Guide Bridge to Wigan via Warrington
Andyh82
19 May 2014
I travelled from Guide Bridge to Wigan on Saturday.
Due to engineering work there was only one train per hour between Manchester and Wigan North Western, so some itineraries I was being offered included going via Warrington and using TFW and Avanti
Would this have been valid with the normal £7.50 day return and would it have worked the barriers at Warrington (assuming there are any, if I’d wanted to break my journey) and not raised any eyebrows with any conductors on either service
I can’t find this option being offered on any future dates as future weekends are confused by strike action and the engineering work may have finished.
jfollows
26 Feb 2011
Wilmslow
Guide Bridge to Wigan is not valid via Warrington on an "any permitted" ticket such as a day return, it is valid by routes defined on map NN at https://data.atoc.org/routeing-maps which means direct or via Bolton from Manchester.
Unless the route via Warrington is 3 miles or less more than the direct route via Atherton, in which case it would be valid also. (Piccadilly-Wigan NW 20.75 miles, Piccadilly-Warrington BQ 22 miles, Warrington BQ-Wigan NW 11.75 miles, so it isn't.)
