102 fan
- Joined
- 14 May 2007
- Messages
- 769
Apparently some new buses are more eco friendly by having thier engines reduced from 9 litres to 5. How is the lessened litreage accounted for? Higher gearing?
Higher compression ratios, bigger turbochargers and higher working temperatures are used to get the engine to produce the same power.
Unfortunately the torque bands become very narrow, so it's a case of getting the gearbox setup properly matched to the engine.
Presumably this is also good for hybrids where the engine can be kept running at a constant speed for much of the time.
The rest of the fleet* are Voith four speed, which are fantastic boxes, but I'm not sure how well they'll cope with the shorter torque bands, as they have fairly long gears (with the overspeed in first, you can hit 25mph on some buses). They do struggle with the newer engines and the flat spots in the rev range to meet the emissions regs though, being noticably slower off the mark and running out of puff sooner.
*With a few exceptions.
I've found the B9TL with a Voith 4 speed gearbox is significantly slower than one with a ZF 6 speed, and seem to have a flat spot in first. I've noticed this on Tower Transit 36136-165 and Metroline VW1301 which are all Voith (Metroline have randomly mixed ZF and Voith buses in the same batch).
One thing I will note is that Volvo have superseded the Euro 5 B7RLE with the Euro 6 B8RLE, so not all engines are getting smaller.
Broadly similar, the new B5TL may even have slightly more horsepower - but that's not much use if the gearbox isn''t matched to its peak torque.Does the HP remain the same?
As part of the rationalisation of engines offered, both the D7E and D9B (which powered the B7R and B9R) were replaced with the D8K (B8R). A fairly sensible step, I think you'll agree. As the low floor version of the B7R, the B7RLE became the B8RLE.
Yes and no - logically you'd expect the B7RLE to become the B5RLE, however when you remember that it's basically a coach chassis with modified front framing for a low entrance (hence the LE) you see where the logic comes from.
The general trend is downwards though; B13R has become B11R, B9TL has become B5TL etc.
Interestingly ADL have stuck with the Cummins ISBe 6.7 litre unit for their E400s despite the change to euro 6.
