Electrostar GTR cascade
387star
Understand southeastern taking 377/1s from southern which numbers?
I travelled on two 377/1s attached together this morning and was reminded how nice the original spec electrostar interior is compared to the /2 /4 and /5 and later /1 varients
Roomy airy and really comfy seats throughout the train
So given southeastern has such a great fleet of 375s with only the metro units being high density (375/9s) I am hopeful they take later series southern 377/1s and leave the first fifteen or so that have 2+2 seating throughout and thicker padding as well
RichardKing
25 Jul 2015
I've got no idea of the unit numbers Southeastern are taking, but I do know that 377 101-119 are the units with the comfortable 2+2 seating throughout and 120-139 have the occasional comfortable seats with a 3+2 layout.
This has not been confirmed yet has it?
Unless you have some very new info, all that has ever been put into franchise agreements is that 100 vehicles (25 X 4 car 377s) are going to SE subject to future agreements.
There's been plenty of forum debate about which class or numbers they might be, but that's all.
RichardKing
25 Jul 2015
I'm sure I heard from somewhere that due to the compatibility and interior of the 375s, it would definitely be 25 units between 377 101-139 that are sent to Southeastern.
Class377/5
19 Jun 2010
yep no further info, infact SE may be getting 319s....
Word is they go for up to 25x 319 in advance of the 377s to give a capacity upgrade a year eariler than planned as switching the Victoria to Orpington service to all 319s requires no training needs as Orpington depot sign the stock.
Once the 700s release the 25x 377, the 319s will go off lease with the 377s on the Maidstone East to release the Networkers to be cascaded back to the Orpington services.
But its all rumours right now.
It's been regularly posted here about the probable unit numbers ever since first mentioned in the TSGN ITT, but repetition doesn't make it any more factual.
Class 466
5 Mar 2010
Reliably informed 377120-155 will be leaving SN for SE. The first 8-10 by December with No booked Networker working along the Maidstone East line at weekends from the December TT onwards. The Maidstone East & Chatham Main lines will see them first replacing any 465/9s working along these routes.
Class377/5
19 Jun 2010
Wow, not wasting any time then!
ScotGG
3 Apr 2013
Can't afford to waste time. The cuts to services last month, plus lack of stock meaning short trains leaving Cannon Street, have caused massive overcrowding on Metro lines.
Class 466
5 Mar 2010
Indeed not! Currently the initial flow will stick to the current 377/5 diagrams SX, and will just berth in Bellingham Sidings rather than swap over there. 377 conversion courses are in full swing at Ramsgate & Dover!
Mikey C
11 Feb 2013
Agreed, these additional trains were needed before the London Bridge works started
physics34
1 Dec 2013
Conversion course?! Not much difference to teach...
ScotGG
3 Apr 2013
So no improvement initially then in December? Just losing some 377/5s and replaced by 377/1s cascading no Networkers to Metro?
If not when will more 377/1s arrive to allow Networkers to be cascaded? SE are now sending 6 car peak trains to Cannon Street in the peaks, and that's on lines like Greenwich where peak time trains have also seen hefty reductions as path aren't available. Not much can be done about service reductions but to then put just 6 carriages on the remaining services is not working. Cannon Street services are packed and people cannot board now.
Class377/5
19 Jun 2010
True, but still must be done.
Ah interesting, only a few hours in there then. Would be good to see some along the Medway.
387star
excellent news that 377101-119 are remaining as these have the best interior in the fleet
perhaps there was pressure to keep those doesn't seem accidental
377120-139 have mostly 3+2 seating so will be akin to 375/9s although they do have 2+2 in the ends of each coach. I wonder if southeastern will tweak the interior and add these additional units to the refurb
the remaining /1s they are getting have the standard southern interior however without the later first class modifications ie no sliding door or plug points and no privacy screen in the standard class part of the end coaches
MrB
3 Jan 2016
What is the difference to drivers between 375s and 377? Will the 2 classes work in multiple with each other?
DasLunatic
11 May 2015
I must ask, what's the difference between a 377/1 and a 375? They were built at near enough the same time, have identical motors, identical body shapes...
jopsuk
13 May 2008
It used to be that they had different couplers- the primary modification from 375/3 to 377/3 was to change the Tightlocks to Delners. But since then the 375 fleet have had their couplers all changed. And 375s aren't fitted with bodyside cameras. Given they were fitted to 377/s, it would hardly be a trial to convert the fleet. If needed. I imagine they're on different software versions
Class 466
5 Mar 2010
There was no pressure at all, the job of these 377/1s is to replace 465/9s. The low density interior of 377101-119 isn't suitable. They will be wrapped in all over blue to match the refurbished 375s. Whether there's scope to add these 36 units to the 375 midlife refresh project remains to be seen.
The 377s will run on their own diagrams, with no plans to run them in booked service with 375s. obviously if one or the other fails, they can rescue one another.
ScotGG
3 Apr 2013
I asked before but no answer. Are the intial batch just going to run the 377/5 diagrams which then leave for Southern? A like-for-like swap?
If so then when does SE see a net increase which can improve things for Metro passengers with Networker cascades? May 2017 timetable perhaps? Thanks
Class 466
5 Mar 2010
Apologies for missing that!
Indeed they are, and then at weekends they will work between Victoria & Ashford/Canterbury W.
The next 12 months will be an incredibly fluid period as 377s arrive in dribs and drabs. but the initial plan is to strengthen all VIC - DFD/ORPs to 8 coaches (The maximum length they can run at without SDO) , which will free up 2 cars to go elsewhere. 377s will (In time) also replace 375/465s on the Hastings Line.
physics34
1 Dec 2013
wonder why because as far as im aware apart from the in cab monitors, exterior cameras and the software (easy fix i presume), there is not much difference....unless they are set to work DOO services.
Class377/5
19 Jun 2010
They need to run a separate batch of diagrams as SE isn't doing the maintenance on them so it's not a good idea to cross work the fleets.
physics34
1 Dec 2013
who is then? Southern?
EDIT:.......ah, its clicked....... no wonder SouthEastern drivers are learning Selhurst depot!!
MrB
3 Jan 2016
Why are the 375s on the Hastings line being replaced?! We don't want any more high density units thanks!
