- Joined
- 13 Dec 2018
- Messages
- 4,073
I believe the bogies were based on the CFR DA 60s, which I think we're originally a Swiss design.Looking on google images, the electroputere 060 DA looks to have similarities
Hi Richard, the possible swiss origin rings a bell with what i had read years ago, when the class 56's were being constructed. so you could be right.I believe the bogies were based on the CFR DA 60s, which I think we're originally a Swiss design.
I know slightly veering off topic but think the first few DA 60s were built in Switzerland - possibly someone can confirm?Hi Richard, the possible swiss origin rings a bell with what i had read years ago, when the class 56's were being constructed. so you could be right.
Yes first six IIRC and tested there over Gotthard.I know slightly veering off topic but think the first few DA 60s were built in Switzerland - possibly someone can confirm?
Weren't those built in Romania?
Will they also have engine driven compressors like most GM powered locos or retain originals (like 57s?). Back to Romanian link the GM re-engined DA60s appear to have engine driven compressors the amount of times the unloading valve goes off.Are the new bits (power units, cooler group, roof section containing silencer, etc) identical and fully interchangeable with those on a Class 66? From looking at the photos, the roof sections so appear to have the class 66 roof profile.
Some updated photos on WNXX (subscription section) today, 56031 has replacement structural components in place and the cab ends restyled, new light clusters and new buffers while it no longer has its grid, underside equipment and roofline sections have been fitted with glazing and bodyside grilles to come, 56311 is next and is on refurbished bogies but waiting for the roofline to be done
I'm surprised it has a yellow panel at all, especially since it has had new lights. Does it have a top light?THe new roof sections do look very similar to those on a Class 66, but difficult to tell for sure whether they are identical.
It also has an AAR multiple working socket in the middle of the yellow panel
There doesn't seem to be any intention to fit a top light as the loco appears at this time, I find it very unlikely that they would cut a space for it now and, presumably, make changes to the wiring. In their current (non)painted state there is no indication of whether there will be a yellow panel or not
The light just below the windscreen is the top marker light, the light clusters lower down include headlights.Looks to have lights in the same places as previously - headlight just below the windscreens, in the centre, and light clusters lower down to either side.
The avoidance of yellow panels seems to be a preocupation of passenger operators - none of the freight operators have bothered with it: DRS has them on the 68s and 88s as part of their livery, despite the yellow technically not being needed (the TPE liveried 68s do not have them)
Well done the freight operators!Looks to have lights in the same places as previously - headlight just below the windscreens, in the centre, and light clusters lower down to either side.
This @GBRailfreight Cl.69 is the first of ten being rebuilt from redundant Cl.56s. This is 69001, previously 56031. I'm told the work is far more in-depth than even the 47/57 conversion project. CLIFF BEETON.
Looks great so far, I'm glad a '56' finally has modern lighting!
What happened to the 66 on the edge of the shot, looks like fire damage?
Thats 66048 the accident damaged one.Possibly the one involved in the Slochd Summit derailment a decade or so ago?
How is it so blackened, there was no fire damage in the accident?Thats 66048 the accident damaged one.
Read 37190 'Dalzell" 's post on Flickr for a detailed explanation of what happened to it here:
Black Sheep?
Seen through the bushes from across the main line, Class 66/0, No. 66048 is seen in the yard of EMD Electro-Motive at Longport. Photographed on the 7th September 2020, the loco had last worn the blue and white Stobart Rail livery and the name "James The Engine". A trawl of the internet found...www.flickr.com
I would explain here but it's off topic.
How is it so blackened, there was no fire damage in the accident??
Simplicity, I suspect, where simpler=cheaper. Why spend money on making things above the roof look pretty when hardly anyone will see them?I'm interested to know why newer designs often seem to have that faceted shape to the roof, while many older locos (including the original 56s) had a curved profile. I'd have though that the curved profile would be the more difficult to produce - and therefore more likely to be a thing with modern manufacturing technology, rather than the other way around.
