I got a Class 93 here that wants to talk with you about that statement.anything short of almost full electrification won't be much help for freight...
The class 93 (and class 99) are amazing innovations, but isn't the battery mostly intended to cover the last bit in goods yards, not to cover relatively long stretches without OHLE, simply because there isn't enough space for batteries?I got a Class 93 here that wants to talk with you about that statement.
That, and to assist the diesel engine for peak power. The Class 93 is 1,200hp on diesel and 1,700hp with battery assistance. I'm sure that's plenty enough to handle the short tank trains up to Aberdeen Waterloo.The class 93 (and class 99) are amazing innovations, but isn't the battery mostly intended to cover the last bit in goods yards, not to cover relatively long stretches without OHLE, simply because there isn't enough space for batteries?
Back then maybe so but now? Seems rather short sighted to install a small amount of OLE at the Tweedbank terminus and not bother with (most of) the rest of the line or have I mis-read the current proposal?but ultimately the correct one.
The long term plan is to fully wire the line; they jsut start with partial wiring to allow new trains to come in ASAPBack then maybe so but now? Seems rather short sighted to install a small amount of OLE at the Tweedbank terminus and not bother with (most of) the rest of the line or have I mis-read the current proposal?
But you are still deferring expenditure from today until tomorrow. The wiring will either be done or need doing eventually. Should be done properly the 1st time, learn lessons from the ECML wiring, cheap at installation but with higher ongoing maintenance costs.Yes the correct decision now. It would have cost about an extra £70m to wire up the line at the then prevailing cheapest electrification rates. That assumes no new feeder station.
Partial electrification now will cost a small fraction of that, and even allowing for the extra cost of battery trains over straight EMUs, we get electric trains for much less cash.
But still needs blocks to achieve what little is being done. At least make the blocks worthwhile. Something NR are extremely poor at.Why? It’s saved the taxpayer a load of cash.
No, you're absolutely not deferring expenditure from today until tomorrow. Once you've electrified enough of a line to introduce battery trains, you move on to partially electrify another line, and get more quickly the benefits of removing diesel.But you are still deferring expenditure from today until tomorrow. The wiring will either be done or need doing eventually. Should be done properly the 1st time, learn lessons from the ECML wiring, cheap at installation but with higher ongoing maintenance costs.
That assumes that your only factor is cash. In reality, it’s much more complicated than that - environment, workforce availability etc.Why? It’s saved the taxpayer a load of cash.
Unless the plans have very recently changed transport Scotland is absolutely planning to fully wire up the borders railwayThat’s not right. It is not incurring expenditure at all. The line won’t be fully electrified.
I thought they had only committed to mostly wiring it.Unless the plans have very recently changed transport Scotland is absolutely planning to fully wire up the borders railway
The [Strathbungo] Society has had the following communication from Network Rail:
Following successful demolition of the Nithsdale Road bridge deck, I wanted to update you on some aspects of the project taking place within the Strathbungo area.
Columns
During one of our previous discussions with the Strathbungo Society, the four columns under the road bridge were discussed, and how these could possibly be saved and re-utilised. We weren’t able to confirm the condition of the columns until the bridge deck demolition was carried out. Now that has been done, I can confirm that we were able to retain the columns in good condition.
We’ve had some interest from Caledonian Railway, but we are keen to establish if there is an appetite within the Strathbungo community to re-use these locally. [...]
Footbridge
As you will be aware, last spring we carried out a public vote for the design of the new footbridge between Moray Place and Darnley Road. Three artist impressions of bridge designs were given to the community, based on construction drawings of the bridge built at Aristotle Lane in Oxford. The vast majority of residents voted for Bridge A.
The chosen bridge was taken forward through a detailed design process. We also took on board feedback around concerns raised about certain specific aspects of the bridge. As part of the detailed design phase, the designs were adjusted accordingly to address these comments and concerns.
BRIDGE A DETAILED VISUALS
I’ve included detailed visuals of the bridge below, which include a few enhancements to the original images:
Height of top chord (curve) – the 3D visual showed parapets at a significant height (+2.3m). This did not meet the aspirations of a simple, modest structure and the designers were asked to reduce the height to 1.8m (the parapet height standard over electrified lines).
Colour – the structure is black and white to reflect the colours used in the current footbridge. It was previously shown as all grey.
Stair units – only the lower part of the stair unit is to be clad in stone. The balustrades are now open steelwork and will match the railings found at Moray Place in profile and colour (black).
The entrance to either end of the bridge has been fanned out to address concerns of some residents for a more open approach to improve visibility for users.
The designs will now be submitted to the council planning team for Prior Approval. At the same time, we are submitting a listed building application for the removal of the existing C-listed footbridge.
wasn't the strategy to do partial first, and then fill in the gaps later on? That's how I read the decarbonisation strategy. Though I guess "we'll do it later" isn't the most confidence-inspiring sentenceI thought they had only committed to mostly wiring it.
They won’t.
Depends how long-term you're speaking about, but I expect that the trains being purchased now will be capable of several (tens of) miles operation off the wires and will remain in service into the late 2030s.Some degree of battery-only capability seems inevitable for future EMU fleets, but I don't see them carrying around enough batteries to get from Shawfair to Bowshank. At most they'd be able to power themselves across the Forth or Tay bridges, or through Kinghorn tunnel.
Would be my best guess tooDepends how long-term you're speaking about, but I expect that the trains being purchased now will be capable of several (tens of) miles operation off the wires and will remain in service into the late 2030s.
That would be an unusually short lifetime - the trains that are soon to be ordered are for delivery between 2027-30 and will be a mixture of EMUs and BEMUs (in what proportion we don't yet know). EMUs are often considered to have a lifetime up to 40 years.Depends how long-term you're speaking about, but I expect that the trains being purchased now will be capable of several (tens of) miles operation off the wires and will remain in service into the late 2030s.
I meant to write the late 2050s! But maybe that was a little too short as well.That would be an unusually short lifetime - the trains that are soon to be ordered are for delivery between 2027-30 and will be a mixture of EMUs and BEMUs (in what proportion we don't yet know). EMUs are often considered to have a lifetime up to 40 years.
The batteries might require replacement before the train does though, and that will inevitably lead to the question as to whether we will still actually need the batteries, even though the units would hopefully last till 2060 at leastI meant to write the late 2050s! But maybe that was a little too short as well.
Hah, that whole thread used to be in this forum until it was derailed by speculation.Decarbonisation of Scotland’s Railways
The Scottish Government has published its Infrastructure Plan for the next 5 years. It states that £550 million will be spent on rail decarbonisation over the period. It also states that £200 million will be invested in the Aberdeen- Central Belt line. A total of £1.2 billion will be spent on...www.railforums.co.uk
Surely almost all the recent posts in this thread belong here?
BEMU's already in fleet service in Europe have ranges off the wires of typically 80km to 160km. See for instance the Flirt AKKU, which claims 150 km range in battery mode and 15 min charging time under catenary: https://www.stadlerrail.com/en/flirt-akku/details/I don't see them carrying around enough batteries to get from Shawfair to Bowshank. At most they'd be able to power themselves across the Forth or Tay bridges, or through Kinghorn tunnel.
Not quite. There have been two threads with similar titles. The one linked by InOban ("Decarbonisation of Scotland's Railways") was a short-lived thread from Feb 2021 and is still in "Infrastructure and Stations" but is now closed. I have no idea why it was closed.Hah, that whole thread used to be in this forum until it was derailed by speculation.
Given Scotrail have decide BEMUS have a place in the fleet they shouldn't have bothered with East Kilbride just used BEMUs for Barrhead its stepping stone to going further South so that makes sense.BEMU's already in fleet service in Europe have ranges off the wires of typically 80km to 160km. See for instance the Flirt AKKU, which claims 150 km range in battery mode and 15 min charging time under catenary: https://www.stadlerrail.com/en/flirt-akku/details/
EDIT: which to me makes them perfect now for East Kilbride / Barrhead services until the lines are electrified, when they could be cascaded to other routes.
