Do tube trains ever suffer from wheelslip?
Railperf
30 Oct 2017
I've been on Central line stock that suffered wheelslide coming into Debden southbound. The train seemed to stop short of the platform end initially and it wasn't clear whether the ATO system or driver then took it forward to the correct stopping position.
Lewlew
15 Oct 2019
Would have been the driver. ATO will only ever restart between stations when stopped at a red signal/block marker board
Railperf
30 Oct 2017
I've also sampled Central line running where the driver (manually driving) slightly overshot the stopping mark (not due to wheelslide) and had to manually release the doors to open.
Towers
30 Aug 2021
I always understood that wheelslip was any form of the wheels losing grip - be it under either acceleration or under braking.
Wheelspin then refers to loss of grip under acceleration as the wheels spin faster than the speed at which the train is actually moving.
Wheelslide then refers to loss of grip under braking, where the wheels lock-up and the train effectively slides along the rails.
Is it actually possible for train wheels to slip, as opposed to slide, under braking? As in to still be turning but without gripping the railhead? I would have thought not, but I'm no scientist!
hexagon789
2 Sep 2016
A slip can be an act of unintentional sliding - so I think so, yes.
100andthirty
Milton Keynes
When there's poor adhesion in braking the wheels start slipping and if nothing is done, will stop and the wheels will slide. The point if wheelside protection (WSP) is to keep the wheels turning unless the adhesion is terrible. It makes the most of whatever adhesion is available, although stopping distance will be extended. Adding sand tends to improve adhesion, so sanding is triggered by the WSP to help stopping performance.
Towers
30 Aug 2021
Indeed, but of course the "start slipping" is presumably the wheel repeatedly locking momentarily - it isn't rotating against the railhead, as it would if slipping when under acceleration - the forces are of course the wrong way around for that! E.g. a train may "slip to a stand", when failing to gain traction under acceleration, but would "slide past a signal" etc when under braking.
I'm being pedantic here I realise, but seeing as it was brought up, I would contest that "slip" is essentially wheelspin, and therefore an acceleration issue, while "slide" is a deceleration thing?
I am growing a beard and perfecting my nasal tones as I type.... :D
100andthirty
Milton Keynes
No, the wheel doesn't lock momentarily. There is significant potential energy in a rotating wheelset, especially if it's connected though a gearbox to a motor. Thus, a braked wheel on low adhesion takes time to stop rotating (i.e. lock) giving tome for the WSP to do its job. "Repeated momentary locking" might have been observed with primitive WSP, but not with modern systems or unless the adhesion is really bad - eg a coefficient of friction in the 0.01-0.02 range.
