if the driver does not respond to the alert within a time period - different to the DSD which only activates if pressure if taken off the controls for a specific time period.
The warnings for both systems would have to be audible and visible to drivers and the control centre, where trams in service are monitored, would be notified in real time.
The only other trams in the country which have a similar device are the 2014 fleet of Birmingham trams, which were bought new with the vigilance device.
It doesn't matter what the DVD does, or how it works, if the operator doesn't maintain it. There seems to be a culture of neglect at Tramlink, as well as a culture of blame and an apparent schism between management and front-line staff resulting in mutual distrust.
I'm not sure how you solve such a situation, but steamrollering a new device through without consultation isn't the way, nor is ignoring the fact that safety devices were not treated as essential requirements (trams allowed out with defective DVDs for example).
It doesn't matter how fantastic any new vigilance device is, if staff aren't involved and consulted on the implementation and if management don't address the underlying issues behind why so many drivers seem to suffer from fatigue while at the controls, then the risk of another incident is there.
Will that device likely be the same or at least work on the same principle as the vigilance device on heavy rail trains?
So still no back pedalling from yourself and your previous post I see then. Amazed how someone from west Yorkshire seems to know so much about the inner workings of tramlink and can form such an opinion even after they have been proven wrong in their opinion about this device.
And nor should he back pedal. The fitted device is unlikely to prevent another Sandilands incident, as it is NOT linked to the braking system. .
I'm of the opinion that many of the industrial disputes are ideologically driven by a deeply anti-union government hell-bent on "cutting costs". Other opinions may vary.
That statement is rather biased. Phrases like "anti-union" and "hell-bent" are unhelpful to a balanced discussion, and rather inflammatory.
Did you not read the article that is at the top of this page then where it specifically states
so it IS to be linked to the braking system
No I can 100% assure you , regardless of links or what others say etc, this system does NOT link to the braking system. It sounds an alarm, takes a picture and shakes the seat. There are other proposed system which do link to the braking system, but this is not one of them.
Genuinely? Takes a picture and shakes the seat?!
Shaking the seat might well be effective, but taking a picture? I can't see that as anything other than gathering evidence against the driver.
That's not to say that drivers should be allowed to doze off at the controls: but if it happens, something else has gone wrong further up the chain of events.
It sounds decidedly comedic. Intercontinental trains running at 186mph manage to do without 'vibrators' being installed under the Driver's backside, I'd be gobsmacked if it was a serious proposal on a tram! As for taking a picture, as if just to ensure that there is rope enough to hang the accused, just no!
You are aware that those trains are fitted with a vast array of safety systems and are controlled by signalling and thus isn't really comparable to a tram.
I am, yes. And some of that technology should quite obviously have been deployed, in a much simplified form, here. Even an LUL style tripcock system would be effective, combined with a stop signal prior to the infamous curve. Bargain basement(ish), but far more effective than shaking a seat, which frankly is a ridiculous idea.
What is the purpose of taking a photograph of the alleged sleepy offender? So that they can all be instantly sacked? And, considering that a driver can evidently continue to operate the 'dead mans' whilst asleep, what protection does the 'vibrator' offer against a driver who is incapacitated? Or a driver who is distracted and fails to recognise their location and the need to brake?
I agree.
This does seem a very bizarre solution, if it can even be called a solution. I can well see why the union isn't happy about what has been proposed based on the last few posts.
Surely a better system would be some form of TPWS style overspeed loops at key locations. These would ensure that if a tram was approaching too quickly for whatever reason: driver inattentiveness; driver error; driver incapacitation, the brakes would come on.
Excessive speed caused this accident. Overspeed loops would prevent this root cause. This system only purports to deal with one scenario that could result in excessive speed.
I'm sure overspeed loops have been considered and dismissed due to costs. Far better to make a pretence at implementing an improvement which, lo and behold, hangs the driver out to dry without actually meaningfully improving safety.
Would a driver be instantly sacked for falling asleep? Obviously nobody would do so intentionally?
I guess tramlink had to be seen to be doing something to reassure the public and this is it? Of course it could also be used to protect a driver if false allegations were made.
I would imagine so.
On the big railway (I assume tramlink is similar) drivers are required to "book on" before every shift. By booking on you are stating you are well rested, fit and well for duty, therefore the onus is placed on the driver.
The difficulty with this is that fatigue is a natural aspect of extreme shift cycles and if you refused to book on every time you felt tired you'd probably refuse half of your shifts.
It's a very difficult one, as you say someone does not fall asleep intentionally. Obviously drivers need to take responsibility to ensure they are fit for duty but there also needs to be:
1. Efforts to ensure shift patterns don't cause excessive fatigue;
2. Technology to ensure the risk of accidents is kept to a minimum of all else fails.
On any railway a vehicle with a defective DVD would be immediately out of service and on the underground, and I would be surprised if not the same on the main line, a second member of staff must ride with the driver.
Key recommendation areas addressed to UK tram operators, are likely to be:
In addition, the RAIBs investigation into how Tram Operations Ltd manage fatigue risk may result in a recommendation.
- provision of active tram protection to prevent serious accidents due to excessive speed at high risk locations
- research into active means of detecting the attention state of drivers and intervening in the event of inattention
- improved containment of passengers by tram windows and doors
- setting up of an industry body to facilitate more effective cooperation between UK tramway owners and operators on matters related to safety performance and the development of common standards
Our final report will also highlight the importance of ensuring the availability of in-tram CCTV systems and any actions already taken to address the issue. If necessary, the RAIB will also make a recommendation for further improvement in this area.
This list is not exhaustive, but includes some of the important safety issues that are likely to take time to implement, making early consideration vital. Other areas within the scope of our investigation, such as consideration of underlying safety management and regulatory factors, will also give rise to recommendations.
We are encouraged to learn that some tramway organisations have already started work in a number of these areas.
Point 2 mentions "research into active means of detecting the attention state of drivers and intervening in the event of inattention" (my emphasis), so it's rather a dead man's handle than a camera.I suppose that point 2 covers the driver-facing CCTV that is being installed in Croydon
