In the 'age of steam' there were fewer trains and more track. Big data doesn't change that.The railway did it in the age of steam and can do it again with big data.
Walk down a train and seeing how many seats are reserved and how many not.
And you are quite happy to make it inconvenient to travel between Norwich and Leicester or Birmingham, which is probably what many customers would prefer.
In the London-Birmingham/Manchester examples increased capacity, whether at increased frequency or not, was a response to higher demand.
I know that you didn't intend for these to be consequences of your ideas, but the reality is that they will be inevitable unintended consequences from taking such a radically different approach, as has been explained several times in different ways now.In many instances the balancing working won't be needed either and a whole round trip could be saved. With good yield management it might then be possible to employ those resources more lucratively elsewhere.
I have never suggested that intermediate stations should be closed. Flighting the fast services would release more track capacity between the flights and this can be used to improve services at intermediate stations.
And I haven't suggested that long distance services should be reservation only either. But in the last 20 years the balance between turn up ang go and reservation in advance has shifted, and the way the railway operates should adapt to that.
And I haven't said that either. Turn up and go fares would still be available. But turn up and go is now a smaller proportion of the long distance market than it used to be, and no longer should be the driving factor in timetable design for long distance services.
How far ahead do you decide if the xx03 and xx06 will run so need the crew? How would you usefully use the crew if the xx03 and xx06 are not required? Or would you just have then on-call?
The complexity involved in trying to do this though for our current rail network would be enormous, even without the need to provide frequent and regular service to local passengers, which there very much is.It is a different way of thinking, put trains on sale 12 weeks ahead, if threshold of busyness is reached say 2-3 weeks ahead, activate the relief and train crew, don’t leave it until last minute.
But it gives options from ticket data which can be crunched quickly in computer era, main train might call at 6 stations, but relief can skip some as demand to/from them is low. Might not even need to run full route (handy if it is quicker to get stock to an intermediate station).
But if you use the data properly should be able to see common connections, so although historically might have run trains from A to B, might show every third train should really continue to C instead.
I've planned relief paths in from Euston to Manchester and Liverpool for FA Cup finals and the like, and I can tell you it's a massively inefficient use of capacity, drivers hours and train planner time. Unadvertised reliefs in for 90 minutes, with Q paths in for extra time/penalties. Have to clear out Euston platforms for twice as long as necessary, sort out balancing moves, etc. It's also no more or less flexible than any other schedule. The departure time is the time the train it goes, regardless of how many minutes of injury time are played.It would be a mix. To begin with, most would probably need to be timetabled and advertised, to maintain public confidence about capacity. But to get the full gains of flexibility, at least some capacity would need to be unadvertised, with what used to be called Q paths in the working timetable.
Fewer passenger trains yes, but a lot more freight.In the 'age of steam' there were fewer trains and more track.
But it could be Norwich-Birmingham and Stansted-Liverpool instead. Do Norwich people have a more desperate need and therefore greater priority than the people of Cambridge for a train to Liverpool? Norwich-Liverpool and Cambridge-Birmingham were a choice made 30 years ago to facilitate splitting the network into franchises, that's all.In this particular case, rather than a Norwich/Leicester and Birmingham direct service, there is instead a Stansted Airport and Cambridge/Leicester and Birmingham service; Do the people of Norwich have a more desperate need and therefore greater priority than the people of Cambridge for a train to Birmingham?
With big data it will be possible to forecast reasonably accurately what demand will be some days in advance. Supermarkets do it all the time. did your local supermarket run out of beer and pizza before yesterday's match? And the railway has the advantage over the supermarket that it can vary its prices more easily to manage demand.In the case of Manchester/Euston, that would only work if it is known before the outward Q train is planned to run how many passengers there will be for the return Q train, ie several hours earlier. Therefore unworkable.
That is always a risk with a radically different approach, and it is a risk that would need to be managed. Thameslink 2018 is a good example of that. It would have to be tried on one route first to learn lessons before rolling out more widely. But where the railway is now radical thinking is needed.I know that you didn't intend for these to be consequences of your ideas, but the reality is that they will be inevitable unintended consequences from taking such a radically different approach
Which could quite easily be shoved out of the way in a siding or yard somewhere to make room.Fewer passenger trains yes, but a lot more freight.
Something which I have suggested would make more sense in the past is very similar to this, Norwich - Birmingham New Street and Stansted Airport - Nottingham. The only genuine downside is the loss of Cambridge - Birmingham direct services.But it could be Norwich-Birmingham and Stansted-Liverpool instead. Do Norwich people have a more desperate need and therefore greater priority than the people of Cambridge for a train to Liverpool? Norwich-Liverpool and Cambridge-Birmingham were a choice made 30 years ago to facilitate splitting the network into franchises, that's all.
But a lot of long distance services are already at full length. And a half-hourly service (or every 20 minutes) is a good way of generating (valuable) walk-up/flexible fares.Bizarrely, for long distance journeys it would look a bit like the days of steam. Any route where the tickets sold are primarily booked in advance should be running the longest trains possible, with lower frequencies.
Even on the busiest long distance routes, there's no need for anything more frequently than hourly if nearly everyone is boking in advance. If demand exceeds the capacity of one full length train, then run two or three in a flight. In the olden days they were called reliefs.
This thread is absolutely astonishing. I thought I’d seen it all on these forums. Every day is a school day!
However, the paths will need to be in the timetable from very far out (6 months presently), and Drivers are normally given their rosters more than a week in advance. If you decide not to run the trains, you will also need to give the train planning and diagramming teams time to cancel out the paths and amend the ECS moves to ensure stock is balanced for the next workings. And get them into all of the systems.With big data it will be possible to forecast reasonably accurately what demand will be some days in advance.
First you say the railway should run paths to match demand, now you say the railway should manage demand according to available capacity! If its fine to manage capacity for relief trains, why is it totally unacceptable to manage capacity for clock face trains?And the railway has the advantage over the supermarket that it can vary its prices more easily to manage demand.
What I've said is that there are opportunities to manage supply and demand together by building in some flexibility to direct supply to where demand is highest. The relief train, if it runs, is the extra capacity for the clock face train. But, as others have said, it is important to manage demand too, so that relief trains aren't running with a handful of passengers. Sometimes it will be better to have higher fares and one train, sometimes it will be better to have two trains, and that might need lower fares to fill both. But best will be the times when two trains can be filled with high fares.First you say the railway should run paths to match demand, now you say the railway should manage demand according to available capacity! If its fine to manage capacity for relief trains, why is it totally unacceptable to manage capacity for clock face trains?
I'm aware of these. Q paths can be in the timetable 6 months out. The railway already has processes for dealing with short term train planning. A good forecasting model with all that data should be able to forecast demand two weeks before, to give the time needed to the train planning and diagramming teams.However, the paths will need to be in the timetable from very far out (6 months presently), and Drivers are normally given their rosters more than a week in advance. If you decide not to run the trains, you will also need to give the train planning and diagramming teams time to cancel out the paths and amend the ECS moves to ensure stock is balanced for the next workings. And get them into all of the systems.
That isn't how the process works though, unless you are suggesting we offer the STP timetable 2 weeks out (freight still bid at 18 weeks). That was barely acceptable during COVID, let alone as a day to day thing. Those Q paths also eat up capacity at the terminal stations and major junctions, which with your solution here cannot be released for another operator to make use of at those timescales.I'm aware of these. Q paths can be in the timetable 6 months out. The railway already has processes for dealing with short term train planning. A good forecasting model with all that data should be able to forecast demand two weeks before, to give the time needed to the train planning and diagramming teams.
Thanks, you have expressed it more eloquently than I did.I do actually have some sympathy with what the OP I believe is trying to say - that in principle the railway should be more demand-led and less supply led. Unfortunately the responses show that the way capacity planning, pricing, timetabling and rosters etc work in the industry at the moment make this virtually impossible. The supply side is largely fixed - M-F, Sat and Sun timetables with very little seasonal variation, and some peak extras, with yield maximised through variable AP pricing on longer distance flows around slightly more flexible peak/off peak and seasons on shorter distance ones. Rail demand (other than perhaps by enthusiasts) is derived demand - people travel in order to do something else - go to work, visit friends, go the football etc - and that demand will vary significantly on any given day but is potentially forecastable to some extent.
And the responses do leave me with the strong impression that the railway is only interested in people travelling when it wants to run trains. That worked for 30 years in a virtuous cycle of increased capacity and increased demand, the new capacity mostly lots of shiny new trains and shiny new infrastructure. But we aren't in that world any more, for the foreseeable future the railway is going to need to be relentlessly concentrating on better deploying its limited existing resources.'should the railway do better deploying its limited resources by running trains when and where people want them, rather than relying quite as much on pricing to encourage people to travel when the railway wants to run trains?'
I'm still just struggling to see why you would want to reduce headline frequencies in an attempt to 'improve' the railway. As I and several others have said, having a spread of departures makes it more likely there'll be a train that fits someone's plans. Surely this proposal is therefore the exact opposite of what the railway needs to attract increased custom?!And the responses do leave me with the strong impression that the railway is only interested in people travelling when it wants to run trains. That worked for 30 years in a virtuous cycle of increased capacity and increased demand, the new capacity mostly lots of shiny new trains and shiny new infrastructure. But we aren't in that world any more, for the foreseeable future the railway is going to need to be relentlessly concentrating on better deploying its limited existing resources.
My reading is that the OP is seeking to 'improve' the railway by reducing costs, by potentially having some effectively 'planned cancellations' at quieter times of the day/week/year. Clearly, any reduction in costs would need to offset any loss in revenue arising from the reduced opportunities to travel at those times/on those days.I'm still just struggling to see why you would want to reduce headline frequencies in an attempt to 'improve' the railway.
Actually, I'm more interested in driving up revenue by using resources more flexibly.My reading is that the OP is seeking to 'improve' the railway by reducing costs, by potentially having some effectively 'planned cancellations' at quieter times of the day/week/year. Clearly, any reduction in costs would need to offset any loss in revenue arising from the reduced opportunities to travel at those times/on those days.
And here's an example of what can be done.more of what GWR have traditionally done during Cheltenham Race week whereby they cancel some Paddington-Cardiff services (well in advance) to provide extra capacity on the Cheltenham route, rather than purely rely on raising fares to dissuade people from travelling by train to Cheltenham
For most of the last 60 years the internet and the smartphone did not exist. The world has changed. Unless the service is every 5 minutes, most people no longer turn up and go, they check on the internet before they set out.All the railway experience of the last 60 years has shown us that frequency is king, turn up and go is king.
The only way you can increase revenue would be by having people make journeys that they would otherwise not have made. Your idea does not do this - if anything it causes people to use their cars/alternative transport because there are fewer trips in the timetable, making the railway less convenient.Actually, I'm more interested in driving up revenue by using resources more flexibly.
Yes it does. The people who are in their cars/alternative transport now get seats on a train instead. And there are more winners than losers.The only way you can increase revenue would be by having people make journeys that they would otherwise not have made. Your idea does not do this - if anything it causes people to use their cars/alternative transport because there are fewer trips in the timetable, making the railway less convenient.
The passenger does not need to know how many trains. All they need to know is whether there are seats available and how much they cost.What that means then is, to take the example again, of Euston/Manchester; Instead of there being in theory three trains guaranteed to run, at xx00, xx20 and xx40 minutes past each hour, there would be just one at xx00. There might be a relief at xx03, or maybe not if insufficient people have booked for it; There might be another relief at xx06, but again, there might not. How on earth is such a haphazard offering expected to attract passengers?
That already happens now. With supply management it would happen to fewer people.If it looks like too many people are booking for the xx00 train, but not enough to justify the xx03 first relief, would fares would be increased to dissuade any more from travelling (no matter how important their journeys are to them)?
In yield management adjustment of fares is a continuous process.And as I asked before, but did not see an answer, what is the cut off point for closing bookings/increasing fares, bearing in mind that booking in advance does not just mean weeks or days ahead, but hours, minutes, and even when a train is already en route, with as you pointed out the facilities of the internet and smartphones.
Don't delude yourself that people are travelling when they want to now. Unless they get in quick most are making suboptimal decisions based on what is still available. With supply management more people will be able to make their journeys closer to their optimal time.On the contrary, reducing the timetable so that instead of a choice of 3 trains spread over an hour, passengers have only an hourly service is the very definition of the railway only running trains when it wants people to travel!
Indeed.That is not my experience at all, but perhaps I am simply not down with the kids.
There are very, very few people who are choosing to drive because the train might be full. They drive because the train is too expensive, or because it's more convenient. Your idea might help with the former but at the cost of the latter. Changing an every 20 minute service into a an hourly one is going to put a lot more people off than will be attracted by the fact that they're guaranteed* a seat.Yes it does. The people who are in their cars/alternative transport now get seats on a train instead. And there are more winners than losers.
