EMT HST Nottm to Skegness
bunnahabhain
8 Jun 2005
They'll both be full sized HSTs then.
Or else they'll have to train the staff twice, as the 43/4s have a different cab/door controls.
Plus there are more spare 43/0s in case of a failure
Drivers can drive either type. Guards are restricted to normal sets unless they've had the SDO conversion course, and only two Senior Conductors have done that for the Angel sets for the proposed December runs to Skegness which didn't materialise. The Angel sets also undergo maintenance on a weekend so shouldn't be diagrammed out for anything.
WesternLancer
12 Apr 2019
From my experience of using the Summer Saturday HSTs from Sleaford to Skegness, first class is declassified (there are no first class fares between Derby and Skegness, so it would be run purely on upgrades if first class was enforced).
When I used it last year, the train manager made an announcement about the buffet being open if anyone wanted to purchase refreshments. Whether that means the actual buffet/shop is open or a trolley is being operated in that carriage, I couldn't say.
Thanks
M7R
15 Sep 2010
What do they do about 1st class? Is declassified? Or can you pay extra to be in first? Thinking about taking my lad for a ride out as he loves the HSTs and it’s an excuse to go the sea side for the day, maybe in some comfort too
43055
8 Mar 2018
Declassified throughout. Only standard class fares are available from both Derby and Nottingham to Skegness.
Deafdoggie
29 Sep 2016
It has always been declassified in previous years. First come first served!
M7R
15 Sep 2010
On at derby then with snacks and drinks it is.
Sorry some how missed all the first class talk on page 2! No idea how.
bunnahabhain
8 Jun 2005
don't think so. And uses grantham avoiding line so does not reverse there either IIRC
The 0943 ex Nottingham reverses there as it calls at Grantham. A few years ago when the service ran in the path of the 0955/1445 Skegness it also ran through to Derby via Trowell Jn and Toton in the evening due to no path being available via Attenborough.
WesternLancer
12 Apr 2019
Thanks - helpful to know that!
a_c_skinner
21 Jun 2013
How did that work, doesn't Trowell face the wrong way? Or have I misunderstood?
Deafdoggie
29 Sep 2016
I was told by the train manager the reversal at Trowell was to get the First Class at the right end again, as the AM trip called at Grantham and reversed, the PM trip needed to reverse too to make the set the same way round when it got back
bunnahabhain
8 Jun 2005
There was no path, as it arrived approximately 1915ish, after the dwell time you couldn't get out infront of the 1920 Matlock without subsequently delaying the then 1932 London, which would have affected the 1936 Leicester and 1941 Birmingham. Had it followed the 1941 Birmingham there was then a conflict with the HST running North to Nottingham, and a subsequent Ivanhoe right behind that. By running via Trowell Jn it avoided all of these conflicts and was booked to pass around the time of a HST heading North. The alternative would have been a near 30min dwell time at Nottingham.
Deafdoggie
29 Sep 2016
I thought it seemed an odd reason, as the set was the wrong way round in the morning-so it would have been better not to have reversed it! Pathing makes much more sense.
xc170
9 Feb 2008
May be in this thread somewhere, but can someone just confirm what digrams the HST's will run on this year please? Thanks.
route101
16 May 2010
Doing the a return from Derby to Skeggy then back to Nottingham. Are these usually busy?
LowLevel
26 Oct 2013
Do be aware that if you're planning to travel and put your head out of the window you will be disappointed - every vestibule is being manned by staff owing to excess foliage en route being considered a safety risk.
route101
16 May 2010
Noticed that , agency staff . Took the 0753 from Derby to Skeggy , even the buffet car was open. Im sure some coaches had seat reservations too.
Took the 1215 x3 153 set back from Skeggy , normal for catering on skeggy services?
hooverboy
12 Oct 2017
why can't they just cut down the trees?
probably a silly question, but seems a less temporary fix.
I'm sure NR used to have a minimum line clearance spec for de-veg.
Deafdoggie
29 Sep 2016
There are advance fares which include a seat reservation. Everyone else just gets a free-for-all. You can’t reserve on any other ticket type on these trains.
WesternLancer
12 Apr 2019
Presumably there is a fair chance EMR will not use HSTs to Skegness next year (ie 2020), given the derogation issues related to these trains?
bunnahabhain
8 Jun 2005
There's a good chance this is the last year. They will be replaced by 222s, whether that is 2020 or 2021 is not known yet. As the HSTs will still be around but with LNER trailers, it may still be those next year as it won't require any training for crews.
