The_Train
- Joined
- 2 Jun 2018
- Messages
- 4,367
Yeah, I'm pretty sure 303 has been acquired for parts only
Interesting… is that for conversion or withdrawal?Reported on WNXX this morning that 56081, currently at Melton, is 'to be retired to Longport in the New Year'
Or whether they are going to use the bogies, traction motors and traction alternators as spares for the class 69 fleet maybe ?Seems odd as all 16 donors have been identified. Wonder if 081 is an additional rebuild?
The cl. 69 uses an EMD/Progress Rail alternator but retains the Brush traction motors - a quote from https://www.railengineer.co.uk/566669-or-56-plus-66-equals-69Or whether they are going to use the bogies, traction motors and traction alternators as spares for the class 69 fleet maybe ?
('Bob' is Bob Tiller from GBRf)The EMD 12N-710G3B-T2 diesel engine produces just under 2,400kW (3,200 HP) at 900rpm and conforms with the EU Stage 3A emission obligations. The requirement for repowering is that the emissions of a new engine should be “better than the engine it replaced”.
Bob says that the old engines predated any emission regulations and were famous for high fuel consumption, smoke and leaks, so the new engines are a very considerable improvement. The new cooler groups, electrical cubicles, computer cubicles and internals were similar to other GP40/50 American designs for metre-gauge applications and fitted the 69 bodyshell, so these were manufactured in Chicago along with the engines, alternators and auxiliaries, and shipped to the UK for installation at EMD Progress Rail’s Longport facility.
It could have had a major component failure or require work on it which has led to a change of plan.Seems odd as all 16 donors have been identified. Wonder if 081 is an additional rebuild?
The Brush cl. 57 rebuilds did use refurbished or new cl. 56 alternators with an EMD diesel engine, but (AFAIK) that used a Brush traction control system.I was under the misapprehension that class 69s used refurbished class 56 alternators.
Correct. Parts of the Class 57 design were used to bring 41001 back to life.The Brush cl. 57 rebuilds did use refurbished or new cl. 56 alternators with an EMD diesel engine, but (AFAIK) that used a Brush traction control system.
So does the class 66 engine + traction alternator combo go straight into the class 69 then ? Makes a lot of sense for the output from the traction alternator to go into the new class 69 contro0l frame.The Brush cl. 57 rebuilds did use refurbished or new cl. 56 alternators with an EMD diesel engine, but (AFAIK) that used a Brush traction control system.
The cl. 69 has EMD EM2000 traction control, which on their DC-drive locos normally uses electronic control of alternator excitation for wheelslip control and multiple alternator field windings to do the equivalent of motor-grouping control (the motors are all connected in parallel). It's possible that the cl. 56 alternator wasn't suitable for use with EM2000.
Wasn't there a rumour a bit back that Colas were sniffing around the 69s as an option to boost their fleet? I wonder if this interest is what has prompted EMD to produce "demonstrators". Although saying that, it appears to be a bit pointless to produce a demonstrator for something that they will have limited scope to produce in the future, unless they are hoping Colas turn up with their 56s to be converted, of course.Regarding the option to build a further two 69s, these "will *not* be for GBRf", if produced they will be for EMD as demonstrators or for spot hire, as with the 56303 situation time will tell
Well yes.Wasn't there a rumour a bit back that Colas were sniffing around the 69s as an option to boost their fleet? I wonder if this interest is what has prompted EMD to produce "demonstrators". Although saying that, it appears to be a bit pointless to produce a demonstrator for something that they will have limited scope to produce in the future, unless they are hoping Colas turn up with their 56s to be converted, of course.
Now if Progress Rail produced a demonstrator class 60, I could understand it.
.... That report on the Class 56 Group Facebook was dated 2nd January (same date as your #1,037 Reply). I photographed Class56 081 passing through Eastleigh on 13th December 2023 dragging empty EMU stock with 69 008 on the tail and know she has been busy dragging stock up to that date. Interestingly on return journeys 081 has been at the head of the train with 69 008 still on the tail. Isn't it more usual for Top-n-Tail locos not to swop ends?According to Class 56 Group facebook the movement of 56081 from Leicester LIP to Longport tomorrow has been cancelled until a later date
Given that 098 seems to be misbehaving a lot lately, I wonder if that could find itself swapped for 081 in the queue for re-building? If that’s still the plan for 081 at least..... That report on the Class 56 Group Facebook was dated 2nd January (same date as your #1,037 Reply). I photographed Class56 081 passing through Eastleigh on 13th December 2023 dragging empty EMU stock with 69 008 on the tail and know she has been busy dragging stock up to that date. Interestingly on return journeys 081 has been at the head of the train with 69 008 still on the tail. Isn't it more usual for Top-n-Tail locos not to swop ends?
This is something that I have heard although that was on the basis of 098's recent failure being serious enough to warrant it unserviceable and I am not quite sure how much substance there is to that at the moment. Certainly appears that Colas won't be taking the option of extending their short term lease of 098Given that 098 seems to be misbehaving a lot lately, I wonder if that could find itself swapped for 081 in the queue for re-building? If that’s still the plan for 081 at least.
Has GBRf provided any confirmation of its future?56081 made what is possibly its last journey today, the 121 late departing 0944 0Z56 Old Dalby to Longport FD
It lives onInteresting development on the 56098 front, reported on WNXX today that with 56103 still undergoing an 'F' exam and 56301 on repair at Loughborough, that 098 is set to go out on hire to DCR next week
