NorthKent1989
- Joined
- 13 May 2017
- Messages
- 1,972
There are no substantial changes to SE we’re still stuck with Decembers 2022’s useless changeIs there a link to the timetable change on the southeastern website
Surely the problem was that practical training couldn’t take place as it required two people to be together in a confined space for a purpose that wasn’t immediately necessary.
That sort of thing was extremely subjective tho, ie what clearly worked for GA wouldn't necessarily have worked for TPE. Just the geographical locations of traincrew depots, the training centre(s), simulators, staff locations etc would have a major impact. Route learning for TPE might rely heavily on riding Northern/LNER services which would then make them interdependent on another TOCs policies etc.As has been said several times, Greater Anglia led the way on this. With cooperation from ASLEF driver courses and in cab training in ‘bubbles’ were started within a month or two and continued throughout the pandemic.
Apologies if already mentioned. Looks line Teesside Airport is re-gaining its weekly parliamentary service in the December 2023 timetable. https://www.realtimetrains.co.uk/service/gb-nr:W32450/2024-02-11/detailed
The DFT and government are ultimately to blame in my opinion even if there have been private sector failings. They granted the franchise in the first place. They are responsible for all the current arrangements, and now the OLR runs the thing anyway.Well clearly someone messed up at TPE. We're told that a lot of the issues are around staffing levels and training, so why weren't these resolved during the covid restrictions when fewer people were travelling. It seems to me that this would have been the perfect time to upskill crews on the new units and start to recruit and train new staff to replace those that were coming to the ends of their careers. But instead of having all the crews and units available (subject to the dispute being resolved), TP are cutting back services and mothballing perfectly good trains. The DfT need to get their fingers out that's for sure, but they are far from alone in the blame.
2 expresses per hour Leeds to Manchester even 6 car just won’t be able to cope, they’ll all be full and standing throughout. Imagine a Saturday when there is a match on at either Leeds or HuddersfieldI am very sad to see the TPE massacre of their north route timetable. Taken from a little earlier in the thread, the pathetic 2024 off peak hourly service is apparently:
For historical comparison, I've attached extracts of the standard off peak patterns in the May 2007 and May 2016 timetables to illustrate just how far backwards they are taking things.
- Newcastle – Liverpool Lime Street
- Scarborough – York
- Saltburn – Manchester Airport
- Hull – Manchester Piccadilly calling all stations Leeds to Huddersfield
- Manchester Piccadilly – Huddersfield stopper
These are from the September 91 to May 92 timetable between Manchester and Huddersfield (and Wakefield/Leeds).And in regards to your extracts of old timetables, I think 4 fast trains per hour with some calls at either Dewsbury or Stalybridge had been the pattern since at least Northern Spirit days if not during Regional Railways
While this is obviously a given and Calder Valley services will be equally unable to cope, I do hope that the through stoppers Piccadilly - Leeds and Piccadilly - Castleford - York when they run will be able to abstract some through passengers to at least make some dent in the level of overcrowding.2 expresses per hour Leeds to Manchester even 6 car just won’t be able to cope, they’ll all be full and standing throughout.
Did this coincide with the Manchester VictoriaThese are from the September 91 to May 92 timetable between Manchester and Huddersfield (and Wakefield/Leeds).
If it works out the way it did when the stoppers previously ran through Huddersfield, then they'll fall behind their timings and the fasts will start tripping over them. I don't think running them through is a good idea at all.While this is obviously a given and Calder Valley services will be equally unable to cope, I do hope that the through stoppers Piccadilly - Leeds and Piccadilly - Castleford - York when they run will be able to abstract some through passengers to at least make some dent in the level of overcrowding.
The usual pattern was 3 fast between Manchester Piccadilly/Leeds & vv with a Wakefield to Manchester Victoria 'stopper'.
The fast ones would've been a Liverpool-Scarborough and (eventually) 2 Manchester Airport-Middlesbrough/Newcastles
If it's as detailed above the stoppers aren't running through, the Hull - Manc Picc will stop all station to Huddersfield then fast to Picc with the Manc Picc - Huddersfield stopper running as now. The Hull service should only be about 15 minutes slower so all this "two expresses Leeds- Manc" is a bit misleading, it's two fast and one semi-fast in reality.If it works out the way it did when the stoppers previously ran through Huddersfield, then they'll fall behind their timings and the fasts will start tripping over them. I don't think running them through is a good idea at all.
It was actually the reverse. The expresses were held up around Manchester or a Leeds, and ran late. This caused the stoppers to run late, which then knocked the express behind and so on.If it works out the way it did when the stoppers previously ran through Huddersfield, then they'll fall behind their timings and the fasts will start tripping over them. I don't think running them through is a good idea at all.
The stoppers are full and standing at peak times. Unless they are all run as 6 carriages, abstraction of through passengers will simply move the overcrowding around.I do hope that the through stoppers Piccadilly - Leeds and Piccadilly - Castleford - York when they run will be able to abstract some through passengers to at least make some dent in the level of overcrowding.
I agree that running stoppers through Huddersfield has impacted on punctuality in the past (as has running them west of Manchester, from Southport, Blackpool North and Llandudno in the 30 plus years I have been using the route).If it works out the way it did when the stoppers previously ran through Huddersfield, then they'll fall behind their timings and the fasts will start tripping over them. I don't think running them through is a good idea at all.
You say that, but if a customer is waiting at Leeds and see a Manchester service calling at Cottingley, Morley, Batley, Dewsbury, Ravensthorpe, Mirfield, Deighton… they’ll see it as a stopperIf it's as detailed above the stoppers aren't running through, the Hull - Manc Picc will stop all station to Huddersfield then fast to Picc with the Manc Picc - Huddersfield stopper running as now. The Hull service should only be about 15 minutes slower so all this "two expresses Leeds- Manc" is a bit misleading, it's two fast and one semi-fast in reality.
Not quite, it was the following each hour;
Scarborough/Newcastle-Liverpool (alternating)
Middlesbrough-Manchester Piccadilly (later Airport)
Hull-Manchester Piccadilly
On the hours the Newcastle leg ran, the Blackpool-York semi-fast service was extended to Scarborough. Later on some of the Newcastles were extended to/from Sunderland.
Sell the cheap advance tickets for the semi fast service and the passengers will not care.You say that, but if a customer is waiting at Leeds and see a Manchester service calling at Cottingley, Morley, Batley, Dewsbury, Ravensthorpe, Mirfield, Deighton… they’ll see it as a stopper
I’m not sure the folks of Hull will be happy having their service to Manchester calling all shacks either
That will then result in the Northern Calder valley service, which is often 3 car also being full and standing
Trust me it wasn't always. When TPE ran to Liverpool via Warrington I used these all the times, and more often than not they would run out of Leeds on time only to trip over the stoppers west of Huddersfield.It was actually the reverse. The expresses were held up around Manchester or a Leeds, and ran late. This caused the stoppers to run late, which then knocked the express behind and so on.
Crew changes in Huddersfield didn't help those matters either.
There's a major recast of the North Downs. Fingers crossed it does happen.Where is GWR? Are they the last to upload? I didnt think there was to be major changes anyways.
I'm talking about when Northern ran stoppers from Leeds to Wigan NW via Huddersfield. And we used to catch those up all the time leading to arriving into the throat at Piccadilly very late and having to wait for a gap in Castlefield. It happened enough for it to stick deep in my memory.When TPE started operating the stoppers that was in May 2018, the same timetable change that saw TPE withdraw from the Warrington Central route. So if your Liverpool via Warrington Central train was delayed by a stopper, it wasn't a TPE through stopper from Leeds.
However, that has to fit around SWR and GTR which both already have their times loaded.There's a major recast of the North Downs.
They’re one of 4 operators not to upload yetAre they the last to upload?
Quite. I know "the railway" loves to say "no", however I can also see paths at all the major junctions and interchanges en route that can work. The key is, can the start-to-finish timings be kept under 3 hours?However, that has to fit around SWR and GTR which both already have their times loaded.
