asylumxl
Personally I don't think DMU's should be on such long distance trains, the uncomfortablel seats and engine vibration is annoying.
They're DEMUs.
Why are DEMUs not considered to be a type of DMU? DMU stands for Diesel Multiple Unit and this makes no reference to the transmission. DHMU/DMMU/DHMMU are rarely used and it seems acceptable to call all of these Diesel Multiple Units but for some reason you can't call a DEMU a type of Diesel Multiple Unit.They're DEMUs.
I agree, if it's a multiple unit, and it runs on diesel, it's a DMU. However most diesel multiple units have traditionally tended to have mechanical transmission (DMMU), so when people hear of 'DMU' they tend to assume mechanical transmission, though hydraulic transmission seems to be making a comeback (e.g. Class 185). Very rarely are the abbreviations 'DMMU' or 'DHMU' used.A DMU is a DMU, no matter how you doll it up.
As far as I can see the majority of people/companies use the term DMU to mean a diesel mechanical multiple unit rather than a DEMU. This can be seen on this very forum, in company brochures and many other places.
If we are going to be so very pedantic, perhaps everyone should attempt to be more accurate and concise, I mean afterall, I could call you a "thing", which while technically accurate, isn't very concise is it?
They're DEMUs.
Well, I did say traditionally!Really? I'd always naturally assumed the opposite and that most DMUs had hydraulic transmission.
Pot/Kettle:roll:
Just saying...
I think the Voyagers should be in a category of their own, as they are not true DEMU's such as the old Southern 205 & 207 DEMU trains, as the Voyagers cannot pick up power from the third rail tracks when they are working in the Southern Region and cannot use the OHL when running further north.
I made this mistake till I learnt too, I thought 205s and 207s could pick up juice hence the category DEMU. They dont actually have the ability to pick up power from the 3rd rail.
Yes, and then what would be about Class 210 (as-built)? HST 253-5 as well? IIRC when a MU can run off external electric and internal diesel traction it is know as an EDMU - see IEP.
The 210s never had external power collection though, either 3rd rail or overheads did they?
It's my understanding that the crankshaft of a Voyager engine goes into a gearbox from which a cardan shaft takes the drive to the powered axles via a differential.
As far as I'm aware the power is taken from the engine to a generator which is then used to power electric motors which drive the axles. Hence diesel electric.
But on a Voyager, I'm certain I've seen a prop shaft (or cardan shaft) rotating beneath the bodywork.
...Personally I don't think DMU's should be on such long distance trains, the uncomfortablel seats and engine vibration is annoying...
I'm sure you have but it'll be between the engine and the generators or quite probably the motor and the axles.
From some of the comments on here, you'd imagine it was like sitting on a washing machine doing a fast spin!Engine vibration is something that gets mentioned a lot too, but I don't know how many normal passengers really notice this.
Dont knock it until you have tried it.
my other half tells me its quite "interesting".
Probably the most fun she gets between you and her trips on a Voyager .
Oye we will have less.
Unlike my other half!
Maybe thats why she goes a bit cross eyed when we go to Yorkshire on the train?
