Ivo
I've just been subjected to a rant from my father who has yet again tried to travel without checking for engineering works in his area (which does get them quite often) and been caught out. He told me that, in BR days, engineering work did not exist, or where it did exist it just meant closing one line and running everything on the same line, and that closures of any description were very rare.
Needless to say, I defended the modern system, saying things like the network being too busy to manage with one track in many areas, doing it in bulk to avoid disruption to commuters, and even the somewhat controversial idea of a lack of interest from BR potentially having increased the modern workload (which, if true, would have been cleared long before now).
So, to those of you who knew BR and how engineering works were planned and progressed, what insight can you provide? What experience do you have of engineering works in the BR era, was the system then better than now, how have safety aspects changed (for instance "shutting both lines to protect workers on one track" to give my father's example, which is frankly ridiculous) - and most importantly, how wrong is he?
Also, which areas are most vulnerable to engineering works? Obviously electrified areas are more frequently covered due to having AC/DC works as well as track etc, but is there any particular reason why his area (Feltham) seems to be hit so often? I assume the third rail system (with 6tph each way) is the reason?
