Emergency Hand Signals
HuggyB87
7 Jun 2022
Merseysode
I can't find a "signalling" thread so thought this would be the right place; feel free to move :)
On the railway, AFAIK, the hand signal for STOP/Danger is 2 hands above your head in a V shape (if you do not own/possess a R/Y/G lamp).
Is there a specified hand signal for emergency stop? For example if somebody has fell on to the track and you need to stop an approaching train.
SCDR_WMR
17 Dec 2017
As you say, 2 hands above your head. Or you can use a red hand lamp or any colour lamp waived vigorously is how the rule book describes it I believe.
HuggyB87
7 Jun 2022
Merseysode
Thank you.
So in the absence of a red lamp, waving your arms vigorously above your head would be suffice?
(I'm not planning on doing it "for fun" - more out of interest and understanding)
baz962
8 Jun 2017
Thank you.
No . The two hands are just straight up in the air . You don't wave , we will just wave back.
SCDR_WMR
17 Dec 2017
As has happened at Stafford not that long ago. Station staff put arms up but waved them, conductor waved back and off the train went. Station staff called signaller to stop train at next signal though.
Hand signals in particular need to be clear.
Thank you.
Lamp other than red to be waived vigorously only.
Dstock7080
17 Feb 2010
West London
On LU a ‘normal stop’ hand signal is both hands held steady above head; an acceptable emergency hand signal is both arms waved above head.
L401CJF
16 Oct 2019
Wirral
By day both hands held clearly above head, or a red flag displayed clearly.
By night a red torch, or any other light waved vigorously.
Efini92
14 Dec 2016
We’re not allowed to wave a white light vigorously anymore, it has to be violently now.
BrummieBobby
16 May 2022
Perhaps the RSSB have seen the physique of some of the station staff and ground staff on the network and have decided that they are incapable of anything too vigorous? <D
Taunton
1 Aug 2013
Gerry Fiennes tells a great story from long ago of a freight train which managed to set off with no crew on the footplate. Station ahead was advised, and all assembled on the platform to wave and shout at the guard in the traditional brake van to apply the brakes. They did so, and the guard thought they were wishing him happy significant birthday. Which it was.
ChiefPlanner
6 Sep 2011
Herts
Yes - a good tale - and the train piled up (after the guard had self-evacuated) .......
SCDR_WMR
17 Dec 2017
I’m not sure, maybe a stabbing motion.
I don’t know why they felt the need to change the wording.
They have to change the wording of something every 6 months otherwise there'd be no rule changes.....
Bit like when the Cess was no longer called the Cess, then was later renamed the Cess.
Efini92
14 Dec 2016
Good point. The other one that springs to mind is not being able to pass an IB on your own authority, then the next update you can again.
Gloster
4 Sep 2020
Up the creek
I was taught over forty years ago that when you raised your arms above your head, you might wave your hands about a bit to draw attention to the fact that your arms were raised (a lot of you in that sentence). Don’t do it violently (or vigorously), and limit it to the forearms and hands. And only when necessary, such as in a dark uniform against a dark background. (What I was told took less time to say than it does to write it.)
martin2345uk
21 Sep 2011
Essex
Yeah, the very next update it came back in. It’s now under passing a controlled signal rather than its own heading.
Can you say which section? I can’t see it in my version of the RSSB rulebook app…
Tomnick
10 Jun 2005
I don't think it was ever the case that you couldn't. The principle was that you could still do so, only if you'd confirmed that the controlling signal box was closed, but the wording and definitions didn't really make that clear. Now it does.
Efini92
14 Dec 2016
It’s the last part of passing a controlled signal on your own authority.
Between December 2022 and June 2021 you couldn’t. I think the wording in the amendments was something along the lines of “with GSMR there should be no reason not to be able to contact the signaller”.
I actually preferred the old wording. What if you pass the signal box and it’s open then 40 miles later at an IB you can’t contact the signaller?
martin2345uk
21 Sep 2011
Essex
Do you mean this part? This is the last part of that section as it stands currently?
Efini92
14 Dec 2016
Efini92
14 Dec 2016
Not all sections are updated each time the amendments come out. Some 'current' sections are years old as there have been no issues to update them.
S5 has been updated since December 2020
