Fundamentally, why should a connecting flight be seen as any different from a non-connecting flight? Travelling by other means to the airport being connected to is always an option.Fundamentally, why not?
Swiss railways use hydro electric, which is fine as long as the reseroirs are full (they weren't last summer)
Because a flight from Manchsster to New York isn't possible to replace with ground transportation, but it's possible to use a car, train or bus from Manchester to Heathrow to joint the flight to JFK there.Fundamentally, why should a connecting flight be seen as any different from a non-connecting flight? Travelling by other means to the airport being connected to is always an option.
Yes but that's not the context in which it's being used.Fundamentally, why not?
Carbon Monoxide and Particulates (as well as Nitrogen Oxides I think?) from incomplete combustion in ICE engines are also a massive concern, not just CO2. Not sure how a jet engine performs on that front - presumably in normal operation Jet combustion is pretty much complete.
Er, that was exactly my point.Because a flight from Manchsster to New York isn't possible to replace with ground transportation, but it's possible to use a car, train or bus from Manchester to Heathrow to joint the flight to JFK there.
My apologies, reading it back I realised I took your point in post #28 completely the wrong way round.Er, that was exactly my point.
No worries.My apologies, reading it back I realised I took your point in post #28 completely the wrong way round.
Geneva to Zurich flight is 50', Add 6' for Geneva Cornavin-Airport, plus 30' check-in/security, then 10' transfer off the plane to the ground transport plus 10-15' transfer to Zurich Hbf, you've got 1h46-51m journey against a current train ride of 2h46.
True, although I'm imaging a reasonably amount of this sort of travel can cope with a holdall of cabin size, either daytrips for business or a couple of nights' conferences. And presumably Geneva-Zurich as an internal flight does not need immigration clearance, or do the Swiss make everybody go through anyway?as long as you don‘t have a hold bag. My last wait at Geneva baggage reclaim was over a hour, and that was after an hour queuing at immigration…
