Derailment near Carlisle - 19/10/2022 - 1715 Clitheroe Castle Cement Gb to Carlisle N.Y. (6C00)
doningtonphil
18 Aug 2014
From the images I've seen it would appear that one or more of the wheelsets have severe flats. This would indicate the wagon handbrakes were left on on the affected wagons.
Which images are they? Do any photos show the Brake Distributor on the vehicle with the flats?
No it doesn’t. Similar comments were made on the thread during the oil train derailment in Wales the other year and it turned out to be a fault with the wagon.
Yes, the fault was that the brakes were being applied by an insufficiently attached Distributor
I think that line runs very close to houses. In the south Wales RAIB report reference was made to the fact a local noticed the passing train sounding different (you must get so used to trains passingvthat you spot an anomally), which along with CCTV images, some from private addresses, helped build up a pretty good picture of the brakes being applied/wheels locking
Chris M
4 Feb 2012
London E14
Well that's quick for RAIB by current day standards so suggests they have quickly identified root cause and the engineers can get on with rebuilding the damage infrastructure.
No, it just means they've identified the immediate cause and have taken all the photographs and measurements from the site they need to before the vehicles are moved. Based on previous reports, if they need photos of the after-restoration state they'll most likely just ask Network Rail to take them or can arrange a site visit at a convenient time (which may be months away) if needs be.
As noted above, the wagons they are interested in, which will be at least the first one to derail, will be moved off-site where they can do all the testing they need in a secure, safe location that doesn't disrupt the railway.
Nicholas Lewis
9 Aug 2019
Fair point the condition of the vehicles need to be ascertained as well to see both sides of the wheel/rail interface but that can be done off site so good that it will allow recovery to get under way quickly and hopefully restoration within a week.
Anvil1984
28 Aug 2010
I forget how many Heaton units do the Cumbrian Coast these days, as that was always Newton Heath for a long time. But I didn't think it was more than 3 or 4 that stayed that side overnight, the ones which do the early Scotrails to Dumfries?
Could be out of date knowledge mind.
Since at least Mays timetable change Northern and Scotrail no longer exchange staff nor units.
The reason for the reduced service on the Newcastle - Carlisle line is probably (just speculating) a mixture of units being the Carlisle side of the blockage, the additional time of taxiing Carlisle crews to / from Wetheral at start / end of shifts, then crews only having break / toilet facilities at one end of the line (unless taxied to Carlisle which is additional time again) and finally either Single Line / Pilotman working between Corby Gates signalbox and Wetheral station (no signal to return off East off the westbound platform). This is alongside Northern not really having that many spare crews at present. It was probably chaos for whoever was resourcing the service
DanNCL
17 Jul 2017
County Durham
Looking at RTT, it seems one 156 (156.475) from Newcastle, and a pair of 158s from Leeds were the only units temporarily "stuck" at Carlisle at the time of the derailment.
Edit. 156.475 plus another 156 heading south on 20:00 Carlisle - Whitehaven on 20 Oct. according to RTT.
All Cumbrian Coast diagrams are now booked Heaton units; Newton Heath allocated 156s no longer have booked work north of Preston. Booked to be 9 Heaton 156s on the Cumbrian Coast, and 1 on the Morecambe branch. Assuming all diagrams were Heaton units as booked, it's 11 of Heaton's 156 allocation 'stuck' with the unit from the Tyne Valley there too.
To avoid issues on the Cumbrian Coast if this closure lasts more than a few days they’ll either have to rework the diagrams to cycle units through Newton Heath for exams, or get the likes of ROG in to move units back to the ‘correct’ side either via Lancaster or Scotland. 195s being the booked traction for the Barrow - Manchester trips won’t help matters as units can’t just be tagged on the back of those to get to Manchester for exams.
Through running to/from Dumfries ended at the May 2022 timetable change.
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
These are relatively modern wagons, they have TF25 bogies, which have a handbrake interlock, meaning if a HB is left on then brake pipe pressure can't be created.
Given the time of year, wheel flats are common, although severe ones should be picked up on examinations.
They may have a handbrake interlock, but none that I ever dealt with did.
Pat
M60lad
31 May 2011
It won't be unusual for a Heaton Unit to end up at Newton Heath for an Exam as I think it was earlier this year that 156480 spent some time at Newton Heath having work done not to sure whether it worked back from Manchester in service though.
2192
16 Aug 2020
Derby UK
Were the wagons loaded or empty? If loaded they will need to be emptied before lifting, which took time after the Sheffield derailment.
Neptune
29 May 2018
On the log that the 156’s will be cycled for exams at alternate locations where necessary, they will be fuelled at Barrow and the 158’s will be sent down to Yorkshire via an appropriate route with the possibility of 3rd party drivers used.
Bikeman78
26 Apr 2018
I’m fairly sure if it’s desperate then they can run some units to Newton Heath for an exam.
Agreed. Heaton units aren't particularly rare around Manchester. There were booked diagrams a few years ago when Manchester to Blackpool was booked for 156s. Conversely Newton Heath units sometimes go up the Cumbrian coast.
ejstubbs
19 May 2016
There's no need to be snooty, it's really not important to understanding the incident.
Sorry, I wasn't trying to be snooty - and I note that Ken H picked up on the use of the word even quicker than I did - but when I read that "carriages" have left the track my brain can't help starting to think of passengers potentially being injured, until it realises that it's actually a case of an unfortunate choice of word. Thankfully in this instance no-one seems to have been injured.
I am more than a little surprised that NR used the term "carriages", although I note that the media report linked above by ac6000cw has now been amended to read: "Network Rail is working with multiple agencies to find out how wagons carrying cement came off the track over the River Petteril shortly after 8pm last night (Wednesday 19 October)." The wording of the BBC article has also been amended since I pasted it in to this thread, with references to "carriages" changed to "wagons".
So I don't think I'm alone in finding the error unsettling.
(I also note that, although examples have been provided of different terms being used for passenger-carrying vehicles, no-one has admitted to calling wagons "carriages" as a matter of course.)
Dr_Paul
3 Sep 2013
Yes, there are some good illustrations of a false flange here. I was puzzled by the reference, but now I know what it is. The wheel tread is ground down and effectively gets another flange on the outside, so the profile is U-shaped. The havoc this caused in the South Wales incident when false-flanged wheels encountered points is also well illustrated.
43055
8 Mar 2018
The planned engineering works on the east coast will no longer take place and LNER will run as normal via the ECML.
LNER Services between Edinburgh and Newcastle – Saturday 22 October
Due to a freight train derailment in the Carlisle area on Wednesday 19 October, the line between Newcastle and Carlisle is closed. LNER service were planned to operate using the diversionary route via Carlisle (extending journey times by approximately 90 minutes), however, this is now not possible. Planned Engineering works between Newcastle and Edinburgh on the East Coast Mainline has been cancelled and LNER services will now run the usual East Coast Mainline route between Edinburgh and Newcastle. This will significantly reduce expected journey times between Newcastle and Edinburgh in both directions. Please note, this will not be reflected in our live journey planners due to the short notice change. LNER Customers are advised to travel on their booked train.
  • Customers travelling from Edinburgh towards Newcastle will arrive approximately 90 minutes earlier than planned. Customers are advised to remain on board the train for Stations towards London Kings Cross.
  • Customers travelling north towards Scotland towards Newcastle will arrive approximately 90 minutes earlier than planned.
  • Customers travelling towards Aberdeen and Inverness will arrive approximately 90 minutes earlier than planned at Edinburgh and are advised to either wait 90 minutes for their booked departure towards Aberdeen and Inverness, or use ScotRail services to complete their journey.
43096
23 Nov 2015
Got to love the railway: they have no problem with cancelling services in the system the night before as that doesn’t count for performance stats and compensation (ie they can use it to screw the punters), but somehow can’t for this. What’s the betting it’ll be used to penalise “booked train only” customers who are on the wrong train as a result?
Dave W
27 Sep 2019
North London
Does this raise the prospect of a Sprinter (albeit ECS) down the WCML between Carlisle and Carnforth? That can't happen too often can it?
DanNCL
17 Jul 2017
County Durham
Under the (weekday) May 2022 diagrams Heaton units shouldn’t work any further south than Preston. Previously the Barrow - Manchester service was a way to cycle them through Newton Heath if needed, but not now that’s booked 195s. Diagrams will have had to be reworked to accommodate it. I was about to say I was surprised they’d made the effort, then remembered this isn’t TPE :lol:
It isn’t completely unheard of for Newton Heath units to end up in the North East but it isn’t common either.
The 158s are largely cycled via the normal diagrams through Yorkshire anyway so I can’t see that being an issue, it’s just any unit(s) that were at Carlisle station that’ll need other plans, I struggle to see how with Petteril Bridge closed a 158 could be moved from Carlisle without a 3rd party driver, but that’s assuming there were any 158s in Carlisle in the first place!
I wonder if XC will also alter their plans for this weekend as a result or if they’ll continue with their planned RRBs.
I remember back in the days of 142s that every so often a Merseyrail interior Pacer would end up doing circuits around the North East for a week or so. Always a grim time. Thankfully the worst that Newton Heath can send us now is 156s :lol:
GC class B1
19 Jun 2021
East midlands
The RAIB report into the Derailment of the tanker train and subsequent fire at Llangennech didn’t conclusively determine the cause of the brake drag that locked the one wheelset and resulted in the massive wheel flats and false flange. See https://assets.publishing.service.g...a/file/1054063/R012022_220113_Llangennech.pdf ,clause 68.
The brake relay mounting fault was probably the cause of excessive brake block wear and dragging brakes on the wagon, but was not conclusively confirmed by RAIB to have caused the affected wheelset to lock. A significantly greater brake force will be required to lock a wheelset than the (much smaller) force that will cause a dragging brake.
Purple Train
16 Jul 2022
Darkest Commuterland
You're definitely not alone - I emailed the BBC to complain about it for exactly the same reasons you outlined in the first paragraph. It's a misuse of basic terminology that can give a misleading impression, which is why I view it as important that it is used correctly.
Pedantic it may be, but "snooty" is going a bit far.
Anyway, back on topic, is there any rough estimate as to when the line will reopen?
800001
24 Oct 2015
Until everything is removed and they can assess the damage I don’t think there will be a timescale.
Reports that the bridge is severely damaged
Bristol
The bit I was specifically referring to as snooty was this:
Does anyone who isn't an utter ignoramus call freight wagons "carriages"?
For which the poster has apologised.
Basic the terminology may be, but, 'utter ignoramus' is harsh. Do you make the specific distinction between train (a set of connected vehicles), and service (the specific schedule to which a train is aiming to operate)?
Crossover
4 Jun 2009
It’s been mentioned up thread that there were 2 x 158’s stranded. They’ll have been the pair to form 2H81.
2H99 surely?
My bet would be on 158793 and 158904 being stuck in Carlisle.
They arrived on 2H94 1648 Leeds to Carlisle - https://www.realtimetrains.co.uk/service/gb-nr:G90232/2022-10-19/detailed#allox_id=0 - this passed Petteril Bridge Junction at 19:28
2H99 was due to depart Carlisle at 20:13 (which was cancelled from Carlisle and restarted at Appleby around 80L).
The freight derailment happened between the arrival of 2H94 and departure of 2H99
