Getting Water into a Cold Boiler?
Diplodicus
8 Mar 2013
Steam engine boilers have a water feed provided by a steam injector. How do you get the water into a cold empty boiler?
Taunton
1 Aug 2013
Some locos, particularly GWR, as well as an injector had crosshead pumps, connected to the cylinder motion. You can thus propel them up and down the yard with another locomotive to activate the pump and get water in.
Pigeon
8 Apr 2015
Hose into the injector overflow would do it if the boiler was cold, or indeed if it was not cold but also not hot enough for the pressure to exceed that of the water mains. I have heard of hose connector fittings being permanently mounted on the ends of injector overflow pipes to facilitate this method.
tiptoptaff
15 Feb 2013
None of the GWR locos I worked on had such a pump. It was all done by backfilling with a hose.
The only pump connected to the motion on GWR locos was the vacuum pump
dazzler
6 Apr 2018
York
My father fills his steamroller boiler through the manhole cover ( an inspection hatch on the side of the boiler, above boiler tube level) with a hose pipe.
