PudseyBearHST
I’m not an expert at all… I believe the difference is:
ETCS is a standard system - different manufacturers make their own ETCS equipment. But in theory, it should behave in a similar way to other ETCS systems and it should be able to work with other ETCS equipment from different manufacturers.
CBTC is a generic term that means Communications Based Train Control. It means that there’s some kind of computerised system that drives and signals trains, and it sends signals over specialised radio or Wi-Fi signals (note that some forms of ETCS do use radio signals and ETCS can also drive trains)
There are different varieties of CBTC from different manufacturers. For example, Siemens CBTC (Elizabeth line) and Thalys CBTC (Circle, District, Ham & City, Metropolitan lines). However, these are all proprietary systems and cannot communicate with each-other.
So a very inaccurate analogy could be: ETCS is a common standard, a bit like email (you can send an email from Gmail to Outlook to Yahoo mail, and it will basically look and do the same thing, with small differences). And CBTC is a bit like a specific messaging platform that can only communicate with itself (Facebook messenger, Telegram, etc.). Of course, there’s a ton of differences between email and train signalling
now to hear about everything that’s inaccurate in this post,,, in a separate thread maybe- sorry this should probably move into a separate thread mods!!
Fantastic, thanks for the responses.ETCS is the European Train Control System. It is used on the Line to Heathrow in a mode called Level 2 where it has fixed signalling blocks and lineside signals are not needed. Trains are given movement authority to the end of a block. It uses an in-cab display to tell the driver when to stop and how far and how fast to drive to the next stop. The onboard systems communicate with a central signalling centre via the radio system which is based on GSM mobile phone technology.
The Trainguard CBTC system used in the Crossrail Core is a moving block signalling system where each train gets movement authorities up to the back of the train in front (with a small safety margin) and uses the same ETCS display to tell the driver what to do but can also operate with Automatic Train Control where the train is driven by the onboard computer. It operates as a subsystem of ETCS where a module can be plugged in to run the Trainguard CBTC software. It communicates with the central signalling centre via a wi-fi like system which can handle higher traffic rates so movement authority is updated more often and the number of trains per hour can be much higher.
Both of the above use Eurobalises in the four foot to pass position information to train so that it knows where it is.
The ETCS system on the Elizabeth Line Trains also has a plug-in module for handling the more common TPWS signalling used on the GWML and GEML and most other UK network rail lines.
The main difference between the switchovers between signalling at each side is that on the GWML the switchover on the GWML is done while moving while the one on the GEML is done while stationary at the platform at Stratford.
I hope that helps.
With regards to the “moving block system,” I notice the Crossrail core has ERTMS boards which act like signals and where you stop? How does this work if it’s moving block? I don’t have a lot of knowledge of in cab signalling. Thanks
