Have you found anything similar for HS1?
Yes! You can find <hs1-network-statement-2017-final.pdf> on HS1's web site. The specs aren't quite as 'copy-and-paste' friendly, but here goes!
QUOTE
3.3.2.2 Weight Limits
Maximum Static Load
Section 1* 17t/axle
Section 2** 17t/axle
Loco hauled freight train*** 22.5t/axle
* Section 1 is the part of HS1 between Fawkham Junction/Southfleet Junction and Cheriton (Channel Tunnel boundary).
** Section 2 is the part of HS1 between St Pancras International Station and Southfleet Junction.
*** Includes loco assisting a passenger train.
3.3.2.3 Line Gradients
The maximum gradient is 2.50% (1 in 40). Due to this maximum gradient, trains composed of vehicles fitted with standard UIC 850KN couplings will be limited to a maximum trailing load of 1,100 tonnes. Details of gradients along the route may be requested from the Infrastructure Manager. Please contact the Infrastructure Manager for further information at the address set out in section 1.8.1.
3.3.2.4 Line Speeds
The Infrastructure Manager is obliged to operate and maintain HS1 in such a way that the TOCs are able to achieve the following line speeds on HS1:
Section International Passenger Trains Domestic Passenger Trains Freight Trains***
Section 1* 300 km/h 225 km/h 140 km/h
Section 2** 230 km/h 225 km/h 140 km/h
END QUOTE
The table in section 3.3.2.4 is to be understood as being of 4 columns and 3 rows. There is more information available in the Sectional Appendix, which I don't have!
I suspect that all this means that 20tonne axleloads may reach 140kph and 22.5tonne axleloads are limited to 120kph in the same way as for the Channel Tunnel.
