dk1
Ah, new info to me I appreciate the heads up.
Yes, it was to me too.
Interesting rather than useful, I'm afraid.Birmingham to Leeds via Crewe or Stoke could be interesting
No, see https://www.railforums.co.uk/threads/802207-hitachi-testing-battery-power-for-transpennine.249321/x.com
x.com
Have TPE ordered some new trains? I hadn't heard about this.
Apart from (maybe) more Liverpool – Lancaster / Oxenholme services, what would the latter provide which current Northern services don't?Re/introduce more destinations on the Anglo-Scottish and South routes, such as Blackpool, Lincoln, Windermere and Barrow-in-Furness.
Why do you want to replace the class 397s with more complex class 802s? The Scotland route from the north-west is entirely on electrified lines, so it makes far more sense to run pure electric trains as they are cheaper and more efficient than bi-modes. If anything, we should be looking at getting pure electrics for the Liverpool to Newcastle and Newcastle to Edinburgh routes (or the through route if you want to link them together), once the core electrification is complete, and then cascading the 802s to run the Hull, Scarborough and Teesside lines.Some of my ideas:
- Order 30 more Nova 1 units to replace the Nova 2 units, and to cover for the withdrawn Nova 3 units.
- Merge the Liverpool-Newcastle and the Newcastle-Edinburgh services to allow 2tph from Leeds-Scotland, and to provide an alternative to CrossCountry.
- Adjust calling points on some services, for example, on the South Route, call at Widnes and (if happening) Rotherham Masborough instead of Warrington West and Dore & Totley.
- Re/introduce more destinations on the Anglo-Scottish and South routes, such as Blackpool, Lincoln, Windermere and Barrow-in-Furness.
...why?Order 30 more Nova 1 units to replace the Nova 2 units, and to cover for the withdrawn Nova 3 units.
What is your plan for Blackpool, Lincoln, Windermere and Barrow? Is this in addition to the existing Northern services, or instead of them? The wider you spread the network, the more you're going to import and propagate delays across a bigger area. How much extra ridership do you think you would drum up from additional through services? My guess would be in most cases not very much, and not enough to offset the extra costs of doing so,
Having 2 types of train (185 and 802) would make the fleet simpler as TMD crews will only need to be trained for two types of train, as opposed to three (or back then, four). Also keep in mind that the routes to Redcar/Saltburn, Middlesbrough, Hull, Cleethorpes and Scarborough are all unelectrified, so if a train breaks down on one of these lines, TPE could use any other train in its fleet as all of their trains would run on electrified lines, which works out better than just segregating the fleet for electric and diesel operations. The 397s could go to future Open-Access operators, like Lumo or Virgin Trains....why?
What are you going to do with the withdrawn units (that as far as I can tell are working perfectly fine) and why do you need bimode for services that run fully on electric?
The DfT have made it very clear that they are opposed to future open access operators. One thing they will not want to do is make rolling stock available that an open access operator could readily use.The 397s could go to future Open-Access operators, like Lumo or Virgin Trains.
Having separate Northern and TPE operations hasn't been a panacea. Under one single umbrella organisation with local management, there could be much improved coordination and a more streamlined passenger operation. There is no need to transfer routes to do that.About Northern, they are too large to manage on their own. So transferring some (but not all) of their routes would help out.
The fleet is big enough to sustain separate electric and bi-mode trains for different route groups. LNER don't seem to have had any great resourcing/deployment problems from having some of their trains as pure electric and others as bi-mode as they ordered separate models, as did Avanti with the Evero.Also keep in mind that the routes to Redcar/Saltburn, Middlesbrough, Hull, Cleethorpes and Scarborough are all unelectrified, so if a train breaks down on one of these lines, TPE could use any other train in its fleet as all of their trains would run on electrified lines, which works out better than just segregating the fleet for electric and diesel operations.
Isn't there already an outline plan for 29 new units?Revised ideas:
- 15 brand-new Class 397 Nova 2 units for Liverpool-Edinburgh and as extra spares.
- Cascade Class 802 Nova 1 units for unelectrified lines, such as Redcar, Scarborough, Hull and Cleethorpes.
- 15 brand-new Class 802 Nova 1 units to cover for withdrawn Nova 3 units.
I believe the Strategic Rail Authority hived off TPE as a separate operator just as it was merging operators at Paddington and Liverpool St, with the claimed justification that doing this would improve coordination and streamline passenger operation.Having separate Northern and TPE operations hasn't been a panacea. Under one single umbrella organisation with local management, there could be much improved coordination and a more streamlined passenger operation.
Paddington and Liverpool St operations have a clear single main line and branch structure, and with apologies to Bristol, Norwich and Exeter there are no non-London suburban networks to speak of. Operationally it makes sense to combine them. No one is seriously suggesting bringing back Wessex Trains, are they?I believe the Strategic Rail Authority hived off TPE as a separate operator just as it was merging operators at Paddington and Liverpool St, with the claimed justification that doing this would improve coordination and streamline passenger operation.
Like arguing that abolishing the over-arching NHS Quango will lead to improved democratic control and save costs, whilst at the same time creating an over-arching railway Quango. One could become cynical
An awful name for a franchise, which ran very little in Wessex. Devon, Cornwall and South Wales being the greater majority of the operation, "Celtic trains" would have been a more accurate moniker.. No one is seriously suggesting bringing back Wessex Trains, are they?
Me too!!!I think TPE is a great brand that is associated with fast comfortable trains and as such I believe that keeping the name would be a good idea.
Having one singular Northern operation hasn’t been a panacea. Despite having one operation, the west and east sides are completely different, resulting in routes being completely abandoned on a Sunday.Having separate Northern and TPE operations hasn't been a panacea. Under one single umbrella organisation with local management, there could be much improved coordination and a more streamlined passenger operation. There is no need to transfer routes to do that.
What you appear to be arguing for is the sort of operation that existed on the Blackpool and Barrow lines when TPE and Northern both ran services, which really isn't ideal for anyone.
TPE has been a stand-alone franchise separate from Northern for over 20 years!I believe the Strategic Rail Authority hived off TPE as a separate operator just as it was merging operators at Paddington and Liverpool St, with the claimed justification that doing this would improve coordination and streamline passenger operation.
Apart from further separating out suburban services, I wonder if it is worth considering whether there are any routes that would be better off transferred from TPE to Northern or vice versa? E.g. the fast Leeds-Manchester via Bradford could fit better under Transpennine, and there is arguably little justification for intercity-standard trains to be serving Redcar.Northern + Transpennine by contrast has numerous routes which could be considered main lines, several secondary routes and significant commuter networks. It makes sense to separate the intercity routes. To be honest I would be looking split it further and 'do a Merseyrail' for Greater Manchester, West Yorks, South Yorks and the North-East.
But there is for Middlesbrough, and I think Redcar has a larger population than any of the settlements on Avanti's Holyhead route west of Chester, or west of Plymouth except Redruth / Camborne (with both of those examples, however, having longer journeys to get to the "main" network).there is arguably little justification for intercity-standard trains to be serving Redcar
You speak of great mysteries. A fast Leeds-Manchester via Bradford train, what is this mythical beast?Apart from further separating out suburban services, I wonder if it is worth considering whether there are any routes that would be better off transferred from TPE to Northern or vice versa? E.g. the fast Leeds-Manchester via Bradford could fit better under Transpennine,
It serves it for operational convenience, as are a number of other small towns on the intercity network.and there is arguably little justification for intercity-standard trains to be serving Redcar.
I believe the SRA view was that the TOCs it merged were, between them, either the exclusive or predominant users of some routes and stations. Merging them one single umbrella organisation was seen as a means of facilitating much improved coordination and a more streamlined passenger operation. They don't seem to have problems running Inter-City and local services. You can still present the public with a separate "Trans Pennine", as indeed Arriva didNorthern + Transpennine by contrast has numerous routes which could be considered main lines, several secondary routes and significant commuter networks. It makes sense to separate the intercity routes. To be honest I would be looking split it further and 'do a Merseyrail' for Greater Manchester, West Yorks, South Yorks and the North-East.
I think was more one TOC per Intercity London Terminus as an aim, they were not around long enough to complete that vision as we could have seen one operator at both Euston and King's Cross (bar sleepers and open access).I believe the SRA view was that the TOCs it merged were, between them, either the exclusive or predominant users of some routes and stations. Merging them one single umbrella organisation was seen as a means of facilitating much improved coordination and a more streamlined passenger operation. They don't seem to have problems running Inter-City and local services. You can still present the public with a separate "Trans Pennine", as indeed Arriva did
GWR or Greater Anglia are like large single trees, with branches connecting into the main trunk.I believe the SRA view was that the TOCs it merged were, between them, either the exclusive or predominant users of some routes and stations. Merging them one single umbrella organisation was seen as a means of facilitating much improved coordination and a more streamlined passenger operation. They don't seem to have problems running Inter-City and local services. You can still present the public with a separate "Trans Pennine", as indeed Arriva did
