Greater Anglia Bombardier Aventras (Class 720): Technical discussion and introduction
samuelmorris
18 Jul 2013
Brentwood, Essex
The same reason the Stadler units were changed, visibility not considered sufficient in the more rural areas. Not sure who forced the change.
uxm
1 Sep 2018
Do you think the Intercity and Stansted Express variants will have a black front?
samuelmorris
18 Jul 2013
Brentwood, Essex
No, units already exist in all three classes (720, 745, 755) with yellow fronts. None of the new stock used in the Anglia franchise will have a non-yellow front, at least not initially.
Class37.4
8 Oct 2018
In my copy of ‘Today’s Railway’ there a major article on both new trains with quite a few pictures of both, and the 720 with yellow front looks OK to me in that colour, the bottom valence has been redesigned from the 345’s and looks way better in my view.
The interior looks nice but if your fat like me the gangway between the 3+2 looks a bit of a challenge to say the least:lol:
samuelmorris
18 Jul 2013
Brentwood, Essex
Can you use existing between 3+2 gangways, e.g. the ones on the 360/1s ? There will be the same level of clearance I imagine.
Wivenswold
24 Jul 2012
Essex
I believe there will be 2+2 seating at the end of each unit for us tubbies!
I'll see you there and will try to bring cakes.
Wivenswold
24 Jul 2012
Essex
Sorry to bump this thread without an update but has anyone got any news, information or sightings of a Class 720? Was the first unit completed after the 3 car photo-call in September? There could well be Stadlers carrying passengers before an Aventra arrives at this rate.
Grumbler
27 Mar 2015
The Swiss are renowned for punctuality.
Says the person that's never used the Riviera line along the banks of Lake Geneva/Lac Leman on a regular basis :D Let's say the "env. X minutes de retard" and "suppression" pages on the Solari displays are well-faded from frequent use.
More seriously, though, this is mostly caused by those dastardly Italians and their ex-Cisalpino Pendolinos...
It's alive! Still not sure about that tiny window, next to angular window that's on the wonk with the bodyshape thing on the cab (I'm not a designer). Thanks for that TRAX.
I think it looks quite good, unlike the SWR renders with the shorter cab that more resembles a sci-fi spaceman's helmet.
samuelmorris
18 Jul 2013
Brentwood, Essex
Well, it's outside. Alive has yet to be proven :D
Odd that the front panel is black before it becomes yellow. I presume that's the colour the material comes in...
K.o.R
6 Dec 2017
You can see clearly that it's a single lamp aperture; so, high-intensity LEDs for the main lights?
samuelmorris
18 Jul 2013
Brentwood, Essex
Yeah that's an interesting difference from the 345/710, the front end is also either a slightly different shape or the colour scheme (the grey front valence notwithstanding) is misleading me to think that.
18 Jul 2013
The driver's side window looks more symmetrical on the 710 & 720, it always looks odd to me on the 345 being at a slight angle from the horizontal.
hwl
5 Feb 2012
At last! Slightly disappointed to see the 720 inherits the noisier traction gear of the 710. I guess the 345s were a one-off in that regard.
I suspect the 7 car 345s may not have the final traction motor cooling setup sort yet which might account for some of the noise difference...
samuelmorris
18 Jul 2013
Brentwood, Essex
That may well be true but it's the drive frequency (or a component of it) that's different, around 1150Hz for a 345, around 1400Hz for the 710/720.
angryskipfan
23 Aug 2017
CL345 and CL710 have two speed traction motor blowers so they can be very quiet when under low load. I believe that 720 has the same arrangement but it might have gone into high speed mode due to repeated full power moves on Derby TT. SWR and WMT aventras have moved to self ventilated traction motors.
rdlover777
4 Feb 2014
Kent
I wonder how far we are from service entry then? From memory it was about 9 months between the first dynamic tests of a 345 at Old Dalby and entry into service with TfL. Theoretically that'll be less with this class, but by much?
According to a comment on that twitter post, sometime late this year
dp21
10 May 2017
They have the marker lamps built in. TfL decided they wanted them separate.
The cab is a different shape. You'll note with the 720s there is more of an upward sweep on the side compared to the 345s.
