computerSaysNo
- Joined
- 14 Dec 2018
- Messages
- 1,436
The first version of my Edinburgh Express Bus Map is now available. It is a semi-diagrammatic map which aims to show express and limited-stop bus routes in Edinburgh in as clear a fashion as possible. It also shows the entire route of Lothian Buses' peak-time Express services such as the X26.
You can download or view the file here, or go to this address if the link doesn't work: https://github.com/40414148/Transport-Published/raw/main/Maps/Edinburgh%20Express/EdinburghExpressNetwork.pdf
Alternatively click here to view the file on GitHub; this will let you see when it was last updated.
These links will always take you to the most recent file version and will never change for as long as the file remains online.
My map shows routes which generally operate at least once a day, across multiple operators. The frequency of which each service runs is shown in the Key on the map.
I believe the map to be correct as of the 26th of January 2023 but if you see anything which needs correcting then please do leave a comment in this thread.
Any feedback is very welcome.
I've put an image preview below, note that this may not be updated when I release new versions of the map.
