End of the station's word!
Xenophon PCDGS
17 Apr 2011
When two postings are made at the same time, you will find that the website will always show the first to be transmitted to be posted prior to the other one.
New thread contributors may not be aware that if a posting made is incorrect, the normal advice is to strike through the posting and make a new posting.
Xenophon PCDGS
17 Apr 2011
From what I can figure out the last valid post was Kirkby,so…
Yetminster
The posting to which you make reference as being the last valid posting was not the posting originally made, but instead of being struck-through, then a new posting made, it was edited after a following posting had already been made which then caused that posting to be struck through.
Time for an adjudication.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Evening,
I’ve reviewed the series of posts - deleted a few for clarity - the correct order of play is:
Hesdigneul (SNCF)
Kerkrade (NS) (continuing from Lostock)
A reminder as noted above to make use of the strikethrough if we need to rather than editing posts. I believe the confusion has occurred as Lostock and Llanfair PG have been played moments apart. The post of Llanfair PG then being edited to Kirkby (Merseyrail) causing further disruption.
rmHawk765
8 Apr 2025
ECML South
Apologies for this, I have noted the correct protocol for future use.
