Double-heading and Banking
Inversnecky
1 Jan 2021
Can someone please explain to me about the technicalities of this. How does the driver ensure both locos are going at the same speed?
Presumably the second engine is controlled by the driver: but are the two linked so number two mirrors the speed or revs of the first? Or does each loco have its own driver?
What about variations in power, where settings are thought to be the same, yet one loco is outputting slightly more/less power than the other?
Thinking of banking, potentially you could have a rear loco pushing more than the front one is pulling, possibly causing a derailment.
Since this doesn’t happen, I’d appreciate hearing from those who knows how it all works in practice.
StephenHunter
22 Jul 2017
With locomotives in multiple working set up, the first locomotive controls the second.
DelW
15 Jan 2015
In the US, freight trains may have one or more unmanned locos mid-train and/or on the rear, controlled by radio signals from the leading cab. These may be up to about 3 miles from the controlling loco.
In steam days of course every loco had its own crew, with communication between them only by whistle signals.
Taunton
1 Aug 2013
Double heading etc - quite simply it's the couplings that, like the rest of the train, keep it all together. Any variances of power are well handled inside that. If under multiple control and one loco, or the other, shuts down, there's just less power applied to the train. The USA have always been past masters at this, just applying as many locos to the front as the load requires. As locos have got larger there the old times of six, possibly even more, on the front have disappeared, but three or four of the latest and largest is still pretty much the norm.
Banking, unattached, at the rear is a bit different, but basically the banker just applies full power. There will be a neutral point in the train where vehicles behind have couplings in compression from the loco at the back pushing, and those ahead have couplings in pull from the loco at the front. This all adapts naturally as power and gradients etc vary - if in the train you may notice little shocks up and down.
Steve Harris
11 Dec 2016
ECML
The physical couplings between loco's along with both loco's working in multiple (an electrical connection system which sends the electrical control singnaĺ from the first loco to the second loco so the same amout of power is applied by each loco at the same time) sorts this out.
Yes if both loco's are in Multiple (see answer above).
If loco's are of different classes and can't work in multiple then each loco will have a driver, this is called working in Tandom.
43096
23 Nov 2015
The only time I've been on a train being banked has been out of Liege in Belgium. Here the process is that the train arrives and the banker then drops out of the holding sidings and buffers up to the rear. On receiving the 'RA' the driver of the train engine releases the brakes and the banking loco applies power to move the train: it's only when up to about 20km/h or so that the train engine applies power.
Whistler40145
30 Apr 2010
Lancashire
I've never been on a train where banking locos are required
I do remember that pairs of Class 37s would be on standby at Bromsgrove to bank heavy freight and the occasional heavy passenger train up The Lickey Incline, one train in the 80s was a Fridays Only Relief from Plymouth to Manchester Piccadilly that was booked for a loco change at Gloucester, a pair of Class 20s were booked to work forward and was booked for banking from Bromsgrove
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
I have had the Lickey banker class 37 on the Bristol to Glasgow sleeper over 30 years ago. Also had a Class 25 over Copy Pit on a Merrymaker in the 1970s. If anyone is interested I am more than happy to post the dates and numbers.
themiller
4 Dec 2011
Cumbria, UK
A rear loco pushing more than the front occurs when the front power car on an HST shuts down. Nothing bad happens.
For freight, Eurotunnel trains are designed so that in the event of one loco shutting down, the other can still power the train out of the tunnel and into the terminal. This gives a stiff gradient and tight curves on a long train.
jopsuk
13 May 2008
Locos pushing trains with no loco on the front at all has been a successful thing for a long time, and serious derailments involving them have only happened when there's been something heavy on the line or the rails have broken
Irascible
21 Apr 2020
Dyfneint
Although the risks are different depending on the type of coupler - knuckles or similar binding couplers can resist lateral & vertical force ( which is one reason buckeyes were introduced for passenger stock quite a long time ago ) whereas buffers ( especially with the couplers being actual loose chains - screw couplings at least limit travel a little ) do nothing to stop overrides & consequent locking.
Push-pull trains have been around an awful long time, the risks are well known. The US cut traction into the centre of trains because they might start pulling couplers apart if they stuck them all at the front.
I wonder how many broken couplings there've been on unfitted 3-link trains when the banker has dropped off a bit abruptly. Given the loose cut would roll back on the banker it would have at least kept them alert!
Cheshire Scot
24 Jul 2020
North East Cheshire
....and Beattock.
Railscot photo of diesel being banked by steam! https://www.railscot.co.uk/img/75/486/
Latterly it was a pair of class 20s crewed on three shifts by Carstairs giving 24 hour cover after Beattock shed had closed. I always assumed they ran light to/from Carstairs three times per day for shift change which would leave three windows each of one hour plus without bankers present - does anyone know if this was how it was worked in practice?
On trains departing Glasgow Queen St the practice was (as noted above) for the banker to start the train and quickly get to full power and the train engine then kicked in. Effectively in unscientific terms the train engine had the train weight on the drawbar and the banker had no weight behind it so (in theory) the banker should never get left behind. In earlier years they operated a form of slip coupling controlled from the banking loco (C15 tank engines) which obviously required the buffers to be compressed and the coupling slack. When this practice ended it meant any loco could bank as they were no longer coupled to the train.
Blair Atholl had a loco shed and trains used to be banked up Druimuachdar - I think they dropped back at Dalnaspidal where the gradient eased and there was a signal box and crossover, and Aviemore provided bankers to Slochd. I could be wrong but I think they also banked out of Forres towards Dava.
As noted by '43096' above, most loco hauled passenger trains out of Liege towards Brussels used to be banked, I can't remember the gradient but I think something like 1 in 38 or 1 in 40, and with the clear glass panels in the gangway connection one could look out from the rear coach and watch the banker - normally but not always electric - start the train and then nearing the top of the gradient drop back. On my most 'recent' visit back in 2010 when push pull operation with Driving Trailers had come in it was no longer possible to get the rear view but banking was still being practiced at least twice per standard hour. Some trains towards Aachen were also banked but this seemed to be less regular, presumably the gradient was less severe. I also recall being banked out of Aachen towards Liege, an interesting scenario of a Belgian crew on SNCB electric loco and German crew on a DB diesel (the voltage change being in Aachen station).
23 Nov 2015
Banking is much rarer out of Liege now, unfortunately. Back in around 2011, there was a period around mid-day when three trains in the hour were banked in the autumn, necessitating three locos. As one of them came with a fresh crew from Kinkempois shed, it could be anything. I was fortunate enough to have a Type 77 diesel on more than one occasion, rather than the normal Type 23 electric at the time.
6Gman
1 May 2012
I've long thought that, given the thousands of railway books published (many of them repetitive), a thorough study of banking on Britain's railways would be a worthwhile book.
Unless - of course - one exists!
Cowley
15 Apr 2016
Devon
I’ve also been banked up the Lickey by a pair of 37s (059 and 133 I think), we drew to a halt and they ran out of the siding behind us but didn’t couple up, then all three locos gave it the beans (47517 up front on 16 coaches) and as we eventually went over the top and started to accelerate away the 37s dropped off and presumably slowed to a stop before crossing over and running back down the bank ready for the next turn.
I’ve linked this clip before but it’s an absolute classic. Some quite enthusiastic crew members in the cab. :lol:
Whisky Papa
8 Aug 2019
Miles Platting bank out of Manchester Victoria. Prior to the station being rebuilt, there was usually a station pilot / banker sat in one of the through roads. This was normally a Class 25 when I was spotting in the mid 1970s, which we saw deployed to assist eastbound freights fairly regularly. In later years, when I was occasionally passing through Victoria on family visits, I recall seeing a Class 60 in this role, which must have been fairly soon after they were introduced.
supervc-10
4 Mar 2012
And of course many other trains are push-pull with DVTs, such as IC225s or the assorted electric locos with DVTs on the WCML before the Pendolinos took over.
