Freightliner Class 90s Mothballed?
Dixie
19 Feb 2012
I've read on a post Facebook (by someone who appears to be their scheduler) that Freightliner are keeping 3 x 2 electrics in use for the moment.
The Bear
11 Sep 2019
Cumbria
I'm not convinced DRS swapping to diesel haulage has anything to do with the price of electricity. I think they do it every autumn as the 88s aren't great on heavy intermodals when the rails are slippery.
DRS don't generally swap the 88s off during RHTT season, they usually run them in pairs.......
Nicholas Lewis
9 Aug 2019
It looks like operators that aren't high electricity users are subject to a different mechanism (EC4T-Freight-tariff-letter-2021-22) for charging which is amended every month
Under the terms of Network Rail’s contract with its electricity supplier, train operators that expect to use more than 450,000 kWh in a railway year are able to lock the energy commodity tariff for their forecast amount of consumption, if they wish . If they do not wish to lock their own prices then the default rate will be the month ahead rate and will be locked by Network Rail a few days before the start of each calendar month.
Its possible FL are under this arrangement and have been caught out with the recent price surge.
DanNCL
17 Jul 2017
County Durham
At a guess DB could well use enough electricity per year to qualify for the same fixed rates as the passenger operators, which would explain why they've not taken the same decision as Freightliner and DRS to switch to diesel working. In addition to the roughly the same number of intermodal flows that Freightliner have, DB also operate the Royal Mail trips with the 325s as well as the HS1 and Channel freight, so will by far be the Freight operator that uses the most electricity.
I'd be surprised if the GBRF/Caledonian Sleeper electricity usage amounts to 450,000 kWh a year, so I'm guessing they'll be paying a fortune right now!
LSL have also stopped using their electric fleet - all of their upcoming tours, including those running under the "Intercity" brand which the 86/87/90 fleet runs under, are now booked to be diesel hauled throughout.
Nicholas Lewis
9 Aug 2019
Theres a separate arrangement for charter operators which is basically same arrangement as freight operators although why there isn't just one rate for anyone using NR infrastructure is bizarre although looks very easy to fix if the political will is there.
hwl
5 Feb 2012
Given the timing (COP26 is looming), might the action be a publicity stunt to try to force different energy tariffs or calculations?
The FOC have been highlighting that the current arrangements contain some problematic that have needed addressing for years and probably before wider scale electrification.
Bill57p9
1 Dec 2019
Ayrshire
Given the additional servicing costs of diesel engines it must take some serious economic anomalies to make dragging your own generator along cheaper in the short term. Where a change of locomotive can be avoided, such as ex-Felixstowe, it is going to be easier to justify. Equally if you were to consider the medium term benefit of fleet standardisation.
But to rock up at Daventry and find it cheaper to take the diesel to Mossend than the electric, that would take some distortion.
Unless of course, as has been hinted, there is an agenda at play here.
There are a number of 90s parked up in Mossend, but hidden behind a line of 325s.
BrianW
22 Mar 2017
OT, but it's exactly the same as these "green tariffs" :lol:
'The market will decide'. And the market has. No interference with the market and bailing out lame ducks under this government ;) None of that green cxxp here.
Makes you wonder what impact this electricity price hike will have on Lumo operation and ticket prices.
Their's isn't a volume operation like LNER, as they only have 5x803s.
Nor do they have the option of going diesel.
I know this isn't (yet) a fuel crisis, but the ferries/airlines are usually very quick to add on "fuel surcharges" for such events.
Hull Trains would be in a similar position.
All depends on their access agreements with NR (and NR's own costs).
APT618S
7 Dec 2018
Hull trains use bimode 802s so in theory could run 100% on diesel.
Caveats being that the fuel tanks are of sufficient capacity not to interfere with the diagrams and acceleration / speed on diesel is fast enough not to incur time (and presumably financial) penalties for slow running on the rather crowded southern section of the ECML.
jayah
18 Apr 2011
Indeed it must and given the movement by multiple operators there must be big numbers.
A Class 66 holds about 6,500l of fuel. At 10KWH/l and 30% efficiency it is about 20,000KWH costing about £5k at around 70p/l.
The media reports suggest a 200% electricity rise. Retail electricity was about 15p/KWH or £3k. If this rose by £6k to £9k it opens up a huge difference for any operator and no wonder they are mothballing electric locomotives.
Where do we go next? Tax natural gas and electricity goes up further. Tax diesel and the price of everything in the country goes up.
LRV3004
17 Mar 2015
88s still being used on the Tesco services as apparently Tesco are willing to contribute towards the costs of using the 88s on their services. Not sure what’s happening with the car trains, but 88006 worked 6X41 this morning, then went light back to Crewe Gresty Bridge, with 68016 coming up from Crewe Gresty Bridge to Garston to work 6L48.
To set a few things straight.
Freight Operators (and TOCs for that matter) routinely hedge their diesel requirements for a year or so in advance. Freightliner will still be paying c40-50p a litre until their hedge expires, compared to around 70p a litre on the spot market.
Most passenger TOCs benefit from long term fixed price deals for traction electricity via the NR deal with EDF, and are thus protected. However some FOCs don’t ave fixed price arrangements for reasons I don’t profess to understand, but likely to be of their own choosing. They are therefore buying traction electricity at spot rates, which is currently 4 times what it was a year ago.
boing_uk
18 May 2009
Blackburn
This is just another example of the cack-eyed way transport is structured in this country.
Critical national infrastructure like the railways being drastically affected by the vagries of the privatised UK power generation cabbal and energy markets, while also being forced to cover it's own operating costs more and more while also dealing with endless political interference and Whitehall ineptitude.
Meanwhile, road transport doesn't pay anywhere near its true costs for the provision and operation of the highway infrastructure, and aviation is subsidised to the tune of roughly £7BN through aviation fuel not incurring either a tax nor VAT.
The playing field at the very least needs levelling, if not actually being tipped in favour of rail transport, given its obvious economic and environmental advantages over other modes.
Road transport pays a lot, lot more than the true costs for the provision and operation of the highway infrastructure.
Which is rather difficult to charge on a unilateral basis, and it would be interesting to know where the £7bn figure comes from. Instead Government charge just about the highest rate of tax on passengers individual flights anywhere in the world, raising around £4bn a year (pre covid).
jayah
18 Apr 2011
There is a highly competitive market in electricity, unlike water for example or even rail travel between many city pairs.
It has been government policy for years to make energy more expensive and subsidise the most expensive means of generating it, while loading the costs onto consumers.
Diesel costs little more than mineral water before all of the tax.
furnessvale
14 Jul 2015
The private car pays for the roads, not freight transport, which does most of the damage.
Ask the private motorist if he would like to see some of his subsidy diverted from HGVs to railfreight instead and you may be surprised.
BayPaul
11 Jul 2019
Surely they'll also be using up their hedge quicker than they were planning, so they'll run out of that nice cheap 40p fuel and have to switch to 70p pretty soon (if I understand the way that fuel hedges work, which do tend to make my head spin)
bluenoxid
9 Feb 2008
How do you know?
Figure raised in tax minus figure spent on infrastructure but that covers all road transport and not just road freight.
What the various taxes of road transport don’t brilliantly cover are the negative externalities such as the cost of supporting and treating direct and indirect deaths, injuries and illness resulting from road transport.
BRX
20 Oct 2008
Indeed, the figures are all so open to argument about what is or isn't and should or shouldn't be included, that I don't think anyone can simply state that the "true costs" are paid for in full by road users. And if you want to consider the marginal cost of heavy freight then everything becomes even less clear.
jayah
18 Apr 2011
All car drivers support subsidising other road users not to use roads.
They don't generally support themselves not using roads, no matter how efficient or heavily subsidised the alternatives are.
jayah
18 Apr 2011
Research by the Freight Transport Association in 2016 (admittedly biased) concluded:
Govt (central and local) spends £4.7bn a year maintaining roads.
Taxes levied on motorists raised £33bn.
Taxes on HGV raised £4.4bn.
The fundamental problem is that the national rail network appears to cost about the same to sustain as the road network.
In 2019 Network Rail spent £1.8bn on maintenance and £2.9bn on renewals.
While road users pay for their own time and vehicles, all of this spending comes out of ticket and freight revenue.
HowardGWR
30 Jan 2013
The total taxes levied on road users have nothing to do with the costs of road maintenance, but are just part of the total revenue raised in all forms of taxes that pay for NHS, Defence and so on. Comparisons are thus faulty from the outset. When you buy a VAT-charged item, such as a lawn mower, for example, your tax is going towards all these things.
If road users paid road pricing, the money raised would still not be associated with cost of roads, unless the government decides otherwise, and they won't.
ac6000cw
10 May 2014
Cambridge, UK
Err, no it doesn't - 70% of Network Rail's revenue comes from Government 'Network Grants' - see https://www.networkrail.co.uk/who-we-are/how-we-work/how-were-governed-and-managed/how-were-funded/
Only 25% comes from track access charges, and 5% from property income.
So direct taxpayer funding of rail infrastructure maintenance & renewal costs (based on your figures) would be £3.3bn in 2019 - for a rail transport system that carried 8% of domestic freight tonne-km (roads 79%, water 13%) and 9% of passenger-km (roads 89%) in 2019, based on official government statistics.
That's a huge disparity (about 7 to 1) in maintenance & renewal costs per tonne/passenger km of traffic carried on rail and road...
This story is now the front cover story of today's RAIL magazine release.
It's perhaps worth mentioning that demand for other energy has started a surge in oil prices as well. If that continues beyond a certain point it maybe possible electricity costs are comparable again, even if they don't fall much.
