Given the Shapps announcement, which lines would you propose for reopening?
DynamicSpirit
12 Apr 2012
SE London
This is one of the big problems with reopenings, that the larger places which used to be served by the previous services are unable to do so due to the growth in passenger numbers.
Yeah, it is a common problem. What makes it a particular issue with places like Cranleigh is that the proposed new branch joins the main line quite a distance from the obvious centre that you'd ideally want trains to run to - which implies considerable running over already congested lines. That wouldn't be such a problem with somewhere like Blyth/Ashington, where you'd probably be looking at an effectively new line that only joins the existing line very close to Newcastle, so the only real issue is ensuring capacity at the terminus itself.
DynamicSpirit
12 Apr 2012
SE London
Here's one I don't think I've seen suggested before.
About 2 miles out from Hull station, the Hull-Scarborough line crosses what I assume is a freight-only line. That freight line runs through a large part of the Hull urban area. And then around Marfleet, what looks like an old trackbed diverges from it, heading out to Hedon and then Keyingham before running into very rural areas. If a chord could be constructed to get trains from that line into Hull station (would probably require demolishing a few houses, sadly), then that looks to me like a potential commuter line that would serve a very high population, at least as far as Hedon, possibly up to Keyingham..
The Ham
6 Jul 2012
There's probably quite a few places around the country where £150 million would allow a new grade separated junction to be created to allow local metro services to run along two lines, quite probably with extra stations built between existing stops.
As long as such schemes looked to serve fairly urban areas then chances are they would be successful. Even if they didn't fully cover their costs on local travel they would increase the numbers using rail so overall the impact is likely to be positive financially.
S&CLER
11 Jan 2020
southport
Branch lines are less useful than links between bigger places that would open up new cross-country(small c) journey opportunities. How about Northampton-Bedford? That might allow a link with East-West Rail and create a much shorter route from Birmingham to Cambridge and Ipswich without reversal at Bletchley. Would the Wellingborough route be better than that via Olney? My 1:25,000 OS map of Northampton is dated 1999, so not much help in showing what's still left of the old alignments now.
A0
19 Jan 2008
Northampton - Bedford's a waste of time, it's a 22 mile line which actually serves nowhere of any significance en route. And when it was open the journey times were circa 50 minutes. Even allowing for modern rolling stock, with the route you'll only get that down in the 30 - 40 ish bracket. Northampton - Bletchley at the moment is 20 mins and EWR are looking at a 20 - 30 min Bletchley - Bedford journey time on which basis Northampton - Bedford direct really doesn't achieve anything.
tbtc
16 Dec 2008
Reston City Centre
Could tbtc (who, IMHO, writes copious sense on these forums) comment if the Sheffield to Stocksbridge line, currently freight only as I understand, could be a sensible candidate? I see the new MP has mentioned it on her FB page:
Very interesting question - I'm going to start a separate thread on this because there are so many complications and so many compelling reasons... it's one I'm on the fence about but with good reasons for doing it and some particular problems in terms of making it a useable line - a real conundrum - glad you asked though :)
This Thameslink 2 / BML2 thing is the problem that Lewes to Uckfield faces - rather than a fairly simple reopening of a few miles of railway along an existing track bed (though probably also some upgrades of the existing route), it becomes part of a multi-billion pound project and trapped in that framework.
BML2 have certainly put the work in to make it less absurd crayoning and more reasonable proposal in recent years. However even the Sussex phase in isolation they throw in a tunnel bypassing Lewes and talk about it being a full time alternative route to London from Brighton and not just a diversionary route - necessitating more comprehensive upgrades (eg linespeed - London Bridge to Uckfield takes longer than London Bridge to Brighton) of the Uckfield line. It also raises the question of where there's room north of Croydon for those additional trains (it's not the 1 path a more focused reopening would perhaps require) - something they know is an issue hence why their proposal is multi-billion as that's what it takes to fix!
Uckfield-Lewes is another zombie that won’t die! Didn’t work as a local line so morphed into a crazy long way round Brighton diversion that has become so expensive it would be better to just quadruple BML1....
This is one problem that these kind of schemes have. Because they have spent a long period as an obsession of a relatively small number of people, they've evolved from "simple project to tackle a small local problem" into "mega-scheme that improves regional connectivity and guarantees year-round resilience".
Uckfield to Lewes has some merit. It's not particularly long, it has a commercial bus service (albeit only half hourly, so not in the same league as some places without a train line - e.g. the multitide of Arriva expresses from Ashington/Blyth into Newcastle), I could see a simple extension of the existing London Bridge service - it wouldn't need to be anything fancy - you'd ideally want electrification (which would put the costs up) but if you were doing a list of Top Fifty Lines To Consider For Re-Opening then I wouldn't object to seeing it on there.
It lacks some of the "regeneration"/ "marginal political seat"/ "post-industrial town struggling to adapt, but lots of jobs in nearby big city" aspects that tick a few boxes. There's nowhere large without a station (so it's not as attractive as seeing somewhere like Ebbw Vale that has no passenger trains) - it's more about providing a local link but without the "urgency" that some better schemes have.
However, growing in the dark, unchecked by any serious scrutiny, it's mushroomed into a billion pound scheme that attempts to rival the Brighton Main Line , requires removal of parts of Tramlink, needs a long tunnel under south London, diverts away to serve Docklands and is presumably intended to run to somewhere north of the Thames as an alternative to Thameslink (even though there's nowhere north of the Thames that will want to surrender their existing Liverpool Street service to a train to Croydon).
Same goes with a lot of these schemes. Look at any Okehampton - Tavistock thread and see how long it takes until someone mentions bringing back through Waterloo services. You could maybe justify "SELRAP" as a modest extension of the hourly Preston - Colne DMU through to Skipton, but, oh no, it *has* to be a mega-trans-pennine scheme with bells and whistles.
People need to look at what works well (short stubby branches like Ebbw Vale, Alloa) and adjust their sights a bit - I'm not sure if the Government will actually re-open more then the Ashington line (and maybe that's more of a "Being Seen To Reward The Former Labour Voters" and "Smokescreen To Avoid People Thinking We Only Invest In The South Whilst We Go Ahead And Build HS2") - but if they do then it'll be a few short schemes - not some region wide project that will suck up the entire discretionary spending for the whole country.
As an example, I'd welcome a fast tunnelled alignment from Exeter to Plymouth that avoids Dawlish (would knock best part of half an hour off the journey time, would make trains competitive with the A38, would remove the weather risk, would free up space through Dawlish for more local trains), but I know it's too expensive to get built in the current climate so I'm not petitioning anyone for it.
If you ask Father Christmas for something simple, he might give you a short branch to somewhere like Tavistock/ Portishead - don't get greedy and waste your crayons on a scheme that rivals both the Brighton Main Line and Thameslink and involves huge tunnels through urban areas and doesn't really deliver much of benefit.
That’s remarkably sensible! One of the main reasons for reinstatement of a line is surely to give a quick reliable way through heavy rush hour traffic, as with Witney to Oxford.
Interesting - I don't know Oxford that well but I've always seen road congestion when visiting and always seen some fairly full Stagecoach double deckers - it's the kind of place where there look like large numbers of people who could be taken off the roads if we could get better trains - but I can't comment on the Witney example - I think that starting from a position of "Which Places Have Traffic Congestion" would be a good place though (something that isn't a particular problem in places like Colne!).
Skipton to Colne would be a good one as it immediately opens up a new transpennine route with the potential to reroute freight traffic.
How much freight a day are we talking about?
How are you going to path it through Leeds and up the Aire Valley from Leeds to Skipton?
And is this mainly just biomass so that we can spend a lot of resources delivering some American materials to burn (because the power station are too tight to pay for ships that use an eastern port, so expect to continue to use a western port and get the taxpayer to fund a new railway line for them)?
In the 2008 study of Uckfield - Lewes, it was calculated that a straightforward single track link between the two would cover its operating costs. Perhaps now, with increased usage the case can be made towards funding construction.
Covering operating costs ought to be a minimum threshold for such schemes - I'm not expecting them to repay the infrastructure costs any time soon but I wouldn't want to open any more lines that require operational subsidy. As above, I'm okayish with a simple Uckfield - Lewes (just not with all the bells and whistles of a mega "Brighton - Docklands via a new tunnel under Croydon" project)
This is a problem.
The word "useful" gets used a lot on here - it's a nice way of justifying things but unquantified - how do we compare the number of people who'd use a simple branch line from a post-industrial town into the nearest big city against the general unquantifiable Nice To Have increased number of long distance links (that people wouldn't use in large numbers every day, but it'd nice kind of nice to have that ability just in case)?
I could see the merit in more long distance links but a lot of the ones that we have are pretty poorly used. Between the Derby - Birmingham line and the Gospel Oak - Barking line, the "east-west" links are fairly quiet lines. Birmingham/Leicester to Peterborough/ Cambridge/ Stansted only gets an hourly Turbostar. Bedford - Bletchley only gets an hourly DMU (was a single 153/150, now a 230). St Albans to Watford is an EMU every forty five minutes.
So it's not as if you can look at the cross-country services we already have (south of Derby, north of London) as huge successes - there are various "calls" to bring back some cross country links but if the best you can hope for is an hourly 170 then there are bigger priorities we could be getting on with. However, if we lived in a world where there were no Birmingham/Leicester to Peterborough/ Cambridge/ Stansted service then I'd expect people suggesting it could justify a full length train every fifteen minutes!
(East-West may be a success one day but as it's already being started upon, I'm not using it as an example here)
Meerkat
14 Jul 2018
Section 4.4.1 of the report showed that four of the six rail based options covered had an operations ratio of more than 1 (i.e. they covered their operating costs).
And what about the capital cost?
Thebaz
24 Nov 2016
Purley
I am in favour of some-kind of reopening of the Uckfield/Lewes corridor. By far the cheapest and easiest option would be a simple extension of the existing single line (with passing loop somewhere) and trains terminating at Lewes. Probably the most logistically complicated and costly (but apparently East Sussex County Council have volunteered to stump up for this, so says BML2....) part of this scheme would be the work required in Uckfield itself to avoid level-crossing reinstatement. The vulnerabilities the current London Bridge-Uckfield hourly service keenly demonstrates, however, suggests that this could easily run into the same operational issues. So I think first you would need to improve service robustness which would involve re-doubling and electrification. That said, I would rather see the above than nothing...
At any rate the following outlines my favoured option (and I know I have a lot of sway here..). For speculative fun let's assume planning starts now:
2020-2024
- Design and planning (continuous)
2021-2023
- Re-double the singled parts of the line.
- Improve reliability of existing services. For this, electrification south of Hurst Green is a must. It is insane that this was not done along with East Grinstead in 1987 (how this compares with the insanity of closing the line in the first place for a harebrained and subsequently abandoned road scheme, I don't know) . Bi-modes will not do because that will keep the route off-limits to the majority of passenger rolling stock in Southern England just as it is now. Accessibility to all rolling stock is part and parcel of improving the robustness of service provision.
2022-2024
- Major civils work in Uckfield town centre - re-routing the A22 on to a new bridge over the alignment. Move the station back to its original position.
- Re-construct the missing link joining the Lewes line at Hamsey replete with electrification.
2025
- New through services to Eastbourne start. (hooray!)
Additonal options
2025
- work begins boring Ashcombe tunnel
2026-2028
- Ashcombe tunnel route constructed
- Tunbridge Wells Route re-connected
2028
- New through services from Tunbridge Wells to Brighton start
There. All the World's problems solved.
EastisECML
26 Sep 2018
Blyth & Tyne line
Leamside line with a connection to the ECML near Birtley to act as a Durham bypass for either the LNER 'super express' or HS2 trains.
Woodhead route perhaps as a link between envisaged Manchester and Sheffield tram-train networks.
Not so much a reopening as much as 'opening up' an existing route to more local services...Durham - Chester le Street - Newcastle - Killingworth - Cramlington - Morpeth - Alnmouth.
A line from the Tyne Valley along the north bank of the Tyne into central station for semi-fast trains. Freeing up the existing line from Blaydon for more stopping services. Blaydon & Dunston only get one train per hour despite being within 'metro distance' of Newcastle.
Bishop Auckland to Durham so those communities along the current Darlington-Bishop Auckland line can be linked to Durham and Newcastle without having to go to Darlington first.
Consett-Stanley-Birtley ECML.
6026KingJohn
8 May 2019
Lichfield-Walsall (would like to continue to Dudley and Stourbridge, but the Midland Metro has already laid claim to Wednesbury-Dudley!)
1) Access for freight from the North-East to Bescot Yard avoiding Sutton Park line.
2) XC Newcastle-Reading trains do not stop at Tamworth so could call at Lichfield City and/or Walsall en route to Birmingham using this route.
3) WMR could provide service from Birmingham, via Walsall & Lichfield, to Burton-on-Trent or Derby with new stations at Rushall?, Pelsall, Brownhills, Alrewas (for National Arboretum). Instead of trying to fit trains for Alrewas onto the Cross City line. (Part of WMR's future plans)
4) Freeing some paths off the Sutton Park line would help WMR's stated aim to extend services to Aldridge (whenever :))
Route is still there between Lichfield and Anglesey Sidings at Brownhills and the rest, between there and Ryecroft Junction, has been safeguarded by the local councils. The bit still there has been singled (except where nobody has bothered to lift the second track). The bridge over the M6 Toll was built for two tracks (as far as I know). There was even a bridge built in the middle of Brownhills to create a roundabout which was built after the line was closed, but before all the track was lifted.
Neen Sollars
21 Jul 2018
Looks good to me and I suggested this line yesterday. Heavy rail and metro can now share the same track (Wednesfield to Dudley)? But Planner says Worcester too busy for freight. So guage is not an issue for freight?
apk55
7 Jul 2011
Altrincham
Another option is some extensions to Manchester Metrolink. Two which are being discussed elsewhere in this forum and are basically reinstatement of closed railway lines are Bolton to Radcliffe and East Didsbury to Stockport.
SCH117X
27 Nov 2015
Not entirely a closed railway and no railway at all in part but their was a proposal some years back to link the former Cotgrave colliery line to the east of Nottingham to the Old Dalby test track to allow for a more direct Nottingham to Peterborough/East Anglia services as well as restoring the link between Nottingham and Melton Mowbray and the possibility of London service running via Corby rather than Leicester.
The Ham
6 Jul 2012
The problem with such a new alignment is that it would only benefit a few trains an hour and there's no scope for extra services at the London end. That would just mean that you'll end up with more standing passengers heading out of Paddington.
To overcome this, unless you were to extend the Bedwyn services you'd need to spend a lot of money to increase capacity out of Paddington as well.
Compare this with the option of extra services from Waterloo, although it would require a lot of spending that spending would be in the form of Crossrail 2, which is justified on its own.
Yes you'd need to spend money on redoubling the WofE line, however there's likely to need to be spending on the B&H to improve capacity.
Whilst I propose the use of Waterloo to Plymouth trains it's not because it happened in the past, rather because there's space on the network for them.
It also improves the connectivity between more of Exeter (as well as the area of Devon East of Exeter) and Plymouth than a direct line would provide. However there's also suggest that the reopening via Okehampton would make a new direct line more likely and not less.
That may sound far fetched, but if you provide 5tph semi fast trains between Exeter and Plymouth, then what's going to happen to passenger numbers? They are most likely to increase significantly, with that increases flow it would mean that the time savings from the direct line would have a bigger value associated with it than with the current trains.
You would make travel to the South West much more attractive from across much of Southern England, including from the likes of Portsmouth, Southampton, Guildford, Woking, Salisbury, etc. without the need to go via Reading or Westbury. Which either means heading further North than you need to, or in some cases even heading further East, before you can head West.
That then frees up capacity for others to use those existing GWR services.
Now, with future electrification what could happen is that you have electric trains out to Yeovil, with a cross platform change to Plymouth, which would remove the need for the trains to run over such a long distance. (Assuming that you don't have bimodal trains or that's the limit of your battery trains).
It could even be possible to provide, if there was a market, a few fast trains a day from Waterloo to Plymouth calling at a few stations (Waterloo, Basingstoke, Salisbury, Exeter and Plymouth, with a likely journey time of 3:45). That would put travel time from Waterloo via Paddington to Plymouth on a comparable journey time. Even if it was 20 minutes slower if it left 20 minutes after the time you'd need to leave Waterloo to get to the hourly Paddington train then you'd still get to Plymouth 20 minutes before the next train for there.
That would likely be course enough in journey time to attract some people from London, however by the time you get to Basingstoke (even with a 4 hour journey time from Waterloo) this would now be 3:10 on a direct service rather 3:20 with a change at Reading, however it could be sub 3 hours (just).
Bevan Price
22 Apr 2010
My prediction is that - after a due interval - all, or most of the "Beeching reversal" proposals will be dropped, either because they are all deemed to be "unaffordable", or because the post-Brexit financial crisis will take priority for government spending.
Assuming anything does get the money to proceed, my own favourites would have included:
1. Restore rail service for Leigh - but probably too expensive due to presence of misguided busway, and removal of infrastructure through town centre.
2. Restore Exeter - Okehampton - Tavistock - Plymouth. New type of bi-mode trains, but with DC electric rather than AC to enable operation into London Waterloo.
3. Blyth & Tyne - but a question, how to serve Blyth ? It was on a branch off the line to Ashington, so complicates how you operate the services. Do you have alternate trains serving Ashington & Blyth, or just rely on shuttles between Blyth and the junction at Newsham. And would the best solution be to connect it to the Tyne & Wear tram system?
4. Fairly simple - restore St. Helens Central to St. Helens Junction, with hourly trains to/from Manchester. Problem then becomes line capacity in the Manchester area.
5. Chinley - Matlock. Would permit better services between Manchester & East Midlands.
Fleetwood ? Original rail passenger traffic fell partly due to decline of passenger shipping services to Isle of Man & Ireland. Not a large population close to intermediate stations. Even at Thornton Cleveleys, the local population at Thornton is not huge; the much larger Cleveleys is almost 2 miles from the station. Blackpool is probably preferred destination rather than Poulton Le Fylde or even Preston. Best solution might be some form of integration into Blackpool Tramway system.
Very low priority : Colne to Skipton. Neither town is "huge", line missed the largest intermediate location (Barnoldswick). Money could be better spent elsewhere.
Lewes to Uckfield looks like a no-brainer due to capacity problem on the Brighton Mainline but the much bigger (multi-billion) project would be a whole new line from Brighton to London and northwards in what has been called Thameslink 2
The issue with any new line on that corridor (Brighton-ish to London), is that it needs to serve the big traffic generators in the corridor: Brighton, Gatwick, Central Croydon, and to a lesser extent Haywards Heath and Crawley / Three Bridges. Any option going via Uckfield fails to do this.
That's Brighton Main Line 2, which I absolutely support. I would prefer stations reopening at Isfield and Barcombe as well as a new stop at Hamsey
www.bml2.co.uk. Maria Caulfield mentioned it to Grant Shapps and he was said to be very interested in seeing the proposals. There is also funding in place via a large consortium plus detailed design work going on, remember pretty much every bridge and structure has to be re-designed and checked.
There isn’t funding in place. If there was, why hasn’t some of it been spent on a feasibility study?
It really hasn’t. It’s stil crayoning.
The previous studies using the Hamsey (1858) connection failed (notably the 2008 study) because the connection points the wrong way, hence the tunnel under the downs idea. North of Croydon there's talk of going up the old Selsdon line, I believe NR are building a couple of new platforms at East Croydon and not going for the BML2 idea until that's done.
Not going for BML2at all, more like.
No that study failed because they couldn't get enough passengers to use the line to get to Eastbourne in 2008. Bare in mind that rail usage was considerably less in 2008 and they've underestimate the growth since - the case has surely improved.
Unfortunately, the 2008 report over estinste growth. Quite considerably. The study would have used standard growth rates as per TEMPRO and WebTAG, which are broadly related to economic growth / population growth (plus some extra factors) - typically around 2-2.5%pa. Compounded this would be around 25-30% growth expecte day now on the same service pattern. It’s actually been 9.5%.
Unfortunately, the relatively small increase in usage will have been more than offset by increased costs - notably longer trains and staff costs rising much more quickly than income.
Did it? What was the BCR?
Less than 1. It wasn't bad, but it wasn't going to recoup its capital costs. It might do now with a large amount of growth in rail travel.
It ranged around the 0.7-0.8 level. But that was with costs that were, let’s say, optimistic, without proper risk allowances. The costs would be more than double what was quoted back then. The benefits will be, if anything, a little less. I’d be surprised if the BCR would get past 0.5 now.
MP33
19 Jun 2011
When re-openings are proposed the re-instated line does not have to follow the previous route exactly. An example would be the Braintree to Bishops Stortford line. This closed before Beeching, although part of line remained open for freight for some years later. From Takeley at the western end you would not go to Bishops Stortford today. Stansted Airport would be the destination.
There was a suggestion that the Sudbury (Suffolk) branch line was re-instated for a few miles to serve new developments. If you were to extend further to Bury St Edmunds there would be no need to connect to the existing station again. A south station in close proximity would be sufficient. There is no need for transfer of Sugar Beet trains anymore.
S&CLER
11 Jan 2020
southport
The advantage of that idea was not so much that it was more direct from Nottingham to Peterborough, as that it would get cross-country trains off the ECML between Grantham and Peterborough, especially the 2-track section through Stoke tunnel. The intermediate population served might be larger as well (I haven't checked the figures).
JBuchananGB
30 Jan 2017
Southport
Round here people talk about reinstating the south Burscough curve, to enable the successor of Northern to operate Southport to Preston, with a reversal at Ormskirk.
Then there's always mutterings about getting the railway back into Skelmersdale, but that is a place where a road has been built where the railway used to be, as well as a lot of houses in the vicinity of Rainford Junction.
class26
4 May 2011
3. Blyth & Tyne - but a question, how to serve Blyth ? the largest intermediate location (Barnoldswick). Money could be better spent elsewhere.
Blyth is proposed to be served from the "main line" by stations at Newsham and then Blyth Bebside. Blyth itself remains a freight only line to the port. See Modern Railways February 2018 - excellent article about this line plus Tavistock - Okehampton
si404
28 Dec 2012
I didn't say it wasn't crayoning. I said "less absurd" and "more reasonable".
It's still absurd, and definitely not reasonable, but it isn't as bad as it was. They now understand that they need to serve central Croydon, and that they can't just evict Tramlink and Hayes line services from the corridor they want to use.
They've gone from these crayons to these crayons. It's a step up, but it's still crayons.
DynamicSpirit
12 Apr 2012
SE London
I'm assuming you mean the EMT Nottingham-Norwich trains, as I can't think of any XC trains that use the track between Grantham and Peterborough. Is there any need to get those trains off that section of track? There are those trains plus 5tph of Virgin East Coast and irregular open-access services. On a section of line with no intermediate stops to cause any pathing conflicts, 6-and-a-bit tph doesn't sound to me like so many trains that you need to get rid of some?
EastisECML
26 Sep 2018
The line to the port on the Blyth side of the River Blyth has been lifted. Senrug proposed reopening this as a branch off the main Blyth & Tyne line and having a more central station for Blyth at cowpen road. This is now a no go as the cutting has been filled in and houses built on top. But that's fine because from Newsham junction the alignment to Blyth's old terminus station is mainly intact to where it crosses over Princess Louise road. Just after that is the sports centre car park and a pathway past it towards the town centre. There's enough room there for a single track and platform right on the edge of the town centre.
But the two currently proposed stations on the edge of the town are in key locations as these are the points where most traffic leaves Blyth. So it's not like people have to go out of their way to reach the railway line.
2020-2024
2021-2023
2022-2024
2025
Additonal options
2025
2026-2028
2028
Umm, I hope you don’t do construction planning for real!
You couldn’t start any main construction works until the planning and consents work is done. A typical timescale for such a project, ie building a new railway where there isn’t one today is:
1 year initial feasibility / Business case development
2 years development prep for consents
2 years consents process
1 year mobilisation (land acquisition, compound construction, finalising design)
3-4 years construction (more if tunnelling required)
6 months testing / commissioning / Entry into service.
Approx 10 years from a standing start. And that’s if it all goes perfectly, with the politicians approving spend immediately they are asked to, and no major objections to the consents.
It is somewhat simpler if the railway is already there, as it was with Ebbw Vale, Oxford - Bicester, etc. For example Ashington could be up and running within about 5 years if the existing level crossings can be upgraded rather than having to build bridges; but that’s because, effectively, the feasibility and early development work has already been done.
S&CLER
11 Jan 2020
southport
Yes, sorry, unintended ambiguity on my part; I meant EMT but used cross-country with a small c in a general sense to mean not to/from London. I see now how it could mislead. As for the main point, I think the speed differential between EMT's dmus and ECML Azumas may have something to do with it; it could sacrifice a path.
To return to the point of directness, any line via Cotgrave would be a mile or two longer than the old Midland route from Peterborough to Nottingham via Melton Mowbray and West Bridgford, which was 55.25 miles from Peterborough North, according to the last Bradshaw of May 1961. And there would presumably be 3 stops instead of just one. Nottingham-Peterborough via Grantham is just under 52 miles.
class26
4 May 2011
Apologies, wasn`t aware that the line to Blyth port was not intact.
Mr Mean
10 Dec 2015
Investment in the railways is always good news but I agree with some of the posts that say we cant just reopen lines for nostalgia.
This money must be used to serve a purpose; to help alleviate congestion on the roads, stimulate growth and/or provide resilience or a better service to those that already exist.
For example in West Yorkshire, where im most familiar, reopening the line to Wetherby would help cut congestion into Leeds and stimulate growth in east Leeds. On the other side of the coin, assuming a route such as KWVR was closed, reopening this would not bring many benefits as it doesn't serve a very populous area.
I just hope the cash is spent productively and not just on fancy presentations as to what you could have if you spent even more money!
Whilst it would be a benefit for not having to cross the mainlines at Water Orton (from the North East, not to it), there isn't a massive amount of freight from the North East that requires to go via the Sutton Park. About 15 in total both ways a day. Sutton Park itself isn't an issue, there is plenty of capacity on the line.
XC would never ever go that way. Why would they? Lichfield is served by the cross city and Walsall gets plenty of services to New St, do not fall into the trap of every station needs long distance links. It would also be a much slower route than the 125mph down to Water Orton.
Alrewas via the Cross City is a hell of a lot easier than round the houses as per your suggestion.
Aldridge can work now. It doesn't need freight moving off the Sutton Park.
