Engineering works between Manchester and Bolton
19 Apr 2018
Does anyone know what the engineering works are between Manchester and Bolton on Saturdays? There's no trains running on Saturdays between Manchester and Bolton until Saturday 17th February 2024.
Mcr Warrior
8 Jan 2009
Apparently it's engineering work at "Springs Tunnel", wherever that actually is. (Anyone able to clarify?)
More info here...
Extract...
Engineering work will affect areas in the Northwest of our network between January and March 2024
Noted that there also appears to be one further Saturday closure date scheduled (= Saturday 24th February 2024).
Electrification work, drainage and track renewal at Hindley, under track crossings (cables etc), track renewal at Swinton, track renewal at Pendleton.
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
Given that the Bolton route is being affected by closures does this mean that work is also being carried out at Windsor Bridge North Jn? And will the sidings on the Atherton line just to the west of the junction be rejuvenated to enable trains to be reversed at Salford Crescent from the Manchester direction?
Geeves
6 Jan 2009
Rochdale
Even in times of disruption to my knowledge they are very rarely used. I only know one time in the last 15 years, I think operationally they are hard to access and there's some other reasons but if anything they could probably go. The new sidings are supposed to be in the Salford Central area around the junction to Hope St stone terminal
I think the second to last Saturday is trains via Bolton but not Wigan but the final Saturday weekend sees all lines blocked again at the Crescent etc.
That is an enhancement, not a renewal. As some of the work is at Pendleton itself, you couldn't use them anyway. As @Geeves has noted, new turn back sidings will be provided at Hope St prior to Salford Crescent for TRU.
snowball
4 Mar 2013
Described as drainage improvements in this press release. There's also another press release which I'll post in the TRU thread.
Passengers are being urged to check before they travel while £2.7m of essential drainage work to reduce flooding and improve the reliability of the railway between Bolton and Manchester takes place over the next five weekends.
Every weekend from 6 January to 4 February, bus replacement services will be in place at all railway stations between Bolton, Salford Crescent, Salford Central, Manchester Piccadilly and Manchester Victoria while Network Rail completes vital drainage upgrades in response to recent storms.
Tom Carrington, project manager at Network Rail, said: “We are very sorry to weekend passengers travelling between Bolton and Manchester for the inconvenience to their journeys while we put in a better drainage system to future proof the railway from heavy rainfall experienced during recent storm events.
“While journeys can still take place between Bolton and Manchester via bus replacement services, and from Preston and Blackpool with train services diverting through Wigan, it’s important passengers know their travel options first by checking before they travel at nationalrail.co.uk.”
Craig Harrop, regional director for Northern, said: “I’d like to thank our customers for their co-operation and patience while these important works take place. It is important to allow more time for your journey during this period and if in doubt, ‘check before you travel’ on the Northern website.”
Every weekend from Saturday 6 January until Sunday 4 February, the railway between Bolton and Manchester will be closed while 1404 metres of new drainage pipes are laid and six foot trenches are dug to better manage water levels to keep passengers and freight on the move.
td97
26 Jul 2017
Is there likely to be any end to the 75mph TSR on the Up line at the embankment south of Kearsley?
D6975
26 Nov 2009
Bristol
Springs tunnel is near Baildon on the Yorkshire triangle, so I think someone has got their wires crossed here.
edit - it's between Baildon and Guiseley, closer to the latter.
MadMac
13 Jun 2008
Moorpark, CA
Are they possibly referring to Springs Branch?
Lampshade
3 Sep 2009
South London
Thanks, hadn't noticed. Not a huge help that the Blackpool North to Airport service is pathed immediately behind the Rochdale.
Oooo so *that’s* why the Blackpool - Airport routinely has to wait outside Salford Crescent.
11 Aug 2019
Why this work could not be done in December over the Christmas period with a December closure
