Exeter to Okehampton services (to commence before the end of 2021)
REVUpminster
3 Jan 2021
Paignton
March Modern Railways reporting a passenger service sometime during the May timetable of 8 trains Mon-Sat and 6 on Sunday.
pompeyfan
24 Jan 2012
Just noticed this path in RTT for 2K03 Exeter central - Okehampton
an arrival and departure call from Okehampton shows 8 return trips
2R51GWExeter Central0720
2R52GWExeter Central0924
2E53GWExeter St Davids1125
2R54GWExeter Central1324
2R55GWExeter Central1524
2R56GWExeter Central1820
2E57GWExeter St Davids2022
2E58GWExeter St Davids2218
Brush 4
25 Nov 2018
So, a trial timetable day? It says planned 75mph maximum, using any from cl 150, 153, 155 or 156. 75mph on the longest straight stretch in Devon......
221129
21 Mar 2011
Sunny Scotland
pdeaves
14 Sep 2014
Gateway to the South West
Hmm, the paths do not seem to include a Sampford Courtenay call. Is that likely to be the final plan?
30907
No idea, but the downhill average speed of 45mph to Crediton and the tight turnrounds at Okehampton suggest there is no margin for one ATM.
They are also missing on Sundays.
BTW I am impressed that they have been able to path most of the trains through to Central, contrary to previous reports.
geoffk
4 Aug 2010
But not Yeoford yet, as this will require upgrading the disused platform.
Wilts Wanderer
21 Nov 2016
My understanding is that Sampford Courtenay platform requires work to bring it up to standard, which is not currently included in the route infrastructure enhancements.
Dinoman
27 Dec 2019
Devon
Having just skimmed through RTT, looks like the first services booked are on the 16th May:
2K03 0843 Exeter St Davids to Okehampton
2E04 0943 Okehampton to Exeter St Davids
2K05 1054 Exeter St Davids to Okehampton
2E06 1145 Okehampton to Exeter St Davids
2K07 1240 Exeter St Davids to Okehampton
2E08 1338 Okehampton to Exeter St Davids
2K09 1438 Exeter St Davids to Okehampton
2E10 1538 Okehampton to Exeter St Davids
2K11 1652 Exeter St Davids to Okehampton
2E13 1743 Okehampton to Exeter St Davids
2K13 1838 Exeter St Davids to Okehampton
2E15 1939 Okehampton to Exeter St Davids
2K15 2102 Exeter St Davids to Okehampton
2E16 2155 Okehampton to Exeter St Davids
21C101
19 Jul 2014
If the majority of the services (including the morning and evening peak services) had not gone through to Exeter Central they might as well have not bothered to reopen it.
Wilts Wanderer
21 Nov 2016
It won’t necessarily be the 16th of May. The paths are in the timetable from that date as it is the changeover date nationally, but the actual service may not commence until a later date aligned with works completion and sufficient driver training undertaken. They’ll probably be redated shortly or cancelled off weekly by short-term planning amendment until the actual start date, similar to how station reopenings are initially planned to align with timetable change dates and then amended to come online from the actual opening date in practice.
REVUpminster
3 Jan 2021
Paignton
I couldn't see them on the 16th but on the 17th Starting Exeter Central, St Davids, Crediton and Okehampton only taking 43 minutes. 46 minutes if it stops at Newton.
Okehampton is on real time. First train 2R51 07.20 arrive Central at 08.05 That's a good time for commuters.
HamworthyGoods
15 Jan 2019
Which is why they were planned to go to central!
21C101
19 Jul 2014
Thank goodness the siren voices calling for them to terminate at the St Davids Bay Platform 2 for reasons of operational convenience were not listened to.
Terminating Barnstaple/Ilfracombe aervices there in the late sixties helped kill the Ilfracombe line.
24Grange
7 Jan 2021
Baldock
I'm amazed that the single line between Cowley and Crediton has that many spare paths on it ? 8 Trains PD Okey, How many to Barn? Plus leaving space for, say 1 up and down ballast per day at some point. - Are they going to combo and split at Crediton?
Are these 159 SWR extensions or "new" use of GWR 150's ( or what ever?)
If you follow the real-time trains links provided earlier you’ll find they’re additional and GWR services.
Also, a search on Crediton shows they are separate services:
REVUpminster
3 Jan 2021
Paignton
It's only 7-8 minutes to clear Crediton - Cowley Junction there's plenty of time to clear the section in a half hour service.
Are the number of services showing in RTT going down again now? Not exactly unusual of course, as everything gets fine tuned. I guess that day‘s service in post #14 gives us an idea what’s still likely to happen eventually?
24Grange
7 Jan 2021
Baldock
Thank You !
I suppose Topsham - Exmouth can cope ( a lot longer single line section) with a train every 1/2 hour, so Cred - Cowley should as well ! Guess I'm over thinking it :)
