Ex LNER (and Grand Central) Mark 4 sets for TfW
tomoufc
12 Dec 2014
Which particular through connections would you like to sever? (That is off topic by the way)
I guess the equivalent of Cardiff to Manchester as a 150 is TransPennine using 150s to Newcastle? Maybe the Saltburn train if Newcastle seems a bit bigger than Cardiff? Worth remembering too that TPE do have Mk5 which are new, not hand-me-downs, and have phased them out because unreliable microfleets are not progress.
I guess it is hard for rail enthusiasts to think that normal passengers prefer a 197 on a direct train than loco-hauled stock that breaks the connection and gets replaced with a 150 (or borrows the 197 from a direct train so the 197 gets replaced with a 150). I find it laughable that people defend TfW when this whole thread is "which of the booked diagrams are actually running?"
We are told there are changes coming to the timetable, but this shambles has been going on for more than one timetable change already. It seems so long ago we had a reliable 175 service on the Marches which connected West Wales
Your beef is with TfW, not me
craigybagel
25 Oct 2012
Immediately below a post which said how great TfW are for having 30 year old reject stock from England.
The Mk4 is nothing more than a vanity project which has severed connectivity and left continual mess in its wake. Yes, Mk4s are nice when they run, but they do not always run, don't look like getting to the full set of diagrams any time soon, and that is not good enough. People on here seem excited when the booked train actually turns up as booked. That is how bad the Mk4 project has made the Marches.
So forgive me if I am critical of TfW. I doubt anyone else who watched their connection pulling out as the Mk4 pulled in, thus earning an hour in Cardiff, would be happy either (And that is when the connection works, for many hours the Cardiff time after splitting the diagram is not even long enough to continue West without the long wait).
There is still connectivity across Cardiff. Yes it's only 2 hourly now instead of hourly, but given the vast majority of passengers on both sides leave the train at Cardiff that seems a reasonable compromise to me. In the past ATW/TFW struggled with capacity in the peaks into Manchester because of the length of time it took to do a Manchester/West Wales round trip. Now the capacity of the MKIVs can be concentrated where it's actually needed.
It also improves reliability on the route since disruption on one side of Cardiff will only affect half of the services on the other side.
So it's a sacrifice for some, but for most an improvement. I'm sorry that you're part of the some, but with a network like TfW there's always going to need to be compromises.
Jez
22 Jan 2011
Neath
As someone who lives west of Cardiff its definitely.a lot less useful when travelling to Manchester or stations on the Marches. I often used the 8am (ish) train from Neath and 1830 back neither of which are direct now..Although there is a connection off the 1830. I usually would use the 7am or 9am trains from Neath now which are direct as its easier than connecting. But I accept that the majority of passengers alight at Cardiff in both directions.. its a balance I guess. I also.used the 7am.up and 1630 back quite a bit.and these still run further West. Plus of course on Sundays we still get hourly.as far as Swansea. So it's only inconvenient at certain times.
Anyway to avoid this going.too far off topic does.anyone know why so many first class services didn't run yesterday (I noticed on twitter/X they posted quite a few were units) Given the MK4 have apparently the best availability they have had in a while that really surprised me yesterday.to see so many subbed for units
Topological
20 Feb 2023
Swansea
Very much so, but you did question the premise of my questioning TfW so I felt a response was warranted.
That would be ok if there were no issues created by terminating trains at Cardiff and someone in TfW control could maintain connections. Problems with terminating trains at Cardiff are well documented so increasing the number of terminators seems like a bad idea.
In terms of capacity, I thought that was what the 197s achieved. Since we will be seeing 2+3 and splitting/joining at Swansea. Doing so hourly would seem like a step forwards without causing too much disbenefit for Cardiff.
As noted though the timetable is finally going to change and then we should see the connectivity back. It is not as good as it could be, but at least it is a step in the right direction.
Just got to get control to hold connections a bit better (even just 5 minutes as a cap would help greatly).
Newp410
1 Jul 2023
On another note, would anyone have details of whether the Canton starter is booked to work 1W11 or 1W13 this week please?
ATP
21 May 2015
Looks like a swap on 1W55 this morning. Is that down to the disruption around church stretton?
The Prisoner
22 Aug 2012
Apologies if this has been covered, but is there any plan to use these on the Holyhead - Cardiff services other than the Gerald? I'd been planning a trip from Chester to Swansea, but it seems to be a constant stream of 197s or even 150s. Sure there used to be Mk 4s a year or two back (my office overlooks the viaduct next to Chester Racecourse).
berneyarms
26 Nov 2013
Dublin
No they have reallocated the sets to Cardiff-Manchester.
sd0733
7 Nov 2012
Seems to be down to the issues at Sutton Bridge, a set was left in Holyhead for the same reason. So everything is in place for tomorrow HD01 will work the 16:49 to Crewe rather than 17:14 Holyhead later on.
craigybagel
25 Oct 2012
Just to follow up on this, notices have appeared saying the changes will take place in "early April". As expected, the MU speeds are going, and being replaced for the most part with a 90/70 passenger/freight differential instead. The last two miles of the up approaching Harlescotte will be 85/70, so a slight slowing down for DMUs on this section, but it'll only add seconds at most. Loco hauled services should gain several minutes from being able to run at 90 vice 70.
Conformed in next week's WONs, the linespeed changes Crewe - Shrewsbury go live from Sunday April 7th.
IslandLine101
8 Dec 2022
Shropshire
Will the timetables be sped up in June to account for this? And do we know how they're getting on with Onibury to Shrewsbury? Its great to see progress being made
BillStampy
6 Jan 2024
Llanharan
67012 allocated to Manchester start tomorrow morning (with HD04), first run in passenger service for TfW in a long while, I plan on seeing it on 1V50 tomorrow aswell.
craigybagel
25 Oct 2012
Probably not. More likely they'll wait till the big timetable change in December. Plus there isn't that much space to tighten the times - the existing times are very tight and a struggle to meet with the current limits
No news or signs of work, but that isn't too concerning. It was the same with Crewe - Shrewsbury until last week when the new speed boards (bagged over) suddenly appeared.
185
29 Aug 2010
They should run Manchesters hourly on to Swansea, whilst anything coming from the west of that should instead be tied in with services to Wrexham / Holyhead / Chester etc.
Yet another totally rammed 2-car 197 on Cardiff-Manchester on Saturday (1W16, 1311 arrival at Man Picc) with 20-30 being left on many stations on route. This was whilst 1D38 (1326 Airport-Picc-Llandudno) was noticed with 2x197s a 4-car, lightly loaded. The whole 197 order should have been 3-car.
sd0733
7 Nov 2012
Been a while to get 012 back, hopefully some of the other missing ones (017 and 020 being the longest now) will follow suit.
Been lots of loco swapping recently so now have:
HD01+67008
HD02+67014 (swaps to 010 on Friday)
HD03+67010 (swaps to 014 on Friday)
HD04+67012
HD05+67013
HD06+67022
HD07+67025
Lurcheroo
21 Sep 2021
Wales
I assume it was seen at Piccadilly, hard to say as it could well be that 4 car is working a ‘busier’ diagram than the unit you were on which may be its only overcrowded service of the day. and whilst the 4 car is lightly loaded at that time could we’ll spend other times of day being very busy where a 2 car is unsuitable. It could possibly have been incredibly busy on its previous run into Piccadilly and the airport (possibly busier than your service would have been if it was a 4car) How do you assign units in that case ?
I agree that clearly the service you were on needed more than 2 coaches but that doesn’t mean the other shouldn’t be a 4 car.
As for the ordering of 2 coaches, 2 coach units ARE needed. I’ve explained it many times on here, but as an example plenty of Cambrian services need not be more than 2 coaches. And I’m sure there’s plenty of other services that equally don’t need to be more than 2.
And please don’t misunderstand me, I appreciate it would give a guarantee of getting no less than 3 coaches if they all were, but the real issue is just getting everything into service so that marches services don’t need to run as 2 cars just to run something.
Topological
20 Feb 2023
Swansea
Marches will be fine as 3+2, which is being introduced in December 2023. The problem seems to be getting to that point.
However, TfW seem to have prioritised getting 197s onto Maesteg so we are still seeing the Marches left short, or even worse with 2-car 150s.
IF the Mk4 can at least be reliable enough to run the 1 less than planned diagrams then maybe there will be some double 197s on the Marches soon.
At least all 7 Mk4 have a loco now according to @sd0733 post.
Lurcheroo
21 Sep 2021
Wales
Looking at RTT today anything from south wales to Manchester Piccadilly has been minimum of 3 cars with a few 4 and 5 car services.
Looks like only 1 2 car yesterday with everything else being 3,4 or 5.
Saturday did have quite a number of 2 car services though.
Topological
20 Feb 2023
Swansea
That is really good, long may it continue.
Bikeman78
26 Apr 2018
The only trains that often turn out a 150 now are 1W92, 1V97 and 1W98 instead of a 158.
sd0733
7 Nov 2012
HD01+67008
HD04+67012
HD05+67013
HD06+67022
HD07+67025
Been some changes to this (already!)
67010 will now come off HD03 at Canton with 67015 heading down later to replace it, HD06 now has 67013 coming off HD05.
HD04 will tonight finish in Holyhead and like HD02 before it will enter temporary storage waiting for 02 to finish its exam at Crewe before heading there for B exam and 5 car. 67012 will return to Crewe as a spare loco.
The 05:30 from Holyhead will be a unit tomorrow as HD04 won't come out so HD05 will pick up the rest of the diagram from the 10:52 from Cardiff.
BillStampy
6 Jan 2024
Llanharan
Lots of diagram changing then! Thankfully there isn't a major disruption caused by this except for tomorrows 0530, HD06 has taken HD03s diagram on 1V50 aswell.
sd0733
7 Nov 2012
Western 52
19 Jun 2020
Burry Port
Today's 1W56 has terminated at Cardiff. 67025 was making a howling noise on the run from Swansea. Not heard a 67 do that before.
