James James
- Joined
- 29 Jan 2018
- Messages
- 426
Oh no-Televisions in the coaches
The televisions with their stupid repetitive noisy and unwanted announcements make me regret stepping onto the HEX every time I've taken it.
Short term once the IETs take over the Bedwyns in the coming weeks and the 769s come into service over the summer that will free up Turbos in 6 car guise to go back onto carefully selected main line suburban diagrams to reduce the number of 387s required in service even further. Crossrail will then massively reshuffle the pack when it introduces its Reading services; and the 387 service requirement will drop to the high 20s, leaving several units to strengthen more semi-fast services to 12 car.
Paddington is in the sticks, it's not a business travel destination.
Nearer units 9+10 in conversion AIUIReally?! What I’m hearing is that December might be ambitious, let alone this summer. AIUI there’s only one 769 unit in existence so far?
4 have escaped Brush so far
GWR also have a 319 for initial familiarisation at Reading.
Because this is, in effect, using up the "spare" 387s freed by the pause on the Oxford (and presumable Basingstoke?) Electrification. There will also be slack in the fleet once Crossrail gets up and running to Reading, which will take over the Thames Valley Stoppers from GWR.
They would surely have accounted for Crossrail already when the 387s were ordered. Crossrail and it’s extension to Reading were confirmed way before the 387s.
But then again, hadn’t the 387 fleet numbers already changed from the original number in the franchise agreement to account for both the altered Newbury/Bedwyn traction policy and the removal of all the intended 365s?Not quite the full story - the spare 387s are being freed up by a combination of:
Crossrail stoppers had always been factored into the numbers.
- Pause in Basingstoke, Oxford & TV branches electrification (use of Turbos/769s/802s instead)
- Additional order of 7 Class 802s permitting use of 800s on through Paddington-Newbury-Bedwyn services (instead of split service of 387s to Newbury + Turbo shuttles)
- New order of 769s replacing a mixture of Turbo and 387 operated services
Any idea when the first unit will be released?
"Televisions"?? Why on earth are these thought necessary for such a short journey?This is the area updates or commentary can be posted regarding the class 387s of GWR but specifically the HeX refurbishment process and the nature of the layout etc and eventually the introduction into service of these units.
Confirmed:
-New Wi-Fi
-2+2 Standard with 1+2 First (implied non-ironing board config.)
-Extra luggage rack space
-Generally more luxurious details.
Expect a class 185 style revamp that could look nice with wood/chrome accenting. There is so much space for creativity in train interiors. Mood lighting is a good idea and for HeX is a realistic proposition given the lighting in the 332s.
Since the HeX is the UK’s most expensive train per mile and the least used by regular passengers, I can understand if there is a lack of interest for it on here but I thought I would add the obligatory 387 status update page.
So far: 387 unit 140 is confirmed at Ilford in old green livery undergoing the refurbishment.
Surely GWR can't release all 10 units without shortforms in the Thames Valley?
There are barely enough units for 8 car operation atm.
This has already been covered in post #28.
It does look pretty good and classy yes.They could have painted the cab roof! It does look a little bizarre leaving that in green. On the whole thought, it doesn't look too bad.
Slightly off topic but not enough to warrant a new thread, what's the diagram for the 6-Turbo?Theres plenty of slack in the diagrams. There’s routinely 3 or even 4 spare units per day. Unit availability isn’t the only reason for running 4 car trains.
Unit requirements drop from 39 to 36 from next week, freeing up another 3 sets for mods. Mostly by introducing a 6 car Turbo onto off peak mainline suburban duties; but efficiencies have been gleaned elsewhere.
I'd be interested to know which diagrams myself, so I can avoid the 'pleasure', got quite used to the superior 387's. I'm a bit astonished we're losing new electric trains to be backfilled by the old noisy diesel junk I'd hoped we were shot of. This should not be allowed.
It’s only short term until December when Crossrail takes over the Readings, seating capacity is theoretically almost the same between a 6 car 165 and an 8 car 387.
Turbo should be on:-
0712 Reading - Paddington
0821 Paddington - Didcot
1003 Didcot - Paddington
1142 Paddington - Reading
1248 Reading - Paddington
1357 Paddington - Didcot
1532 Didcot - Paddington
1712 Paddington - Reading
The current PM Peak Turbo stopper (1755 Paddington - Reading) goes over to 8 car 387 operation.
The big question is, will it actually be a 6 car unit in practice?
Noticed that a few Oxford and Gatwick Airport services have been 2 car vice 3 car lately
I'd agree with that, bar the booked Sunday 2 car it is pretty unusual to see one on the North Downs.It’s scheduled to be a 6 car (2x3) - with no Bedwyns the Turbo fleet should have an easier time of things from next week. 2 vice 3 happens occasionally; but really not as often as you’re inferring.
