Here's a recording
Good to see the BBC are into recycling, some of the prerecorded bits of that report turned up on this evening’s South Today.
Here's a recording
Argh, that was infuriating to watch in places. The person from CPRE who complained that the railway was "going through pristine countryside" - well it's going between Bedford and Cambridge, short of building on top of the A421 and A428 you can't avoid that. The person who emailed in to say they've looked at the Cambridge timetable and think they can make a northern approach work with two tracks - good to know, you should apply to NR to be a planner.
I don't know why EWR are being blamed for not having sufficiently good answers on housing development plans for the next 30 years.How is that their remit?
I did like the person from Dry Drayton who didn't want a northern route. A perfect demonstration that no matter where you put a railway, some people are going to experience disruption.
East West might not be, but NR are looking at it.East West Rail are not currently proposing a chord at Bletchley to enable trains from the East to continue North on the West Coast Mainline. Only trains from the West, including Oxford, Aylesbury and possibly freight trains from Southampton, will be able to go to Milton Keynes and continue North on the West Coast Mainline. Freight trains from Felixstowe to South Wales would be able to use East West Rail but the Network Rail study states "Note that all trains between Ipswich and Bristol/South Wales would remain on the Great Eastern and through London."
Really? It has been reiterated constantly in this forum that an east/north chord at Bletchley is unworkable.East West might not be, but NR are looking at it.
Indeed, it would bring a massive amount of flexibility. Having extra diversionary routes also makes my job as a controller a lot easier.East West might not be, but NR are looking at it.
I'm not sure that anyone is say E-N chord at Bletchley is unworkable, just that it is expensive and may not turn out to be very useful (Cambs-MKC passenger trains notwithstanding). Such a chord could be useful for frieght, but it would presumably be hard to justify on that basis alone.
From the freight point of view it duplicates the north connection at Nuneaton, in that it allows freight from the east to head north on the WCML. As far as I know that curve has had very little use. It would also allow a MK-Bedford passenger service, but based on the options in the consultation that would probably be a case of the same number of services, but some terminating at MK instead of Bletchley. This would probably result in whatever Marston Vale stations remained, other than Ridgmont and Woburn Sands, losing service to Bletchley.The likely main issues are:
-Quite significant amount of land-take requiredto build it
-If you did build it, whether there is enough capacity on the Slows between Bletchley and MK to be able to make meaningful use of it (and thus justify people having their land/property compulsorily purchased)
It also allows access to DIRFT and the new terminal thats going to be built near j15 of the M1, though that would never be enough to justify it on its own.From the freight point of view it duplicates the north connection at Nuneaton, in that it allows freight from the east to head north on the WCML. As far as I know that curve has had very little use. It would also allow a MK-Bedford passenger service, but based on the options in the consultation that would probably be a case of the same number of services, but some terminating at MK instead of Bletchley. This would probably result in whatever Marston Vale stations remained, other than Ridgmont and Woburn Sands, losing service to Bletchley.
Or 6. The property being purchased was sufficiently distant from the proposed works that it doesn’t come up on the searches.
Or they could have bought, say, 1 Chesterton Mews, which is 62 metres away from the railway line and yet is currently under threat of demolition.Since this particular householder is complaining about demolition then, unless the extra two tracks are over 200 metres wide, unlikely!
Yes, that is understood.when numbers 21+ are demolished #21 needs to also be demolished, then that might then mean #19 might then need to be demolished if it depends on #21, and so on and so on
So would I. Why can't EWR? I pity the poor occupants of Nos. 1-21 whose houses have been blighted by this consultation document.I'd put money on the only demolitions in this row being #23+
This was my point: if the householder is concerned about potential demolition then even that house is within the 200 metre buffer for the purposes of the local search.Or they could have bought, say, 1 Chesterton Mews, which is 62 metres away from the railway line and yet is currently under threat of demolition.
Should they not identify this issue now and then potentially have it emerge only later if structural survey indicates demolition is in fact required?So would I. Why can't EWR? I pity the poor occupants of Nos. 1-21 whose houses have been blighted by this consultation document.
Based on this satellite picture (very useful - thanks) it looks like there are offset party walls every few houses in the terrace.Yes, that's the house on this row at the end of AWAY from the tracks.
If that's so, then I take back what I said about EWR. But these are relatively modern houses. IF building regulations permit houses to be built where there is a risk of such a domino effect, then they are not fit for purpose.Based on that, the entire lot might well actually have to come down!
The building regulations or the houses?....or possibly both!IF building regulations permit houses to be built where there is a risk of such a domino effect, then they are not fit for purpose.
Perhaps if EWR 'reprofiled' their 'Need to Sell' scheme as 'Would like to sell if the price is right' there would be less opposition? I dare say EWR would find enough people who will buy (in due course?) or rent through a Housing Association. If not already, Bedford will be a great place from which to commute, or in which to work at or from home; it already is. Cosmopolitan- one of the widest range of cuisines- ex WW2 PoWs; River Ouse with rowing, boating; flat for biking ... What's not to like? Clearly the purchaser thought it had a lot going for it. I sympathise of course- hope she can take out some of here rage on her solicitors!This was my point: if the householder is concerned about potential demolition then even that house is within the 200 metre buffer for the purposes of the local search.
They will then be accused of hiding information i.e. the same as the current complaints about freight usage, property demolition, &c.
They’re damned if they do and damned if they don’t.
I’m no structural engineer, but I did work on a very acrimonious case a couple of years ago which was on its face a similar layout. Based on that, the entire lot might well actually have to come down!
The chord at the moment still has limited value in relation to Harwich / Felixstowe because some infrastructure off the route is yet to be suitable for Freight Traffic to run via East West Rail. Any enhancement between Ipswich and Cambridge is likely to be many many years away.East West Rail are not currently proposing a chord at Bletchley to enable trains from the East to continue North on the West Coast Mainline. Only trains from the West, including Oxford, Aylesbury and possibly freight trains from Southampton, will be able to go to Milton Keynes and continue North on the West Coast Mainline. Freight trains from Felixstowe to South Wales would be able to use East West Rail but the Network Rail study states "Note that all trains between Ipswich and Bristol/South Wales would remain on the Great Eastern and through London."
Not really my area, but I suppose Building Regs might not necessarily anticipate or require provision to be made for partial demolition of a terrace of houses!If that's so, then I take back what I said about EWR. But these are relatively modern houses. IF building regulations permit houses to be built where there is a risk of such a domino effect, then they are not fit for purpose.
I wouldn’t be at all surprised if house values go up in this area once East West Rail is up and running. If I worked in Cambridge then a half hour commute from Bedford would be a very attractive proposition.Perhaps if EWR 'reprofiled' their 'Need to Sell' scheme as 'Would like to sell if the price is right' there would be less opposition? I dare say EWR would find enough people who will buy (in due course?) or rent through a Housing Association. If not already, Bedford will be a great place from which to commute, or in which to work at or from home; it already is. Cosmopolitan- one of the widest range of cuisines- ex WW2 PoWs; River Ouse with rowing, boating; flat for biking ... What's not to like? Clearly the purchaser thought it had a lot going for it. I sympathise of course- hope she can take out some of here rage on her solicitors!
Some of you may recall Ronan Point, the tower block in Newham, the corner of which became a 'pack of cards' from a gas explosion. Building Regulations were amended in relation to 'progressive collapse'.Not really my area, but I suppose Building Regs might not necessarily anticipate or require provision to be made for partial demolition of a terrace of houses!
Correct - done many times due to bomb damage...Presumably you could, with suitable care, reinforce one of those offset party walls prior to demolition from there towards the railway so as to resolve matters without having to pull the whole terrace down?
They did it in Nottingham with the new tram lines. The mid-terrace wall of the remaining terraced house was reinforced, as can be seen here:done many times
Yep. Our house move (March 2020) to Maulden in Bedfordshire bought up EWR in the searches.I bought a house in the middle of Sandy between Dec 2019 and June 2020 and East-West Rail appeared on our searches.
There’s a potential opportunity here in this respect: buy cheaper at below true value and then, if it’s not demolished, you capture the increase and, if it is demolished, you get full unblighted market value plus loss payment on top i.e. more than market value as compensation!
