Grand Central apply for Newcastle - Brighton direct
The exile
31 Mar 2010
Somerset
I think they'd stand a better chance if they went from Oxford to Sheffield via Bedford, Leicester and maybe even the Erewash valley. That would probably pass the not primarily abstractive test.
Given the fact that there’s currently nothing to abstract from…
Howardh
17 May 2011
Probably more like 3-3.5hs based on current journey times
So from, say, Nuneaton near Birmingham you're in London in 75 mins, then walk to St Pancras in 15, then Gatwick (1hr max) or Brighton in 1.5hrs max including waiting for the next service; looks like the traditional route pips the "new" one; but only just? Avoiding the walk might just tip the journey in favour of the "new" route for some?
Also would there be equivalent seating/services on the "new" train, such as Advance Standard seating, snack bar and so on? If there were then I would absolutely consider Manchester - Birmingham - Brighton as a viable alternative.
Bristol
There’s no capacity between Reading, Gatwick and Brighton. IIRC that is basically why XC were binned off the route nearly 20 years ago. Surely NR will still take the same stance?
Are Redhill and Gatwick Airport still officially congested infrastructure? Can see that being a fun discussion. Can't imagine Arriva will be happy to stump up for any major works to enable the service.
It's not really about end to end (no cross country journey is), it basically gets the Brighton service back onto the network.
If this is the only reason for doing it, it's not a good one.
They also need to pass the 'making a profit' test for their own shareholders, of course.
FlyingPotato
23 Mar 2023
Always moving
The benefit of the service for airport passengers I think given the times are very similar, would be that you are sat down and you don't have to move till Gatwick or Brighton (In theory), would be very good if you had loads of luggage, children, were mobility impaired or just wanted less stress. I think GC said they would have a special designed train or that might have been a poster
BranstonJnc
4 Apr 2025
Castle Gresley
This is one of the worst things to ever be proposed.
Quite apart from the fact that Newcastle / York to Birmingham is perfectly well-served (especially if York - Brum via Doncaster is going back hourly with XC), if you're doing pretty much any journey in that list of Newcastle - Derby, all of it can be done rapidly via St Pancras / Kings Cross and Thameslink down. You are not going to sit on a crumby (I suspect initially surplus 180) round the houses.
Then, there's the sheer stupidity of trying to thread a service into the North Downs which eventually will be 3tph won't it? At least between Reading and Guildford.
I would immediately assume that the smartest way of doing this would be to run down to Finsbury Park, round the Camden Road, over the North London, down West London and onto the Southern. This would remove needing to reverse at Redhill (which is congested), and trying to get into the mix with freight via Solihull and Oxford.
You would also have the added benefit of being able to add a call in at Finsbury Park in a sort of "out of London" way, giving you the option of cheaper tickets from the North East to there; you could stop at a major station like West Hampstead, as well as Shepherds Bush (Olympia is old hat), and somewhere like Balham.
RT4038
22 Feb 2014
Why is that such an important objective of threads started every few months? Maybe GC should actually go for Liverpool to Brighton, that‘ll get the XC bingo full house…
via Bedford and Oxford preferably......... (as this the new 'must have' route)
If they’ve found 5 spare paths between York and Newcastle, why can’t the proper XC operator use them to extend their Reading to York services back to their full length, and full almost hourly frequency?
BranstonJnc
4 Apr 2025
Castle Gresley
To be fair, if I was XC, I'd sooner not extend the services. Releases some units, and crew, and saves a bit of extra bother. There are times when we would have to say that as part of the greater good, people should be turfed off a train with 4 coaches onto one of many with 9 or 10 coaches (LNER, XC via Leeds) so that capacity is used effectively.
18 Mar 2007
North Oxfordshire
Like most on this thread, I'm very sceptical that this will ever happen.
However, any proposal to improve the capacity on the Birmingham-Oxford-Reading axis is welcome, as the existing XC service is really not fit for purpose.
Unfortunately, it sounds like this one would still involve running silly short trains that waste valuable paths, rather than at least 8/9 car sets that could cope with both short and long-distance demand.
A direct link Birmingham-Gatwick service also makes some sense to provide better airport links, but with the constraints on the North Downs Line, I don't see it happening any time soon.
Bishopstone
24 Jun 2010
Seaford
Putting Brighton and Gatwick back on the cross-country network sounds like a great idea to me (in East Sussex, admittedly), but I note the wall of pro-railway (presumably?) folk who think that having more trains, opening-up more direct journey opportunities, at no direct cost to the taxpayer, in a time of climate concern, is somehow a terrible idea.
If the DfT/Government think this operation would be so successful that it would leech revenue from their subsidised entities, they could tender or directly operate a similar service themselves.
It will be interesting to see what they are expecting to be flexed to make this work. I wonder if they are looking for the slots the XC are currently not using.
With Grand Central being Arriva, is this an attempt to keep the most profitable bits of XC on nationalisation?
To be fair, XC (and BR before them) have rather thinned out the service over the years, until the mid 1970s many trains ran using Warwick route instead of through Coventry
And when XC was first privatised still had trains to South Coast, (both Brighton and Portsmouth) both now dumped. Could interpret it as not wanting the revenue, so they can't really complain about abstraction.
Back in 1980s and 1990s XC via Oxford might have been 2 hourly, but would get 10-12 carriages, nowadays XC is hourly but often only 4 or 5 carriages, and risk of overcrowding or struggling to get on at Oxford as only 4car train is provided is high. XC seems to be pricing to limit demand (even if low profitability), not encouraging travel from Warwickshire to Sussex
That is fine, as long as its not detrimental to the actual running of the network. Just because a path might be there, doesn't mean it doesn't tip performance over the edge. It would leach off existing intermediate flows and still doesn't mean its the correct thing to allow.
If you're going through it anyway, surely a call at Leamington would be in order.
They have either decided that is too abstractive off XC, or it doesn't work in the timetable.
BranstonJnc
4 Apr 2025
Castle Gresley
Would a Thameslink core service ever be allowed or would it be refused on the basis of no paths?
Well apart from the fact you'd probably be mandated to have ETCS on the units being used, and the fact that there's restrictions on what diesel-powered things can go into the Core (City Thameslink fire alarms?), you'd only be able to do it off-peak as at peak times the service ramps up. I'd also be interested to see how it all works with trying to send an Intercity-type train into the core which would need 2 minute dwell times at stations, rather than 30 / 60 seconds.
11 Jan 2015
And via Kensington Olympia puts one on the slow side of the Brighton Main Line (note the Engineer's Line Reference is VTB not BML) at Clapham Junction requiring northbound trains to cross the down fast at Balham and the down slow at Clapham Junction and southbound ones to merely cross the up slow at Balham.
In general I'd support frequent trains onto which connections can be made than infrequent ones. The former is much better for network connectivity, though the rise of advance tickets suggests the longer distance operators aren't worried so long as they know the yield of each train.
jh64
3 Sep 2015
I assume this is going to use the infinite pool of surplus Voyagers that all the Open Access applications are trying to use?
They have an order in for Hitachi AT300s to replace their current fleet, I expect they will have follow-on options for more approved routes.
fgwrich
15 Apr 2009
Hampshire
Congrats to Grand Central for coming up with an idea that would make the Speculative Threads on this forum blush
Indeed. The irony of Arriva’s own press release stating that the reason for this is “providing vital connectivity for underserved communities along the route” considering that 75% of that parallels its own franchise, it could be argued that Arriva itself is the ones underserving those communities!
More than likely refused for several reasons (and why you’ll never see anything other than 345s through the CrossRail Core). Pathing, gauging, signalling, all of the above.
