Except it wouldn’t - as the tunnel capacity is maxed out regardless of where the trains go east of it, and there’s no space on the GEML for these services.
The only answer to increase capacity at Stansted is a second tunnel or a new line in from Spellbrook. Even then the limiting factors are further south, ie capacity south of Broxbourne and London terminal capacity (hence Crossrail 2).
Having said all that, with 12 car 745s running around, it will be a while before capacity is an issue.
I wasn't suggesting new GEML services, I was suggesting extending towards Braintree to run in the path of the existing GEML Braintree services. This would mean better links from the airport to Chelmsford/Colchester too.
As you said, no capacity further south - although I'd say
@Meerkat's idea of building terminus platforms at the other end with a branch from south of Elsenham wouldn't be a bad idea - especially given the connections from the north are generally poorer for public transport than to the south. That idea still allows a rebuild towards Braintree in future, if wanted.
Something like this, for example -
Getting a rail route from Stansted Airport to Braintree on the old trackbed isn't going to happen. First it is necessary to get out of the existing Stansted Airport station and onto the old trackbed crossing both the new and old versions of the A120. Then it is necessary to get through or round Dunmow where the trackbed has disappeared. In particular the substantial viaduct over the River Chelmer, just east of Dunmow, was demolished many years ago. And virtually all of the trackbed that survived has been repurposed as a cycleway.
Yes, you'd need about 6.75 miles of new alignment to build towards the Flitch way trackbed, with about 1.5 miles of that in tunnel (first section of tunnel to proceed out of the airport property, second section to tunnel under the western A120 Great Dunmow junction - to the immediate west of that tunnel, you'd place a parkway station).
For example, see below for a potential alignment:
And you'd then need to reuse the Flitch Way, which is broadly unobstructed the whole way to Braintree.
While you'd lose the amenity of the cycle path, the railway's connections make it much more valuable to Essex.
If you really wanted another rail trail, you could convert the nearby former railway alignment from Halstead to Haverhill.
Re. capacity on the GEML. There was once a transport campaigner in South west London by the name of Stephen Colbourne, wrote an interesting blog of his ideas in the early '10s and saw him at a couple of Crossrail 2 consultation meetings around South London. He had an interesting idea for an Anglia relief line from London along the M11 to the Stansted area with branches via I think, the Epping/Ongar branch (extended to Chelmsford) and the Stansted to Braintree branch. Given the freight along the Great Eastern trackage a relief line would be welcome.
Hmmm. If you were to do this scale of project, it would be easier to grade separate the WAML junction just before Cheshunt station, tunnel under the Lea valley to Holyfield (approx. halfway between Waltham Abbey and Nazeing), continue on a surface alignment from there to the M11 and then finally an alignment parallel towards Stansted.
Even in tunnel, his idea of London-Stansted via the M11 is going to be very,very messy south of Debden.
