Gatebeck Tramway
MisterSheeps
12 Jun 2022
Kendal, England
This went from Milnthorpe station (LNW, WCML) to Gatebeck gunpowder works, serving also the Lancaster Canal at Millness (Crooklands), built in 1874, closed when the works closed in 1937. There is a mystery about the track gauge, appears to have been around 3 foot 6 inches (Wikipedia says this, Railscot says approximately), the attached are from an information board at Wakefield Wharf (Millness), says between 3ft 6in and 4ft. How could the gauge vary? Very wide flanges? Was it only ever horse drawn, as the drawing suggests? Anyone know anything more?
Rescars
25 May 2021
I doubt the gauge varied. Surely it's more likely that the gauge was somewhere between 3ft 6in and 4ft, but the actual measurement has now been lost. Purely speculation, but as a horse-drawn line, the standard of maintenance may have left something to be desired and the gauge could have become somewhat flexible over time! Railscot's "approximately" may be spot on :)
randyrippley
21 Feb 2016
This 212+ page pdf file will tell you all you need to know about the site
relevant extract
Tramway system
A network of tramlines existed within the works by 1881, for a tramline is mentioned in the official report into the explosion of the northern press house in that year (Expense Magazine, section 6.2.3 above). However, the date that tracks were first laid is unclear. The Gatebeck Tramway connecting the factory to Crooklands Wharf and Milnthorpe Station was built in 1875 to a gauge of 3 feet 6 inches (1.07m), opening in January 1876 (section 6.2.8 above). According to Tyler, the internal tram network was built to a narrower gauge. If correct, this suggests that the two parts of the system were laid at different times, with the internal lines probably the earlier. Tyler’s evidence for different gauges is unconvincing, particularly because there is no evidence on any of the maps for transfer sidings (section 4.2 above), but it is nevertheless still feasible that Gatebeck had an internal tram system by the late 1860s or early 1870s since Wakefield’s local competitors were all constructing tram networks around this time. Part of a probable wooden sleeper, apparently in situ, was observed during survey circa 14.5m south of the glazing house. Its dimensions are circa 0.14m wide by at least 1.39m long; such a length would be consistent with a track gauge of 1.07m.
The earliest surviving record of the track plan is the 1896 OS map (Fig 138), which depicts a complex network of lines around the works. However, the present report has found evidence that the map omits parts of the network, namely short spurs out from the expense magazine to the two press houses and possibly another in the vicinity of the mixing house (section 6.2.3 above). Comparison with the 1911 OS map (Fig 139) suggests minor additions and changes were made to the network over the next 15 years, most no doubt intended simply to ease the transfer of materials between buildings, but at least one – the creation of a dedicated spur to the incorporating mills and the shortening of the previous route past the large corning house and glazing house to end at the latter building – was presumably undertaken because of safety considerations (Glazing House, section 6.2.3 above). Although not recorded cartographically, the present investigation has produced evidence that when the small corning house was reconstructed between 1923 and 1931, the spur to the northern press house was extended across the river to replace the existing spur that approached the building from the east (Small Corning House, section 6.2.3 above). The track was lifted when the works closed, and although a number of rails lie scattered about the works (some upended and stuck into the ground north of boiler house 8 for example, presumably as fence posts) there is little evidence of the permanent way apart from bridge abutments where the lines intersected watercourses. The most impressive of these abutments lie on the spur out to the expense magazine and press houses where it crosses the pre-gunpowder mill leat (Fig 103) and beck, but a number of smaller abutments survive along the banks of the beck within both Millbrook and Gatebeck Caravan Parks.
Note: "Crooklands Wharf" is a canal wharf on the Lancaster canal
It's worth noting that I've been told by a local the at least some of the rails were wooden - you really don't want steel on steel on an explosives site. However I've no idea how much credence to give that
Just for interest a couple more links
A potted history of the site
Background of the Furness & Kendal gunpowder industry
MisterSheeps
12 Jun 2022
Kendal, England
Thanks, both. @randyrippley for the download about the gunpowder works, though the authors state the tramway to Milnthorpe was not researched, there may have been a 1ft 9in internal works tramway, and the terminology (horses propelling bogies around the works, p37) makes no sense in railway terms. It is surprising how little information exists about the tramway. The map on page 2 also shows a railway to Blackbeck off the Lakeside branch ... interesting.
randyrippley
21 Feb 2016
I think "bogies" would have meant (in that context) either 4-wheel flatbeds or 4-wheel tipplers. Think of mining tramways.
As for the Blackbeck branch - wasn't that to an ironworks?
MisterSheeps
12 Jun 2022
Kendal, England
no, Black Beck was a gunpowder works ... i think it was the combination of charcoal from the densely wooded area, water power, and the demand from mines & quarries in the area which explains the profusion of gunpowder works, though seems odd that Gatebeck (with its obsolescent tramway and canal) lasted longer than the standard gauge Black Beck
randyrippley
21 Feb 2016
One reason for the number of gunpowder works may simply be down to the fact that juniper seems to have been the preferred wood for making gunpowder charcoal, and juniper was common in the woodland in the South Lakes.
Of course it may also have developed in parallel with the iron works around there, which would also have started off using charcoal rather than coke.
I remember Arthur Ransome describing lake district charcoal burning in one of his books, but can't remember whether that was for iron or gunpowder
