Differences in rolling stock safety regulations in mainland Europe compared to UK
rvdborgt
24 Feb 2022
Leuven
European countries seem to tolerate graffiti much more, with windows often being completely covered in tags in Belgium, Germany and Italy. I'm glad that these are generally removed from service in the UK
You can't generally speak about "European countries" here. It varies a lot between operators. In Switzerland or the Netherlands for example, you won't see a lot of graffiti.
Richard Scott
13 Dec 2018
With regard to doors, it's worth noting that if the UK had adopted the RIC style folding door with its twofold safety features, blocking of the inside handle above 5km/h and autocloser, many "falling out of doors" deaths would have been avoided (and droplights would have gone away much sooner too, so quite a few people would still have had their heads attached). So it's not the UK that's always ahead on safety.
If Europe had adopted buckeye couplings instead of screw there would likely be many more Europeans still alive that wouldn't have been killed by concertina coaches in accidents. I can't believe that some Italian high speed trains are screw coupled and TGV power car are screwcoupled to coaches.
This is a much bigger issue than droplights; how many people have been killed through droplights? Remember still plenty of stock with droplights in Europe.
DanielB
27 Feb 2020
Amersfoort, NL
In the Netherlands it is often already hard to see the actual livery of a train through all the dirt on the outside, so that obscures any graffity as well ;)
Especially the case for NS, where even transparent windows are getting rare, the regional operators have much cleaner trains.
Any revised stock in the Netherlands is now being liveried using coloured foils, so graffity is easier removed as it involves replacing a bit of foil in the worst case (avoiding the need to use agressive cleaners which may permanently damage the paint)
68s are screw coupled to coaches here, too, as were most locos in the Mk2/3 days. Screw coupling between coaches has been abandoned in the UK, though.
They have a larger loading gauge - you would have to lean a LONG way out to whack your head.
43096
23 Nov 2015
It's a question: what was the last screw-coupled (between passenger carrying vehicles) service train to run? First thought was the last first generation DMUs. For loco-hauled coaching stock it would be much longer ago, as all Mark 1/2/3 mainline stock has drophead buckeyes.
DanielB
27 Feb 2020
Amersfoort, NL
Show me just one single Dutch VIRM that hasn't been tagged over the windscreen...
That doesn't necessarily show it happens often: it just takes a long time to be removed.
When I'm not mistaken this is due to the location of these tags. They cannot be removed at sidings as cleaners would need to work too close to the live OHLE to do that.
10 Feb 2019
Spent a week travelling around Romania, all I can say is take care around the doors, trains depart with them open, some close (due to TB0) but others don't. One instance on an iR from Galtai towards Bucharest a door flew open at 120kmh and train crew were trying to shut it, eventually it was bound shut with a bit of curtain. In Germany we are certainly stricter in this regard.
Bikeman78
26 Apr 2018
This is true. I remember the plan V units were filthy in their last few years. They used to be bright yellow 20 years ago.
