markem41
As a passenger using the soon-to-be-forgotten Manchester-Liverpool (ex-CLC) route, will I see any improvements to my journey as a result of these plans or am I condemned to overcrowded peak-time travel for eternity?
The southern route via Warrington Central.
I wondered about that, but unless they're going to electrify South TPE (Hope Valley and via Barnetby), Sheffield - Grantham via Nottingham and Ely - Norwich then there wouldn't be much point. By electrifying the northern route via Chat Moss it enables local diesel services on that line to go 100% electric.
Its a little like the Leeds - Manchester situation - the northern version is more "self contained" and therefore better to electrify than the southern "long distance" route - hence my feeling that the Bradford - Halifax route may be wired before the Huddersfield one is
I reckon the self-contained half hourly Pacer service through Warrington is sufficient justification to wire this route too (EMUs would have better acceleration and be able to get out of the paths of the "fast" trains better too), especially as both "ends" are already done - certainly better cost/benefit ratio than Newbury - Reading!
The people of Warrington will certainly make their voices heard if it is proposed they lose all long distance services from Central station
Hammond was responding to the inquiry into the value for money of the IEP program which offered as a possible alternative (Along with life extend 125's) the changing of locomotives. Hammond was saying despite the reports findings it was impractical so no need to worry there.
Yep, if you listened to the debate Hammond wasnt too hot on his northern geography. The diversion of Manchester-Scotland services away from Bolton is mainly to relieve the capacity constraints on the Bolton line where additional paths are wanted for faster, longer and more frequent commuter/regional services, including the single line section which hampers flows considerably. Despite this route being less compass direct it would be faster passing through less stations and with higher line speeds. Moving the service back to the Bolton line when its electrified a couple of years later has been considered but is currently not favoured.
