According to the NRCoT:
Now, I'm interested in the Greater Manchester Traincard which is a PTE product. The only terms and conditions I can find anywhere online are at http://www.nationalrail.co.uk/times_fares/pr93c0eaeb9d4653b48ac9b0307154fb.aspx and there is nothing there which excludes using this ticket in accordance with condition 14.2 above (ie. treats it as a season ticket).
I'm going to buy the Traincard rather than a point-to-point season ticket anyway, since for the journey I want to make it's actually cheaper. But what I'd be interested in finding out what is the general opinion of my analysis of the above.
What do you think?
Link: http://www.nationalrail.co.uk/National Rail Conditions of Travel.pdf14. Using a combination of Tickets
14.1 Unless shown below, you may use a combination of two or more Tickets to make a
journey provided that the train services you use call at the station(s) where you change
from one Ticket to another.
14.2 If you are using a Season Ticket, daily Zonal Ticket, or another area based Ticket such
as a concessionary pass, ranger or rover in conjunction with another Ticket and the last
station at which one Ticket is valid and the first station that the other Ticket is valid are
the same, then the train does not need to call at that station for your combination to be
valid.
14.3 Some Tickets specifically exclude their use in conjunction with other Tickets. This will
be made clear in the terms and conditions when buying such Tickets, and you cannot
use such a Ticket in conjunction with another except as set out in 14.1 above.
14.4 In all cases you must comply with the specific terms and conditions of each of the
Tickets you are using (for example, keeping to the valid route(s) and train services for
which each Ticket is valid). It is your responsibility to check that you comply with the
Conditions listed above.
What do you think?
