Interesting posts above about the concrete shell units and the steel tubes used for lining pile holes. I think I saw the large steel tubes being used at the piling for replacement piers at the Bletchley viaduct site.
Yesterday I had an informative conversation with an engineer just outside the Water Eaton worksite. A large yellow crane was on site and unloading long precast concrete beams from road trucks. A wall of concrete shell units has been erected on the west side of the tracks, part of the new box unit. This side is complete asides from sill beams and waterproofing, and work on the east side, in a more confined area, should start today (23 March). When the other wall is complete, some of the concrete beams will be placed across and the electric cables will be clipped to the undersides. The steel overhead line gantries will then be removed and the rest of the beams placed in position. The Twitter post linked above shows that the wall is curved, but this is not evident from a distance. The wall can be seen above the white fence in the attached photo (taken on 20th Mar)
Shell units will also be used to build three or so replacement piers.
I also found some pictures via the Twitter link a few posts above, showing what is happening at Pier 30 and Pier 17. This work is entirely invisible from outside the site. I wondered what was going on atop the embankment by the Buckingham Road. You may need to scroll down a bit.
https://twitter.com/LittleHKiwi
