DynamicSpirit
First off, I'll admit to a bias: I've never liked the idea of 400m trains (that is, two 200 trainsets coupled together). I understand the need for capacity, but the railway also needs to be reasonably passenger-friendly and accessible, and to my mind, expecting people to walk 400m down a platform to find their seat is pushing those bounds too far.
But now that London-Birmingham/Handsacre is the only part of HS2 being built, it seems to me there's no longer any significant justification for 400m trains: Rather, we should be building a uniform fleet of 250m-ish trains, without any expectation that they will ever be coupled in normal service.
- The vast majority of HS2 trains will spend most of their time on the classical network. They therefore need maximum capacity within the limits of the existing WCML. That presumably means making them about the same length as an 11-car Pendolino: 265 m, NOT 200m. So, too long to be coupled in normal use.
- 400 m trains will now only be able to run Euston-Birmingham, nowhere else. It makes no operational sense to have a separate micro-fleet that can only be used on that one route.
- Building for only 250m will mean you can shorten the platforms at Euston, reducing the expense of building the new station there. Since Euston represented a massively disproportionate part of the expense of HS2, that's significant (or maybe the money saved would pay for passive provision for an extra platform or two in case they are ever needed?).
- Since London-Birmingham will now carry far fewer trains than the line is specced for, capacity is not an issue (other than maybe at Euston), so having more frequent, rather than longer, trains on the London-Birmingham route should now be a possible option. Even Euston shouldn't be that much of a constraint: The 6 platforms ought to easily be able to take 12tph, and HS2 will now be replacing only 9 Avanti trains (10 if you count the proposed 2nd Liverpool one). Also with the reduced number of trains, it's doubtful that all 6 platforms at OOC will be needed, so you now have some additional capacity for running a few additional trains that terminate there, so it looks to me like 14tph should be doable on the infrastructure that's now being proposed: Easily enough to adequately serve Birmingham and other WCML destinations without 400 m trains.
